R50/53 keeping busy
Old Jan 16, 2019 | 12:25 PM
jk6672's Avatar
jk6672
keeping busy
My LDS and clutch should be here today, but I'm waiting for my passenger side engine mount to get back from power before I can remove the tranny using the engine support bar from harbor freight. I'm going to replace all the gaskets and O rings too.
These hoses look like they've been soiled a lot and feel flimsy, I'm going to replace them too, does anyone know the part number of them or what they are called? Keep in mind I've never had a R53 previously or taking one apart, they look like part of the heater system. Yes, I'll be replacing the oil filter housing gasket too.
I found the wire that I believe connected to the oil drain plug once upon a time, can anyone confirm if it's a single blue wire lead? I'm sure if this is it I can just add an extension and a female connector to it. I bought the oil plug and it just has a flat male connector attached to it
I also bought a Mishimoto radiator before I read all the bad news about bad welds and leaks. Bummer, hopefully I'll get lucky with this one. Their intercoolers are highly recommended in the diesel world so I figured it would be the same in the MINI world.
I also took the rack off and pump off because I sent my subframe to be powder coated illusion orange.
Old Jan 16, 2019 | 12:54 PM
JAB 67's Avatar
JAB 67
Those flexible hoses are part of the oil cooler system. Good luck with the Mishimoto radiator; I'm on my third one - the previous two leaked in the same spot and I fear a similar fate for the current one.
Old Jan 16, 2019 | 01:08 PM
jk6672's Avatar
jk6672
Thanks. Looks like the hoses go into the firewall from there so I assumed heater.
where does your Mishimoto leak from?
I may even see if I can return to Way after all the stories I’m hearing and go the Koyo I hear is the go to replacement.
Old Jan 16, 2019 | 02:23 PM
mountainhorse's Avatar
mountainhorse
First.... Great thread and photos !
Second... what IS the best radiator out there for the money on an R53... improved or Stock Replacement??
Links and/or prices would be much appreciated!
Where do the stockers typically fail and why?
Old Jan 16, 2019 | 08:59 PM
jk6672's Avatar
jk6672
I've never bought a clutch kit before, do they come assembled? I know I recieved a previously returned one, the tattered ziplock bag and scattered bolts gave it away, lol.
Old Jan 16, 2019 | 09:15 PM
Tgriffithjr's Avatar
Tgriffithjr
Send it back and insist on a new kit.
Old Jan 17, 2019 | 06:12 AM
cooper48's Avatar
cooper48
Looked on realoem.com for part numbers and was surprised to NOT be able to find a diagram of the oil cooler. However, MiniMania sells the coolers/hoses so you might try them.
Old Jan 17, 2019 | 06:48 AM
Tgriffithjr
“I found the wire that I believe connected to the oil drain plug once upon a time, can anyone confirm if it's a single blue wire lead? I'm sure if this is it I can just add an extension and a female connector to it. I bought the oil plug and it just has a flat male connector attached to it.”
Can someone enlighten me about the wire on the oil drain plug? Never heard of that.
Old Jan 17, 2019 | 06:50 AM
cooper48's Avatar
cooper48
It's for an oil temp gauge. That gauge is standard on my MC40.
Old Jan 17, 2019 | 06:53 AM
Tgriffithjr
Old Jan 17, 2019 | 06:57 AM
cooper48's Avatar
cooper48
Old Jan 17, 2019 | 07:04 AM
Tgriffithjr
Can you get that gauge set to install in a non MC40?
Old Jan 17, 2019 | 02:22 PM
cooper48's Avatar
cooper48
Yes. I've seen them occasionally on this forum for sale and also on eBay.
Old Jan 17, 2019 | 02:31 PM
jk6672's Avatar
jk6672
Thanks. https://new.minimania.com/part/NME87...W-manual-Trans
Old Jan 17, 2019 | 02:34 PM
cooper48's Avatar
cooper48
@Tgriffithjr - F.Y.I. on the MC40 gauge cluster: https://www.northamericanmotoring.co...gauge-pod.html
Old Jan 17, 2019 | 02:37 PM
cooper48's Avatar
cooper48
Also, ECS Tuning sells oil temp and water temp gauges for the MC40 cluster but I'm not sure if they're factory OEM, repros or ???. You might check with them.
Old Jan 17, 2019 | 02:43 PM
cooper48's Avatar
cooper48
@jk6672: Just so you know, those oil cooler hoses tie into the water re-circulation system to help the oil achieve peak operating temp.
Old Jan 17, 2019 | 03:48 PM
Tgriffithjr
Thanks Cooper48 for the info.
Old Jan 17, 2019 | 06:51 PM
jk6672's Avatar
jk6672
I followed the hoses and it looks a little confusing, it goes into a four-way coupling.
Bugs
Nov 9, 2006 12:38 PM
biz
Aug 12, 2006 08:48 PM
Doogs
May 30, 2006 12:26 PM
Smooth is Quik
Jan 3, 2005 10:54 AM
noblecomputing
May 2, 2004 01:24 PM
