R50/53 Supercharger planetary gear check... R53
Old Feb 25, 2019 | 07:33 PM
Terry Wilkinson's Avatar
Terry Wilkinson
As it would be, I just saw a similar post but didn't want to highjack but my question a bit different. I too have a 2004 R53 that I've obtained a replacement supercharger from a newer car (2005). Basically only gain is that it has teflon cover blades which is better for controlling heat from what I understand but I'm going with a 15% reduction pulley so I'm also able to basically pre-stage my replacement as another plus. I'm changing the pulley and oil during my process just to be clear. I've have seen many post over the years of owning this car working up to this point about the oil running out of the front and rear chambers. So with this replacement, I've was concerned with the planetary gears that drive the water pump. I've drain the oil, it had about .8 of ounce in it which I felt was good but wanted to know for sure that my gears were good before installing. So pulling the cover, the gears look great... very happy about that. My questions/concern is that I've noticed there is no sealant or rubber gasket... I put the two pieces back together and torqued to 18ft-lbs that I found noted on another site. Now I'm starting to question myself was I supposed to apply some form of sealant on these mating surfaces before I put them back together and torqued? I have yet to put oil back in so there's still time to fix this if I've made a mistake with this. Can someone provide me guidance OR their thoughts on this?
Thanks!
Old Feb 26, 2019 | 04:41 AM
IQRaceworks's Avatar
IQRaceworks
If it was me, I would put a thin layer of RTV Grey on those two surfaces before I bolted them back together. I'm sure someone else will be along to chime in....but that's strange that there is no seal or gasket....I can't imagine they are just relying on the machined surfaces to seal each other.
But I've never had my 170,000 mile supercharger apart yet......so I'm just guessing.
Old Feb 26, 2019 | 09:30 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you do need a thin layer of RTV to seal it up
Old Feb 26, 2019 | 10:03 AM
veedubpat's Avatar
veedubpat
I also found it strange when doing this maintenance recently that there wasn't a legitimate gasket, just the feintest residue of "something."
I personally opted to use a super thin, finger-applied layer of red (high-temp) liquid gasket in lieu of anything official that I could find.
Old Feb 26, 2019 | 05:01 PM
OCR's Avatar
OCR
Note - The drive gears in the Mini supercharger...are NOT of the "planetary" design. Just simple, straight cut tooth "spur" gear design.
Mike
Old Feb 26, 2019 | 07:26 PM
Terry Wilkinson
Thanks for all the replies, very helpful. Also the info on spur gears NOT planetary gears... now I'll have to review that.
Old Feb 26, 2019 | 09:39 PM
OCR's Avatar
OCR
This...is a planetary gear set. A Sun gear, and a bunch of Planet gears, Then there is a ring/driven gear that goes on the outside of the planetary gears.
Mike
Old Feb 27, 2019 | 06:17 AM
Terry Wilkinson
Mike
ok that makes sense... thanks, very helpful!
Old Feb 27, 2019 | 10:41 AM
veedubpat's Avatar
veedubpat
Mike
A la our differentials :thumbup:
poushag
How to
Nov 11, 2013 09:26 AM
A S K
Feb 22, 2010 03:16 PM
Fr33zy
Aug 28, 2009 05:47 AM
megmini5
Jan 17, 2008 09:48 AM
bobbydanger
Jan 12, 2007 07:42 AM
