R50/53 Bought a 2006 R53.... Let it begin.
Old Sep 2, 2021 | 12:54 PM
  #276
bump32's Avatar
bump32
Orp
Originally Posted by Eddie07S
You can make another big step up with the addition of a big front sway bar... A car that wants to step out in the rear is not a well balanced car, and it is not faster through the corners. And, no it will not cause the car to understeer more. One of the thinks it will do is to reduce body roll of the car in corners. An body roll that a MINI has in a corner reduces any negative camber that has been dialed. 2 deg of body roll on your car will result in your car having +0.5 deg of camber on the side of the car that is trying to keep you on the track and causes more understeer. If you are able to reduce the body roll by even a half deg, you have improved the front camber and reduced the understeer... So, while you will hear that a larger front sway bar will increase understeer, in a MINI or other car with a strut suspension, it will actually help reduce understeer. I have built a MINI just like yours and my current one. Guess which one handles better...
I have been thinking about this bigger front sway bar and I like what you are saying. What gets me... is pulling down the front sub frame. Again. That was a big job (for me) and I'm not really looking forward to doing it any time soon. I'm also waffling on a good set of coilovers this winter.
Hmmmmmm
I have signed up for one more track day this fall back out at ORP. I really think the car set up is the best it's been and my time is such that I'm just going to leave it as is.
And since I'm keeping track... here are my hot tire pressures (couple minutes after cool down lap) at ORP running clockwise. More even than PIR.
LF 36 37
RF 36 37
LR 35 36
RR 34 35
Couple more pictures from July at ORP.
Old Sep 2, 2021 | 09:11 PM
  #277
bump32's Avatar
bump32
Driving lights
Finally got tired of looking at the cracked front driving lights. Got some new LED style to match the rear. (I kinda sway back and forth between keeping it stock or making the mini a little more modern)
Good choice....
Old Sep 3, 2021 | 12:58 AM
  #278
nd-photo.nl's Avatar
nd-photo.nl
Team Modern for the win
Mine has the normal bulb instead of integrated LEDs for giving direction (whats the correct name of this haha)
I used some dark tint over the fog lights as I never use these, and it looks better this way imho. Might also be an idea for you?
Old Sep 3, 2021 | 07:07 AM
  #279
bump32's Avatar
bump32
nd-photo.nl I think I saw yours at some point and when I started looking for replacements....the halo/ring version popped out at me.
Eventually I will probably put brake ducts in place of my fog lights. Not a race car just yet.
Mine are Vinstar... nicely made with 4 orange LEDs in the middle for the turn signal. No wires were cut so I can go back to the stock light if I ever want to.
Old Sep 3, 2021 | 07:13 AM
  #280
nd-photo.nl
If I would do trackdays, then I would also replace them with ducts. Thats is a much better plan than adding a tint :D
Old Sep 4, 2021 | 05:56 AM
  #281
Eddie07S's Avatar
Eddie07S
Hmmmmmm
LF 36 37
RF 36 37
LR 35 36
RR 34 35
Great pictures!
A larger sway bar is all about increasing the roll stiffness of the car. This is what a swaybar is designed to do. So that makes them the best option for achieving this. When building up a car for the track, this provides the best option.
Another way to increase roll stiffness is to install stiffer springs. While this may not be as effective as a swaybar, it may be an option for you. That is, install stiffer front springs. Problem is, as far as I know, spring rates are none existent for aftermarket replacement springs that are OEM spring replacements...
This leaves the MINI OEM springs. While rates are not known, it is known that the rates increase from the Base Cooper up to the optional JCW red springs. You could see about getting a front pair of the JCW black springs or better yet a pair of the optional red springs and ditch the front and rear FSDs (not a fan of these for the track, not enough control) and replace them with a set of Koni yellow adjustable shocks. With adjustable shocks, you dial in more front stiffness, which, along with the stiffer front springs, can be made to mimic a larger front sway bar...
A third option is a set of Ohlins coilovers. I pick the Ohlins as I have worked with them and know what they can do and they are moderately priced. Other coilovers don’t advertise their spring rates, so you would not be sure of what you are getting. These are also bottom adjustable. Others are top adjustable, which means the rears would have to be removed to adjust them. Unfortunately the Koni Yellows are top adjustable.
Old Sep 16, 2021 | 08:28 PM
  #282
bump32's Avatar
bump32
Eddie07S Your post has not gone un-noticed... I've been thinking about it but I have become sidetracked with a couple other mods.
POWER
Right now I have:
Cravenspeed 15% pully
NKG spark plugs (one colder) 4285 BKR7EQUP
DDMWorks Cool Air Intake with foam filter
Miltek cat back exhaust
ATI Super Dampener
Next step:
380cc injectors
PC laptop, software and OBDII cables.
Tune with Adriancl
Good info here
https://www.northamericanmotoring.co...ml#post4500764
BlwnAway Has laid out the Power Mod road map in Post 4
I did some research on adding an aftermarket 4-2-1 header to this project but I think I'm going to hold off for couple of reasons. 1) I want to make sure I can pass emissions here in OR 2) New Header with the stock CAT is a bigger project that I want right now 3) If I want to go back to the stock OEM tune and pull a few of the mods off I still can (once the CAT is welded to the new header, I might be past the point of no return) 4) I want to make smaller changes to feel the difference.
Some info on Headers
https://www.northamericanmotoring.co...ed-this-3.html
I was looking hard at the OBX with the Stock CAT but I think my first choice would be a Scorpion.
Old Sep 17, 2021 | 06:02 AM
  #283
Eddie07S's Avatar
Eddie07S
It will be interesting to see what you get with the tune.
I know that tuning an engine is a lot of fun. Tune, see what you get, header (4-2-1 is a good choice), retune, see what you get. The feedback is immediate and the car feels more alive which is a great feeling. Back in the day that is what I did, but it was all in the engine, no computers. I thought that was a good way to be fast around a track, until I started tracking my car and getting serious about watching races. Lime Rock Park is a short, 1.5 mile track. A well prepped, 110-ish HP Miata in the right hands will turn lap times that are on par with a GT3 Porsche in slightly less capable hands. Just sayin’...
OK enough soapbox...
Old Sep 29, 2021 | 01:55 PM
  #284
bump32's Avatar
bump32
GP style wing Part 1
I have never liked the spoiler on the r53 S, but I couldn't bring myself to drop $800 iso for the Orranje GP wing.
I've been keeping a look out for a used one here in the states but they are hard to come by. DING.... found one up is Seattle and had my buddy go grab it for me.
Here's my docu on the GP Wing with a few links to great info and YouTube videos.
Instal video
Fubrication used to make one, good wing info here.
https://www.northamericanmotoring.co...r-picture.html
The wing also fits the R56 so there's info from the R56 guys too
https://www.northamericanmotoring.co...f-spoiler.html
From what I can tell (I don't have the wing yet, it's still in Seattle) The vertical trim pieces are going to be really close to rubbing on the wing side supports. I decided to remove them and see how I like the the "no trim" look. They have some foam tape/3M tape on the back side. Hair dryer, little wedges, long zacto blade and off they come.
Vertical trim piece.
Sticky tape.
Cut with a zacto and then scrape it off with a razor blade.
Much cleaner lines but I can kinda see the red through the gap. We'll see when we get the side supports in.
With the R53 you need to remove the spoiler in order to fit the GP wing on. Here's a video on how to remove the OEM spoiler.
10mm nuts on the inside of the hatch.
Couple notes if you don't want to scratch up the paint under the spoiler.
Don't use wire, use fishing line.
Heat helps, I used a hairdryer.
Painters tape around the wing is great for protecting the paint as you jam the wedges in.
As you pull the fishing line back and forth the line almost heats up the VHB tape and cuts better... make lots of pulls with less pressure.
Here is where all the tape is on the back side.
Paint is still in great condition....
Because there are 2 holes left in the top of the hatch, you have some choices to make.
1) Patch and Paint.
2) Find a r50 spoiler to put on. (more info on this below)
3) Cover the holes with something. (There used to be some little GP wings but they are no longer available)
Choices to make....
Old Sep 29, 2021 | 02:54 PM
  #285
smschriefer's Avatar
smschriefer
Good deal! The funny thing for me is Hyphens Classics just released a G Wing Lite video today so this all looks in order. lol
Old Sep 30, 2021 | 04:29 PM
  #286
bump32's Avatar
bump32
r50 spoiler vs Shark fins
Cleaned up and ready to go.
I don't want to patch and paint the holes. So that leaves some sort of covers or the R50 spoiler.
I think I'm going to try little shark fins first. I can us 3M tape to stick them on and with the little rubber gasket on the inside and drain holes in the bottom of the hatch any water that may sneak in will drain out the bottom. Maybe paint them red?
The GP fins are no longer available. But I'm going to try and fabricate or find something similar. Any suggestions are welcome.
The mini shark fins maybe a temporary fix while I look for a r50 spoiler.
https://www.northamericanmotoring.co...king-info.html
BTW the base spoiler for the R56 does not work on the r53. The r56s have 5 bolts and replace the whole panel instead of bolting on top.
More info here:
Here are all the part numbers for the different colors of the R50 spoiler. There is a Chili RED but that be a needle in a haystack type search.
https://www.realoem.com/bmw/enUS/sho...60#51710146087
***Part number for r50 is 51-71-0-021-452 primed version maybe still available to order???
Going to get the wing mounted up first then decide how to proceed.
Old Oct 5, 2021 | 09:23 AM
  #287
bump32's Avatar
bump32
Bosch Injectors
I've been busy with work and forgot I purchased some 380 injectors on Amazon about 3 weeks ago, turns out they came all the way from Germany. I would assume coming all the way from Germany they would not be counterfeit, but I have read about knock-offs so I figured I would follow through with checking them. Hopefully this can help someone else out there.
There's a couple different ways to check.
1) The QR code on the boxes. Just scan it and a confirmation comes back right on your phone browser.
2) Go to www.protect.bosch.com & key in the 18 letters/numbers printed on each box.
You'll get a confirmation just like this.
That easy....
More info here.
http://www.slturbodiesel.com/identif...e-bosch-parts/
Old Oct 5, 2021 | 10:22 AM
  #288
Thinker2112's Avatar
Thinker2112
The R50 "spoiler," to the best of my knowledge was added there to just clean up the air coming off the top of the car - and to make it look more sporty! Sort of like the way pick-up trucks have that wide top to the tail gates. I am certain it was 100% non-functional as far as down force is concerned; though I really loved the look when I had my R50 - yeah, I sold it..... I do miss it though and the coworker that I sold it too keeps sending me updates of his ownership of it - the first one was a short video of the motor making an unholy clatter; the second after a truck with a tow hitch backed into the rear hatch. It just makes me sad. ANYWAY...... That being said...... The R50 spoiler might actually assist with the fully functional (as I was told) GP wing.... You may have stumbled into something here.
I now know that my RF can be driven on track without an after market roll bar with Track Night in America and Hooked On Driving. I may see you out at ORP or PIR next season.
Old Oct 11, 2021 | 07:12 AM
  #289
bump32's Avatar
bump32
Oil Catch Can - Update
November of 2019 I installed an oil catch can and at the same time I cleaned the inside of the IC. Well, I had the IC off today and here's the inside after almost 2 years and 4 track days.
I would say that's a win.
Old Oct 11, 2021 | 07:30 AM
  #290
bump32's Avatar
bump32
Injectors and Intake valves
380 injectors went in today. (I will post all the details and part numbers here in wrap up post)
For noobs like me... here's a link to Mod Mini for some details. (@5:00 he works on the fuel rail)
Couple notes:
The OEM O-rings can be purchased for cheap and put on the injectors. (BTW these are not the JCW injectors... I think they are Audi TT injectors but I've been told they will work with r53 injector O-rings)
The O-rings that come on the Bosch injectors look very close to the same but I changed them out just to be safe. The top and bottom O-rings are the same so you'll need 8 total.
The 380 injectors are a little shorter than the OEM 320 injectors. But the O-ring seems to be at about the same distance from the fuel rail so it should still seat in the intake manifold. Again I'm a noob here and just noting my observations, please chime in and correct me where I go off track.
After installing, I let the fuel pump run a couple of times and then it started right up. No codes... just ran a smooth as ever.
Old Oct 11, 2021 | 09:47 AM
  #291
nd-photo.nl
Nice! That looks almost squeeky clean
Old Oct 11, 2021 | 12:46 PM
  #292
smschriefer
Where did you get your injectors? I got the kit from ECS and they were longer and black in color. I have the converter plugged on the connectors in the picture. I ended up not using them as they put the wires in contact with the intercooler. I ended up modifying my harness, but I think I saw a kit that used a wire between the two plugs that might resolve that issue.
Old Oct 11, 2021 | 03:04 PM
  #293
ssoliman's Avatar
ssoliman
that does look GOOD. What catch can and routing did u use?
Old Oct 12, 2021 | 07:51 AM
  #294
bump32's Avatar
bump32
I purchased them from Amazon ( directly from Bosch) It took about 10 days for them to get here but I did not want to deal with switching the wiring and these have been used by other guys here on NAM & recommended by Adrian.
Bosch injectors 0280156063 $45 per (more info on these about 4 posts back)
https://www.amazon.com/Bosch-280-156.../dp/B00BHJ63MC https://www.amazon.com/Bosch-280-156.../dp/B00BHJ63MC
*BTW Those are some nasty looking injectors you have there.
Old Oct 12, 2021 | 04:06 PM
  #295
bump32's Avatar
bump32
I put the catch can back by the brake lines, cut a hole through the plastic and tried to keep it cool. I want to go back and take the 90 degree junction out so it has cleaner look and more direct flow but haven't got around to it.
Details are here in post #151.
https://www.northamericanmotoring.co...ml#post4503355
November 2019 I pulled about 1.5 Tablespoons of oil out of the can. Post #212. I'm going to check it again here soon.
Old Oct 12, 2021 | 04:51 PM
  #296
ssoliman's Avatar
ssoliman
very interesting, thank you
Old Oct 13, 2021 | 05:23 AM
  #297
Tragesaurusrex's Avatar
Tragesaurusrex
Nice progress!
I have the same Bosch (Audi TT) injectors and can confirm they work fine with the Bosch o-rings too. The OD was identical as far as I could measure. Been running them for over a year now and a full AX season without issue.
Old Oct 13, 2021 | 10:09 AM
  #298
Thinker2112
POWER
Right now I have:
ATI Super Dampener
Next step:
380cc injectors
Tune with Adriancl
Good info here
Have you looked at the RMW shorty header w/CAT? A few years back when I was looking into building out my R50; Jan said that his headers with the CAT's are actually 50 state approved - that seems to have changed, at least as far as California is concerned. I think that they would pass Oregon's emissions tests; at least that is what he told me in 2018. The header and CAT seem to be reasonably priced.
http://store-revolutionmini-com.3dca...ting_p_94.html
Old Oct 14, 2021 | 06:48 AM
  #299
bump32's Avatar
bump32
Originally Posted by Tragesaurusrex
Nice progress!
I saw these injectors in your build thread last year and made note.... Adriancl confirmed they were the right way to go.
https://www.northamericanmotoring.co...thumbs-up.html
I have not looked at the RMW shorty header.... There have been mixed feelings regarding Jan here and I have some hesitation with purchasing anything from RMW.
I have put the Header on hold for now anyway. I received a tune from Adriancl last week and I'm going to put up some more details here shortly. (after I've driven the car a few more times)
My latest wild goose chase is an AF gauge that includes both wideband to monitor and narrowband for the ECU. I saw Mod Mini put one in his car in his blown engine series. I'm not up for re-wiring but I like the idea of both narrow and wide in one plug. (so I don't have to get another bung welded in my stock header). Going to research this a little more.
Shows the Innovate kit at 2:00 here.
UPDATE:
https://www.innovatemotorsports.com/products/lc2.php
I have no idea what any of this means but I did find the LC-1 and the LC-2 controllers on the Innovate website. $200 for just the LC-2 controller. Hmmmmmm
Old Oct 14, 2021 | 10:33 AM
  #300
bump32's Avatar
bump32
Pistons & Intake valves
Confession. I'm throwing these photos up for feedback, I really have no experience here and lots of questions.
While I had the IC and injectors out, I took a look down the holes.
Intake valves first:
Look pretty good to me????? But I really don't know what to look for.
Pistons next:
Soooo what is the gold/ orange colored stuff? Too much heat right at the valves? Is the build up around the edges of the pistons bad?
What am I looking at here and should I be concerned?
Thanks in advance.
