R50/53 Fubrication GP Spoiler Picture
Old Apr 7, 2016 | 11:11 AM
minihooligan773's Avatar
minihooligan773
Looking if anyone has a picture of the Fubrication GP Spoiler from under where the inside spoiler mounts to the 2 side posts. Trying to see if there is 2 wholes under or inside the middle spoiler where it mounts too. Thanks
Old Apr 7, 2016 | 12:17 PM
RB-MINI's Avatar
RB-MINI
The center spoiler section has two holes in each end for mounting to the uprights. The uprights have three holes so you can adjust the angle of the spoiler. The small fins covering the screws on the outside of the uprights are optional. You can see the unpainted screws in this pic. The small dust looking speck under the front screw is the third hole to change the angle.
Old Apr 7, 2016 | 01:31 PM
minihooligan773
Do you have a picture from the bottom?
Old Apr 7, 2016 | 02:09 PM
RB-MINI's Avatar
RB-MINI
I'll check, but it looks just like the top. The Fubrication wing doesn't mount like the Orranje wing from Europe. That wing has brackets that slide into the center section and fasten from underneath. The Fubrication has threaded inserts on the edges only.
Old Apr 7, 2016 | 04:30 PM
RB-MINI's Avatar
RB-MINI
I don't have a clear pic, but I found this on the web. It has several pics and I think this pic with the parts laid out shows the bottom of the wing.
Here's the link to the thread. It looks like the center section is actually mounted upside down in the after install pics.
http://www.newminisociety.com/forum/...TID=16622&PN=3
Old Apr 8, 2016 | 08:32 AM
Like that spoiler, looks great
Old Apr 8, 2016 | 09:59 AM
minihooligan773
Cause I found this but says for all GP style but mounts from bottom.
https://www.ebay.com/ulk/itm/231877280742
Mini Cooper JCW Carbon fibre GP Style Wing blade R50 R53 R56
Old Apr 8, 2016 | 12:04 PM
RB-MINI's Avatar
RB-MINI
You can probably modify it to work with the Fubrication, or just buy the Fubrication carbon version, but that blade won't work on a Fubrication as is, unless it also has threaded inserts in the ends, too.
There was a carbon fubrication for sale not too long ago for about $600 on the forum. They also did a short run last year on regular and carbon versions and have another run going on indiegogo. Try contacting Terry at Fubrication and find out if any extras were made or if they'll do the carbon version again for this run.
Old Jan 22, 2021 | 08:41 AM
bump32's Avatar
bump32
I'm going over my options for the Orranje GP wing/spoiler and it's my understanding that:
1) The S spoiler that I have is going to have to come off. ( two bolts and youtube videos )
2) I can get the non S spoiler from the r53 or r56---- OEM MINI spoiler to go with G-wing (non S spoiler #51622753757) I'm up for this route but it would involve paint and I almost like it better without a spoiler.
3) I can go without a spoiler but I'll need to cover the holes.
So I looked up fins on Amazon and they all suck. Way to big and ugly.
RB-MINI I found this picture... and I think it's yours? Any info on where you got the little fins???
Anything else I'm not thinking of?
More info on the Orranje G-wing here:
https://www.northamericanmotoring.co...ml#post3782833
Old Jan 22, 2021 | 09:11 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Those little fins were factory pieces and now they're NLA.
I sold a set of them here on NAM a few months back,
this is the part # and what they look like:
Old Jan 22, 2021 | 11:58 AM
RB-MINI's Avatar
RB-MINI
Yep, that’s my wing. As posted above, the small fins are the factory covers for the JCW wing and are NLA. A few other options you can go with are:
  • A factory spoiler that could work with a GP wing, the non-S spoiler and I think the aero spoiler also works.
  • A non-S hatch with no holes, or have your holes plugged and painted.
  • An aftermarket spoiler delete panel like the FUbrication. Unfortunately, that is also NLA.
  • Sticker type covers. Some are available from Orranje in the UK in black and white which are just round or oval rubberized domed decals.
  • 3D printed JCW replica fins or some similar design.
I thought a smaller spoiler covering the mounting holes extended the roofline too much and took away from the GP wing, so I went with the small JCW fins instead. A big issue with them is the foam tape provided for mounting is cut in a way that doesn’t actually seal the holes from water. You can see them in the pic above. I ended up sealing the holes with car vinyl first, then I put the fins on top of that.
Old Jan 22, 2021 | 07:15 PM
jacktown's Avatar
jacktown
Hi @bump32 to answer your question about anything you’re not thinking of. Quite a bit of clean up. Once you’ve removed the two bolts it takes some effort to get the spoiler off as its
stuck on with adhesive. I recently removed mine (detailed in my car’s thread) I didn’t have to paint for my project - but I wouldn’t fear paint in your case. If I was in your situation I’d fill the holes and paint the area that was previously covered by the S spoiler. It’s a perfect single panel for painting that doesn’t join up with other parts of the car - therefore easy to mask off and contain paint to that area.
You could use fishing wire to help remove the spoiler. Just have some goo-gone, handy!
It’ll clean up nicely with some effort. Just anticipate an hour or so of elbow grease.
Old Jan 25, 2021 | 10:34 AM
bump32's Avatar
bump32
Thanks for the extra info. Yeah I watched a YouTube video M7 put out for their wing instal. Guy used wire??? Probably scratched the paint. I'm going with fishing line for sure. I'm hoping my paint is in good shape. I still don't have a plan for the fins?????? hmmmm
I took a screenshot off the video so I can see where the adhesive is.
Old Aug 3, 2021 | 03:57 PM
bump32's Avatar
bump32
So I'm back on this project...
Some questions regarding the base (non sport spoiler). on an r53 with the Orange G-wing.
1) Does the base spoiler people are using with the G-wing block the rear brake light in the r53? Does it only work on the R56?
2) I found part numbers 51622753757 and 51622753756?. Is this the same part? One primed and the other painted?
3) Does it look like the picture on the back side or is this a different spoiler? If so I probably doesn't work on the r53?
Old Aug 4, 2021 | 03:01 PM
RB-MINI's Avatar
RB-MINI
I don’t think the spoiler pictured above will work on an R50 or R53 without a lot of modification. The 1st gen spoilers mount on top of the exterior body panel of the hatch while the R56 spoiler is the the exterior body panel that bolts to the hatch structure.
You can see what I mean in the 4th pic of this DIY article from Pelican: https://www.pelicanparts.com/techart...eplacement.htm
This post has info on a lower profile spoiler for the 1st gen if you don’t want to cover the holes with the factory JCW fins, G wing domed decals, or fill them by welding + bodywork: https://www.northamericanmotoring.co...king-info.html
Old Aug 9, 2021 | 07:06 AM
bump32's Avatar
bump32
RB-MINI. Thank you for the info, makes way more sense now. Somehow I got confused with the G-wing fitting the R56 also that the rear spoilers were also interchangeable.
Side note for those looking for a more cost effective wing. Orrange is making a G-wing Lite now.
https://orranje.co.uk/shop-by-brand/...g-lite-spoiler
mationato
Apr 14, 2020 12:46 PM
dosomething
Jul 3, 2014 06:58 PM
suntaepark
Oct 15, 2012 06:32 PM
BUIZILLA
GP Talk (2006)
Jan 4, 2008 04:56 PM
chows4us
Off-Topic :: Autos
25
Apr 13, 2006 12:32 PM
