R50/53 Things You Didn't Know About Your MINI
Old Mar 21, 2008 | 10:27 AM
  #1176
dlpruk's Avatar
dlpruk
Originally Posted by Miniturtlede
Hi
I am new on this forum.
I too have read so many posts on this thread (my personal favorite) I might just have to spend several days just sitting in my MINI. What could be better? driving my MINI!!
anyway I hope I am on the right thread. I put air in my tires...regular not run-flats when the orange light on the speedo started blinking. They are fine according to my tire pressure gauge but the light keeps blinking. Is this something I have to have fixed by a professional or is a do it myself thing?
Thanks in advance
Miniturtlede
"Allie" 03 MC/BRG/W White bonnet stripes
Did you reset the run-flat indicator after adjusting the tyre pressures?
PP 61-63 of the UK manual refers, but I don't have a US one.
Old Mar 21, 2008 | 10:42 AM
  #1177
Miniturtlede's Avatar
Miniturtlede
Originally Posted by Mini2Go
If you can describe the icon in the orange light, we'd be able to help more.
Did it resemble one of these?
Yes it looks like the one with the ! in it. It is orange and blinking. Is that the traction or the tire pressure?
Thanks Mini2Go.
As to reset of the runflat. I have regular tires not run flat. I bought the car used and have been figuring out most of the stuff she has or doesn't have with my friends at the local BMW place where my mechanic owns a MINI.
I just need to take off work and go over there.
thanks for the input
Old Mar 21, 2008 | 11:01 AM
  #1178
dlpruk's Avatar
dlpruk
Thanks Mini2Go.
I don't think the Run Flat Indicator cares, or even knows about what tyre you have but that's what MINI call the part of the stabililty control system that compares the wheel speed on each corner and flashes a warning whenever one falls below the average of the other three.
It must be reset each time the pressures are adjusted. (I assume you got a manual with your car and I'm sure another US member could refer you to the right pages - but if not, come back and I'll see if I can do an extract from mine!)
Old Mar 21, 2008 | 11:04 AM
  #1179
cabriopilot's Avatar
cabriopilot
Is it the image on the left or the one on the right?
Old Mar 21, 2008 | 12:55 PM
  #1180
daffodildeb's Avatar
daffodildeb
Thanks Mini2Go.
Both have ! in them!
Old Mar 21, 2008 | 02:59 PM
  #1181
Miniturtlede
Thanks for everyone's help. I guess I am one of the guilty ones someone mentioned who didn't read my manual thoroughly enough. I am having a particularly dense day.
I spent my lunch hour reading my manual.
I found the reset button on the emergency brake...neatly hidden by the aftermarket rubber tray that fits under the emergency brake..
And voila...my traction control is happy and so am I.
This MINI owners are the best.....
Old Mar 22, 2008 | 03:08 AM
  #1182
umberto's Avatar
umberto
a traction control light? my dsc is a triangle....are you sure that that light you just reset is traction control?...sounds like it is tire pressure
Old Mar 30, 2008 | 06:58 PM
  #1183
silvrcelt's Avatar
silvrcelt
Things I'd like to know: How do the self-washing headlights work?
There's not much about this in the manual, except how to fill the resevoir. I'm just curious about when and how the "self-washing" process takes place. What does it wash, exactly?
Old Mar 30, 2008 | 07:01 PM
  #1184
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
It's been a while since I had to explain or think about this, so I might not get the details 100% but:
The headlights will only squirt once for every third pull on the windshield squirters within a specific time period (I forget the amount of time before the count is reset) and this is when the headlights are on.
I'm sure someone will correct me if that's wrong - but it's very close!
Old Mar 30, 2008 | 07:16 PM
  #1185
ofioliti's Avatar
ofioliti
Watch:
http://video.google.com/videoplay?do...arch&plindex=0
Old Mar 31, 2008 | 07:30 AM
  #1186
Miniturtlede
Originally Posted by ofioliti
Thanks Ofioliti
I had wondered about that too. That was a cool video
Old Mar 31, 2008 | 10:22 AM
  #1187
daffodildeb
Thank you SO much for posting this video! I'd often wondered what the silver thingie was for--figured it had to do with the washer, but could never find where the water came out.
Another mystery of life solved!
Old Apr 1, 2008 | 05:29 PM
  #1188
minicoaster27's Avatar
minicoaster27
Probably been posted but just found this in my mini.
In the glove compartment (aside from being air conditioned) there is a little sunglasses holder in the part that folds down. Great for my cause I was looking for a place to store my sunglasses in my Mini.
Old Apr 1, 2008 | 07:12 PM
  #1189
MINICHEF's Avatar
MINICHEF
There are also coin holders in the glove box door, but the quarters keep falling out of the slots? Must be designed to fit English coins
Old Apr 1, 2008 | 10:08 PM
  #1190
Ferroequine's Avatar
Ferroequine
When you're using the cruise control, and you want to kick the cruise off for a moment, there is no need to hit your brakes; just press the on/off button ONCE, and the cruise control brain will still be active and remember your previously set speed when you press the Resume button.
Old Apr 11, 2008 | 04:57 AM
  #1191
steimle's Avatar
steimle
Interior Lights
Not sure if this is true or mentioned earlier, but... It appears if you leave the door ajar enough for the interior lights to stay on, they will eventually go out, rather than run down your battery.
I was charging my battery, so the trunk was open slightly. I could see the light was still on. After the charge was done, I saw the light was off. Opened the door and the light did not come on. Uh-oh, I thought. Turned the key and everything was normal.
--Dave
Old Apr 11, 2008 | 01:47 PM
  #1192
AllBlack05S's Avatar
AllBlack05S
That is accurate Dave. Aggravating in a somewhat dark garage when changing gauge faces though.
Old Apr 11, 2008 | 07:35 PM
  #1193
arizona29's Avatar
arizona29
The parcel shelf
Any1 have a pic of the parcel shelf in its special place behind the seats? I tried a few times and just don't see where it goes when u want to take it out of its ment to be spot
Old Apr 12, 2008 | 11:35 AM
  #1194
pmustang's Avatar
pmustang
I can't read through all umteen pages of this thread, but I would love to know how to turn off the autolock doors!!! I hated this on american cars when I lived there and just bought and 06 with this feature, Over 10mph the doors lock. Can this be de-activated?
many thanks. Peter
Old Apr 12, 2008 | 12:04 PM
  #1195
minicoaster27
I have a question:
I remember someone posted in the tread before saying if you hold down the unlock button when you unlock the car, the windows will open. Does this work on 02 Mini Coopers? I tried and nothing happened.
Old Apr 12, 2008 | 12:19 PM
  #1196
cabriopilot
Originally Posted by pmustang
I would love to know how to turn off the autolock doors!!! Can this be de-activated?
Short answer is YES, take it to your MINI dealer and have them deactivate the autolock feature.
Old Apr 12, 2008 | 01:06 PM
  #1197
pmustang's Avatar
pmustang
The salesman said they could do it but I would have to be sly about asking, I don't think they want "safety" features de-activated. I will surely ask though.
Thanks. Peter
Old Apr 12, 2008 | 01:34 PM
  #1198
MotorMouth's Avatar
MotorMouth
exactly and depending on the dealer be prepared to pay a small fee.
Old Apr 12, 2008 | 04:00 PM
  #1199
cabriopilot
I think thats why the salesman told him to be sly about it.
More so than a safety issue.
It is normally free if you have many of the ON/OFF features done right after you buy it from them.
I have had mine for about a year now and I keep forgetting to tell them that I want the daylight feature turned on.
Old Apr 13, 2008 | 03:25 AM
  #1200
pmustang's Avatar
pmustang
Since I have not collected the car yet and have yet to pay for it in full I think they may want to do the door lock thing.
Thanks. Peter
