R50/53 woo busy week for my mini
Old Nov 7, 2006 | 05:15 PM
Bugs's Avatar
Bugs
Wow.. my cars been busy this week
When i started my car had a 4 channel x 35watts amplifier running front stage on 2 channels, and a 12" sub on the 3/4th. Weak at best.
1- remove front seats and my rear seat delete.
2- complete the B-Quiet (dynamat) install under rear seat/rear hatch floor
3- remove crappy 4 channel pioneer amp
4- run a 3rd rca from deck to under driver seat
5- repair 4 channel fuzion 75x4 amp -
6- wire front and rear component sets to the 4channel Fuzion
7- install new 400w mono amp under driver seat
8- wire 12" sub to the mono amp
9- install splitter between headunit and antenna
10- install new CB under the glove box, mounted to air filter cover
11- hook cb up to the antenna splitter
12- run new power to everything
13- reinstall front and rear seats
14- clean car, and work on making myself deaf :impatient
Old Nov 8, 2006 | 05:15 PM
Murmini's Avatar
Murmini
Tell us more about # 2 - the Dynamat treatment.... What areas? What was involved?
Old Nov 8, 2006 | 05:41 PM
allenski's Avatar
allenski
ditto...pray tell.
Old Nov 8, 2006 | 05:51 PM
Bugs's Avatar
Bugs
Originally Posted by allenski
ditto...pray tell.
i used a product called B-quiet extreme. Essentially a direct competitor to Dynamat. Apparently only about 80% as effective, however it is MUCH MUCH less expensive.
I removed the rear seat and carpet in the boot.
I cut pieces out for either side of the battery tray, as well as all covering the entire section below the seat. I made sure to cut the stuff in proper shapes as to allow access to the fuel pump and whatever else is hidden under the black circles. Essentially, i covered everything from the underside of the seat to the back and left access to all screws and panels which may need removal later
exhaust drone is down quite a bit, and the sound 'punch' of the sub woofers is MUCH better.
www.b-quiet.com
very happy customer
I will be ordering another large box to do the entire floor pan and inside firewall of the beetle I am restoring.
essentially, everything under the carpet area, the red area under rear seat, and circular pieces ontop of the black circles under rear seat are all covered.
EDIT
Old Nov 8, 2006 | 06:12 PM
allenski's Avatar
allenski
Thanks for the info. So how does the "road noise" compare, now that you have it installed?
Old Nov 8, 2006 | 06:50 PM
Bugs's Avatar
Bugs
hehe road noise
something i havent heard much from since installing the Borla Race
Old Nov 8, 2006 | 06:57 PM
allenski's Avatar
allenski
^ that's all I needed to "hear"
Old Nov 9, 2006 | 12:38 PM
borrowingamini's Avatar
borrowingamini
I've used "Peal and Seal" which is even cheaper. It's a roofing material that has a reflective side. I've actually done this on my old Maxima and my large screen TV (the 3 subwoofers were making the cabinet rattle like crazy).
All you need is a pair of good pair of scissors, afta (for cleaning the goo out of the scissors), a heat gun, and gloves (that was after I burned myself a few times).
Peal and Seal can be found at Lowes or Home Depot and it comes in a 6" roll (I guess about 20 feet) for like $12. I did my whole trunk in the maxima for like $40. It really made an impact on the sound.
Getrieben
Sep 12, 2024 07:03 AM
xpunisherx
Aug 10, 2015 10:50 PM
M7Speed
R61 :: Paceman Talk
Aug 10, 2015 01:01 PM
M7Speed
Aug 10, 2015 01:00 PM
SDMini_me
Aug 7, 2015 08:10 AM
