R50/53 Best Chip or flash tune for 03 mini Cooper s
Before I spend my money I wanted some opinions. What works best? Looking for hp gain with torque gain and when I want to drive it right better gas mileage.
Appreciate the help
Chazz
Appreciate the help
Chazz
Only chips in the Gen1 is the bag you buy at the grocery store/quick stop. You would need somebody to reprogram the ECU.
In most opinions here the two cheapest mods are 1.) a smaller supercharger pulley and 2.) a stiffer rear swaybar. The first depending on size can get you another 5 psi , or more, of boost and the rule of thumb is that for every 15 additional pounds of boost you double your horsepower. The second will take out some of the understeer.
Have you heard of this?
I found these kind I'm looking at the VR flash tune
https://www.vividracing.com/tuned-ecu-flash-tune-mini-r53-cooper-16l-0106-p-150893849.html
And this other one
https://www.vividracing.com/unichip-plug-and-play-ecu-system-mini-cooper-0206-p-128710.html
And this other one
https://www.vividracing.com/tuned-ec...150893849.html
And this other one
https://www.vividracing.com/unichip-...-p-128710.html
And this other one
Your best option is either a custom remote tune from ByteTronik or RMW, if not those, get a custom canned time from Way, all of these options are much safer.
Don't buy tuning unless your mods warrant tuning.
Injectors over 380's or an aggressive cam = ecu tune. Other that that, the ecu is pretty good at addressing other mods such as CAI or a pulley change.
We do custom tuning and offer basic tunes. But before you consider that we recommend getting the mods you want to do first. Then use the tune to take advantage of them. The car will be tuned for how it is when you tune it, changing mods after that would warrant retuning it.
ECU Tuning
Without any doubts, -17% SC pulley need a tune.Without tune engine will run lean at high rev.Maximum Fuel amount at WOT is calculated for stock pulley.If you introduce more air into the cylinders,ECU can't inject more fuel than is written in fuel map.
On the other hand , more mixture amount need different spark advance maps.Of course is not about to tune only fuel table and spark table.must rework the axis of the fuel and spark table,due to high boost pressure.And also few other modifications on the tables.
cschues80
Mar 5, 2012 10:40 AM
