R50/53 Strange missfire/bucking issue? Ideas?
My 03' R53 started doing some weird stuff on the way home from work yesterday. When ever I start getting on the gas, and I start building boost.....the power from the motor will cut out for a second, almost feeling like a misfire or dead cylinder. It didn't do it every time I got on the gas, but most of the time it would....it would bobble and skip a beat or too. The plugs and wires aren't that old...but it sure does feel like some sort of misfire.
I don't have any codes ...so I'm at a loss. Should I just go ahead and change the plugs and wires, or could it be something else?
I was going to say this too. Check the terminals for corrosion too possibly .
I have a misfire/hesistation under heavy load as well. Went to swap the coil out today and 2 of the 4 bolts were stripped (on the valve cover side) so take it easy when removing and tightening the coil pack bolts.
Yes.....it feels like a misfire. I will take a look at the coil. If it's got a lot of corrosion on it......should I just get another oem MINI coil, or is there a better aftermarket "performance" option out there?
Thanks guys!
Thanks guys!
Check your plugs as well, I had one that had microcracks from the factory, it took me a long time to diagnose it as I "knew" that the plugs were good as I'd just changed them....It had an 1/8" wide carbon track all the way down the insulator-obvious once I pulled the plugs.
I don't think it's a traction control issue......it will do it going 70mph down the highway sometimes. But I can give it a try.
The car is 17years old, and has 180K miles on it........The current plugs and wires have around 30,000 miles on them....and the coil is the original. I went ahead and order new plugs, new wires, and a new coil today....I'm hoping that will cure the issue.
Indulge me and throw just the new coil on and see if that helps the situation. Crazily I had a coil fail on my Mini recently, so i bought a brand new OEM mini coil, and that too failed within 3 weeks, and then the replacement finally cured the issue. Basically would misfire under load and when it reved above 4.5k rpms.
I'm curious to see what is causing the actual problem.
***UPDATE***
Well, my new coil never came in on Friday like it was supposed to, but I did get my new NGK plugs and wires. The terminals on the old coil were all corroded and looked horrible. I cleaned them off, installed the new plugs and wires, and so far...the car is running great. Not sure if I will install that new coil when it shows up, or just return it. So far so good.....
I would install it for peace of mind, keep the old one as a spare unit.
Add a small dab of dielectric grease on the connectors > https://www.farmandfleet.com/blog/wh...%20connections.
***UPDATE***
2003minicooper
May 3, 2012 03:57 PM
