R50/53 2004 MC40 headliner colour
Old May 18, 2023 | 08:19 PM
bcgreen's Avatar
bcgreen
I been out of town for 7 mos. and will be replacing the headliner when I get back.
I don't remember the colour of the fabric and is it foam backed?
If there is anyone who had done the MC40 can you tell me where you purchased the fabric?
Old May 19, 2023 | 10:41 AM
Horizon Gray is the factory color. This is the part with no sunroof option.
https://www.ecstuning.com/Search/Sit...h/51447114579/
Here is the MINI Cooper Headliner DIY R53 R50: https://www.northamericanmotoring.co...liner-diy.html
Old May 24, 2023 | 11:52 AM
mrbean's Avatar
mrbean
When I did mine I ordered from yourautotrim.com. Their foam backed "light gray" material is a perfect match to the stock horizon gray.
Be sure to order 3 yards of material as you need just a little more than 2 to get full coverage.
A couple of comments regarding the DIY link above.
I was not able to get the headliner out through the back hatch - I had to remove both front seats and wiggle it out through the passenger door. This is the way the factory manual says to do it so be prepared if you run into the same issue.
Be very meticulous getting all the old adhesive off the backerboard. 3M makes and "adhesive remover" in an aerosol can that works great. Any residual adhesive will compromise the quality of the new adhesive.
It can be tricky to get all the bubbles and creases out of the fabric, take your time and be patient. Having a second pair of hands is very helpful.
Old May 24, 2023 | 11:57 AM
bcgreen's Avatar
bcgreen
Interesting how some are able to slide it out the back.
Old May 24, 2023 | 12:04 PM
bcgreen's Avatar
bcgreen
Couldn't enlarge the chart - would you be able to give me the prt. number?
Old May 24, 2023 | 01:18 PM
Jonny's Avatar
Jonny
Most do get it out the back successfully. You do need to bend it somewhat. If you’re careful, you won’t damage the headliner. It is a little more flexible if you have a pano roof. No need to remove the Apiillar cover completely, but will need to remove rear seats, rear trim, remove B pillars, loosen C pillars. Sometimes good to look up the trim pieces on Allmag etc. so you can see where the clips and tabs are.
This is another good DIY thread with great pics. https://www.northamericanmotoring.co...ml#post4652454
Also check to make sure the foam is 1/8” not 3/16” if you have a pano. From my understanding.
Attached Thumbnails 2004 MC40 headliner colour-ffae2f2b-15c5-4de8-91d7-400d04c480e5.jpeg   2004 MC40 headliner colour-e67c74fe-e49d-4bd5-b322-bacbaab58045.jpeg   2004 MC40 headliner colour-07c10d24-123e-4f4a-a72b-d273cdfe68f8.jpeg
greatgro
Mid-Atlantic
Oct 4, 2004 06:57 AM
CA-SPORT
14
Feb 2, 2004 06:08 PM
d2mini
16
Oct 23, 2003 06:26 PM
CraigRasmussen
Jul 16, 2003 03:54 PM
