R50/53 New owner picky questions
Old Sep 21, 2004 | 09:57 AM
JoeDentist's Avatar
JoeDentist
I have had the car for a few days at home, and have read my owner's manual, but have one or two little questions that you can probably answer.
1. I bought some driving light mounts, and the instructions say that in the MC/S you have to cut through the screen behind the grille to fit the brackets. The factory mount instructions even include templates to make the cuts in the right places. My car has nothing behind the grille - it will make it easier to install the brackets, but am I missing something I should have? Is the screen part of some exterior option like the aero kit?
2. What exactly does the "toolkit" represent in this car. The manual says that it should be in the compartment on the right hand side of the boot, but that is where the HK amp is located. There is a jack in a bag suspended between two brackets in the trunk. Is the "toolkit" just the jack in cars with run-flats. The manual talks about using allen wrenches when the sunroof stalls and other things. Are these not in the tool kit? Where is the tool to remove a tire? i.e. lug nut wrench, etc.?
3. The brackets in my trunk are purple - are these always the outside color of the car? I.E. are they white in a PW car? (Loops to hold netting I guess.)
Old Sep 21, 2004 | 10:08 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Congrats on your new MCS. I know #2 and #3.
1. The driving or rally lights usually mount behind the slat or aero grill of the bonnet. They mounts are from behind the grill on the inside of the bonnet as the lights are in front of the grill. If you have a stock MCS then the bonnet grill has slats.
2. The tool kit will vary from MC to MCS. For the MCS, the jack and lug wrench are in the long tool bag (marked part number 71.11-6 762 180-01) hooked to the left side of the boot floor. The black and red toolkit (marked part number 7111 1511643-03) has a small screwdriver (by Heyco), a fixed small wrench with 13mm and 10mm open ends, and a wire with ring on one end to pull your center cap off for some wheel models. It is inside the left wheel well access door. The HK amp is in the right access wheel well like you said.
3. Yes the loops in the rear boot are body colored. Mine are indi blue.
Old Sep 21, 2004 | 10:16 AM
dominicminicoopers's Avatar
dominicminicoopers
To answer #2.
They are located behind the panel on the left side of the boot, opposite sida as the HK Amp. You'll find a black pouch that holds smaller tools. The jack should be in the boot.
I'm also very interested to know why your MA did not show these locations to you upon taking delivery at the dealership...
Old Sep 21, 2004 | 10:38 AM
winechic's Avatar
winechic
I was wondering about the tool kit. I'm gonna go look in my boot.
nope, no tool kit. Should it be there? maybe they don't put it in the '05s.
Old Sep 21, 2004 | 12:06 PM
Jenn B's Avatar
Jenn B
I'm learning things from this thread
I know my MA told me all kinds of stuff but I was starry-eyed and kind of out of it
Old Sep 21, 2004 | 02:24 PM
JoeDentist's Avatar
JoeDentist
Whooops there it ain't.....
No tool kit in mine, either. Has it been deleted on 05's or something? Anybody with an 05 MC/S have a red and black toolkit in the left or right boot compartment?
Old Sep 21, 2004 | 04:03 PM
MotorMouth's Avatar
MotorMouth
woot!
My first post and I can answer a question.
The '05 MCS should have the tool kit on the left side of the boot in a pouch just like the '04's. It should be out in the open.
Old Sep 21, 2004 | 04:27 PM
C4's Avatar
C4
My '04 MCS has the toolkit pouch hidden inside the left boot trim panel. The right trim boot panel is reserved to access the Harmon Kardon DSP/Amplifier unit.
Old Sep 21, 2004 | 04:38 PM
JoeDentist's Avatar
JoeDentist
I have a pouch in the boot on the left side clipped to the floor, but all that is in it is the jack and the lug wrench. No more spanner and screwdriver and other tools?
Old Sep 21, 2004 | 04:41 PM
C4's Avatar
C4
Have you looked under the trunk mat panel? I know the battery is in there but they may have stuffed your tools in there.
I believe the tool kits are added to the car as they arrive to the VPC or when the dealer preps the car before delivery.
Call the dealer if you believe they forgot to put your tool kit.
Old Sep 21, 2004 | 04:45 PM
bmovierat's Avatar
bmovierat
The MAs at my dealership went over this in detail. The whole process of buying my MINI took nearly 3 hours. I was very impressed with how much time they spent with me (and on a saturday no less).
Anyway, I seem to remember them mentioning that various little details are different on the 05s compared to the 04s. The tool kit might be one of them. On mine, it is located in the battery compartment just lift the carpeting in the boot and it should fit snuggly in the inch or two of space around the battery. I'm sure the MC models are different, since their batteries are under the bonnet.
I included a pic so you know what you're looking for.
Old Sep 21, 2004 | 04:48 PM
C4's Avatar
C4
Yeah that's where my tool kit is in my '04 MCS!!!
In the '02 Cooper, the toolkit (And jack) is also located underneath the trunk mat panel. The spare tire is located underneath the car (Cooper model only).
Old Sep 21, 2004 | 05:55 PM
JoeDentist's Avatar
JoeDentist
OK - so its not where they said it was......
Well, even though the 05 manual does not make any mention of it, the tool kit is stuffed next to the battery at the back. Completely enclosed and unlabeled. Thanks guys. And thanks bmovierat!
Old Sep 21, 2004 | 06:07 PM
Zociac's Avatar
Zociac
If it isn't foir this thread I wouldn't know about the tool kit in the battery compartment. Though I am normally a fix it myself kind of guy I figure I would just call Mini Roadside Assistance.
What is the huge eyelet looking thing? It is not for lifting my Mini out of the ditch, is it?
Also what is the spare box in the battery compartment the battery cable goes into?
Old Sep 21, 2004 | 06:34 PM
lotsie's Avatar
lotsie
The eyelet is a tow hook to pull the car with.There is a towing point in the front and rear bumpers.Little 1/2 moon piece pulls off and a place to thread the hook is behind it.With our winters,I got another and leave them in for the winter months.Don't want to be installing it in the ditch,hopefully won't have to use them
Old Sep 21, 2004 | 07:11 PM
JoeDentist's Avatar
JoeDentist
Yeah, what is that box next to the battery. In my car it is orage and black. I bet its a battery cutoff if the car roills over or is an accident.
Old Sep 21, 2004 | 08:21 PM
Minirox's Avatar
Minirox
Yes its the blow pack. It disconnects all power in an accident.
Old Sep 21, 2004 | 10:33 PM
VRBeauty's Avatar
VRBeauty
Hey Joe:
Thanks for asking about the tool kit. I just went out and found mine... I'm not sure I've ever seen it before. But then, I've only had this car for -- oh -- about two years! Better late than never, I guess .
Getting late... time to brush
Old Sep 22, 2004 | 03:21 PM
PATHFNDR's Avatar
PATHFNDR
[QUOTE=Jenn B
I know my MA told me all kinds of stuff but I was starry-eyed and kind of out of it [/QUOTE]
OMG, that's too funny!!
Old Sep 22, 2004 | 05:12 PM
winechic's Avatar
winechic
Found mine too. thanks for asking Joe.
I really need to go to the dentist.
W0TM8
Dec 19, 2019 07:50 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
DiGiPiMP
Aug 24, 2015 11:04 AM
Overpolished
Detailing 101
15
Aug 21, 2015 07:19 PM
Terry J
Aug 11, 2015 09:39 AM
