R50/53 Chrono Pack Retrofit - All the info you need (hopefully)
Old 07-05-2023, 08:45 PM
Dotradepro's Avatar
Dotradepro
Dotradepro is offline
It’s not really possible to find a new chrono, I know what my mistake was, but the flash is lost for my board, now I’m restoring it in pieces and I think if I had a second board, so there was no problem, since I successfully counted the old odometer, reset the vin code and mileage, so for the car it has become new, when I restore the firmware of my chrono package I will do the same
  #277
Old 07-06-2023, 05:18 AM
Couch53's Avatar
Couch53
Couch53 is offline
I haven't spoken directly with Mini but from the looks of it, you can still order a new one. I guess I was wondering if that is indeed possible that it can just be coded by mini as a new unit and work around the mileage issue. Might need a new Speedometer tach as well which looks to be available too.
  #278
Old 07-06-2023, 10:11 PM
Dotradepro's Avatar
Dotradepro
Maybe I didn’t put it right, I can encode the panel as a new problem in that I had 2 panels and, due to not knowing on the chrono package, I killed the flash firmware and now I can’t get the arrows to work, I had my native odometer in the center, I successfully reset it because I already knew what I did wrong and he was defined as new in ista-p
  #279
Old 07-09-2023, 07:49 AM
Dotradepro's Avatar
Dotradepro
I can confirm today that I successfully flashed the chrono dashboard and managed to program it as new at the end I received my native mileage equipment and vin number
  #280
Old 07-09-2023, 12:05 PM
cut7's Avatar
cut7
cut7 is offline
Can you please post a detailed description of how you did that.
  #281
Old 07-17-2023, 09:57 PM
Dotradepro's Avatar
Dotradepro
I have not yet been able to activate the oil pressure and temperature arrows in ncs expert there are two items but they are not saved in the car settings
  #282
Old 07-17-2023, 09:59 PM
cut7's Avatar
cut7
cut7 is offline
I meant how you flashed the chronopack with the R270.
  #283
Old 07-18-2023, 02:12 AM
shrevemini's Avatar
shrevemini
shrevemini is offline
If your car is a pre facelift they will not work. You need to get a post lift DME an program it to your car’s specifications. Then you gauges will work.
Onizukachan (07-21-2023)
  #284
Old 08-28-2023, 06:14 PM
Onizukachan's Avatar
Onizukachan
Onizukachan is offline
Read eprom successfully with r270.
loaded binary files for 30 I downloaded from GitHub, removed .txt. And renamed from .bin to .BIN
Tried writing the flash (I assume you select flash) and tried writing eeprom with the 0km file.
both said it was “data size invalid” seems to be an absolute assload of commentating in it? The original read was minimal and any commenting mostly gibberish?
joshzash14 (09-18-2023)
  #285
Old 08-29-2023, 12:27 PM
Onizukachan
Figured it out, you have to download raw from repository, not right click save as from link in the instructions.
then the flash is only 131kb and eepron only 2mb
  #286
Old 09-18-2023, 05:49 PM
joshzash14's Avatar
joshzash14
joshzash14 is offline
Onizukachan - any chance you'd be open to reprograming my units? (Have a chronos pack and nav unit) - plan to swap the nav units screen out for a carplay like unit in its place, but wouldn't mind having the chronos unit in its place for the time being.
Feel free to PM if you'd like.
  #287
Old 09-19-2023, 09:55 AM
Onizukachan
If you were local, I would
if you have a windows computer, get the r270, install the software and download the flash and eeprom files.
Follow the TDLR directions and strip out the numbered wires from the ribbon cable about 6” back and connect the wires as indicated in the pictures on GitHub.
make sure you can read it beforetrying to flash anything.
What I did to get a good read was tin the only rearmost section of exposed wires after stripping so I could press fit them into the socket holes in the board amd when they got to tinned section, boom. They stayed.
there is only one wire that needed to be soldered in place so I tinned that one fully and just touched surface contact point with iron to preheat, then put wire atop and touched wire with iron to make a temp connection I could just pop free after.
when you have a good connection it will read or flash it in 6-10 seconds, when you don’t it will stall and sit there not actually doing anything for minutes.
after you have it flashed, hook it up to car.
Don’t bother with copying vin etc from old one, dont even bother trying to read old one.
once it is virginized, if you have pasoft 1.4 aka bmw scanner, it has the options to import over from ews in menu with a click, instead of having to fndtlessen etc amd switch moduels and codes back and forth in NCSexpert…, those options are in it for one click operation. Worth the $20 for that one too, have had mine for about a decade and used on 2 former early 2000s bmws and now 3 r53s.
  #288
Old 03-14-2024, 09:47 PM
Chamberlin1's Avatar
Chamberlin1
Chamberlin1 is offline
As opposed to doing all of this coding stuff, couldn't you just swap over the EEPROM from the car's original cluster to the Chrono cluster? I understand desoldering and resoldering a 52 pin IC is no fun, especially as delicate as EEPROMs can be, but with the right tools, it is possible. I'm guessing you might have to fight some conformal coatings as well... but again, manageable.
So in short, wouldn't moving the E²PROM to the Chronopack cluster from the original cluster take care of the VIN/Mileage/features disparities? What else would be needed at that point? For this thought experiment, I am assuming a 2006 facelift center speedo EEPROM being moved over to a matched set of 2006 facelift Mickey Mouse ears/Chrono gauges.
  #289
Old 03-15-2024, 12:58 AM
Onizukachan
Hmm, maybe I’m not getting where it is easier. Seems to be a lot more work than simply revirginizing a chrono? 104 desolders amd 52 resolders for a total of 156 solders compared to… 1 solder, a $20 r270 and 10 minutes time start to finish?
  #290
Old 03-15-2024, 03:39 AM
Warwick Dean's Avatar
Warwick Dean
Warwick Dean is offline
I'm not sure if the EEPROM is where the coding bytes are stored
CCiPhantom
Mini/MINI BUILDS
09-01-2019 12:40 AM
greekzilla
09-28-2017 11:08 AM
witecpa4u
R55 :: Clubman Talk (2008+)
08-25-2013 08:15 PM
Bohica
06-25-2008 10:54 AM
88m
07-22-2005 08:13 AM
Quick Reply: R50/53 Chrono Pack Retrofit - All the info you need (hopefully)
