R50/53 Cvaxle boot replacement
Old Jun 23, 2015 | 02:33 PM
mhopper49's Avatar
mhopper49
K so on my 05 mini s I have discovered I have a bad boot on my cv axle. I was reading about a boot replacement kit. Anyone ever used one or know if it is reliable?
Old Jun 23, 2015 | 02:48 PM
CV boots are here , you will have to pull the axle and then separate and replace and re-grease the boots. Its a bit of a job but do-able.
Here are the boots, the ones we carry are great and OEM to the manufacturer.
Note they are for the inner and out and for the manual and automatic transmission.
http://www.ecstuning.com/Mini-2005-Cooper-R52-S-Convertible-L4_1.6L_W11B16A/Drivetrain/Axles/2
more info on DIY
https://www.northamericanmotoring.co...placement.html
https://www.northamericanmotoring.co...-a-how-to.html
Old Jun 23, 2015 | 02:50 PM
mhopper49's Avatar
mhopper49
Do you happen to know what kind of grease is in the passenger side. I'm in a little bit of a pinch just need to get by till the kit gets here?
Old Jun 23, 2015 | 03:01 PM
Try to find the grease local if you can to get by.
MoS2 grease
Old Jun 23, 2015 | 03:02 PM
mhopper49's Avatar
mhopper49
Thank you, wi be ordering boot tomorrow!!!
Old Jun 23, 2015 | 03:03 PM
Old Jun 23, 2015 | 05:55 PM
Alkaidovich's Avatar
Alkaidovich
is this something major/serious... or can you drive on it for a little bit?
Old Jun 23, 2015 | 08:11 PM
David.R53's Avatar
David.R53
If you replace the boot soon (days or a few weeks) the joint inside should be ok and last a long time. Depends on how dusty the area you drive is. If you wait, dirt gets in there and destroys the joint. Once it starts making noise, it is ruined. Then you are in for replacing it - and quality axles are hundreds of dollars - not a good place to look for cost savings!
Old Jun 24, 2015 | 11:10 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you don't hear any clicking you are fine, but I wouldn't drive on it for too long. Check and see how much grease is there. Once the grease is all gone that is when the joint begins to click and you're no longer able to get away with only doing a reboot kit. If you have noise you can do a new OEM axle (don't go aftermarket) or find a place that does OEM rebuilds.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 24, 2015 | 09:46 PM
Alkaidovich
-Luccia
Going to most likely order the axle with boot already pre-fit from you guys... these come greased I'm assuming correct? Its slowly starting to get some noise so Id rather be safe than sorry... sucks this happened right after I just spent and got my intake, exhaust and coilovers just fitted lol
Old Jun 25, 2015 | 05:51 AM
Alkaidovich - If you order the full axles they come press greased and ready to go.
Old Jun 25, 2015 | 07:19 AM
Alkaidovich
Good to know.. Ill have to get one ordered this evening! Any way I can expedite the shipping? Ill need this soon.. I ordered a new shift **** and aux input kit from you guys but says it won't ship until july 2nd
Old Jun 25, 2015 | 07:25 AM
You can split the order, order the axle asap , then put in a second order for the other stuff. I will try to speed on my end the other stuff also.
If you have them on order all already , call in and talk to our sales and they should be able to split up the order for you.
Old Jun 25, 2015 | 07:34 AM
Alkaidovich
Already have them on order... and I'm not worried about when those come, just couldn't pass up that price on the JCW shift ****
I do worry though about ordering the axle... I am going to go ahead and place an order now... If theres anything you guys could do about getting it shipped out asap, I don't mind paying more for shipping (2-day, next day, whichever) or at least getting it shipped out this week.
Old Jun 25, 2015 | 07:36 AM
Alkaidovich
Also, what is the difference between the 2 axle replacements and OEM one (besides brand)?
http://www.ecstuning.com/Mini-2005-C...les/ES2652329/
http://www.ecstuning.com/Mini-2005-C...les/ES2009417/
Old Jun 25, 2015 | 07:39 AM
Yep, you are welcome.
If the axle, just select the the quickest shipping from the shipping box on checkout, there is usps , fedex, etc and they expedited shipping options. We will do our best to get it out asap. If in stock here ships out same day. We ship fast once its here. PM me the order # and I can send it over to sales.
Old Jun 25, 2015 | 07:41 AM
Alkaidovich
No worries, I see it can be shipped out tomorrow which will work out just fine... Now down to my last question, besides brand, is there any difference really between the axles you guys offer?
Old Jun 25, 2015 | 07:46 AM
Just the brands and cost. Those are manual transmission , passenger side.
Also on that side the big difference is the OEM MINI one has the bearing with the bracket to the engine. On the aftermarket you get the full bearing but not the bracket, you have to fit the bearing on the shaft into the OEM bracket off the old one.
Genuine MINI with bracket / bearing.
VS aftermarket
Old Jun 25, 2015 | 07:47 AM
Alkaidovich
Ok thanks for this, placing my order as we speak
Old Jun 25, 2015 | 07:36 PM
mhopper49's Avatar
mhopper49
Alk I replaced my driver side a few weeks ago, got one at a local parts places for around $100. From everything i have seen it is fine. And the insta isn't bad at all. There are plenty of walk throughs out there.
Old Jun 25, 2015 | 11:15 PM
batrugger's Avatar
batrugger
The axles you get from the chain parts stores will work and have a lifetime guarantee, but they are so cheaply made that you will be changing them almost yearly. If you want an axle that will last 100k miles, get an OEM one.
Old Jun 28, 2015 | 02:32 AM
minsanity's Avatar
minsanity
+1 on what batrugger said.
Old Jul 7, 2015 | 09:38 PM
Alkaidovich
So my axle came in a couple days ago along with my exhaust. Tried to do both but didn't manage due to timing. Exhaust put in, axle did not.
How long would you say it takes to replace this axle? Generally Im ok with working on cars - I am no pro, but me and my buddy got my coil overs done in about 7 hours (give or take with not all the proper tools) not ever knowing how to do those.
I have an appointment at my local mechanic to get it done, but its also gonna cost me $180 for labor... Hoping I can eliminate that by doing it myself but I have no problem dropping some dough if its gonna be a PITA for me to do it vs doing it right, especially since I leave for the track Saturday
Old Jul 8, 2015 | 04:55 AM
JABowders's Avatar
JABowders
Veteran: Army
Single axle should be about 2 to 3 hours (Right vs Left) if you have the tools handy and replacement nut.
Motor on!
Old Jul 10, 2015 | 06:02 AM
+1 about 2-3 hr.
woodstudio
Mar 15, 2020 08:28 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Chasp
Aug 22, 2015 01:27 PM
speedbird_1
Aug 15, 2015 04:44 PM
