R50/53 Oil Leak Question
Old Feb 8, 2014 | 12:24 PM
CosmicBlue15's Avatar
CosmicBlue15
Oil Leak Question
I have a 2006 MCS, 64,000 miles and in the year I have owned it I have not had any mechanical issues.
I have a large oil leak on my floor after the car sits for a week during bad weather. The oil dipstick shows nothing has decreased and is marked full. When I look at the engine from the top and as much of each side of the engine that i can see ... no oil leaks anywhere.
I have not tried to crawl under the car due to outside temps ... not motivated yet.
Still I am wondering where the oil is coming from? I am not a mechanic but can perform basic maintenance and have a car that I love driving.
Old Feb 8, 2014 | 12:30 PM
AndyPWR53's Avatar
AndyPWR53
Where is the leak coming from? passenger side? drivers side? the middle? Towards the back of the engine bay or towards the front?
Old Feb 8, 2014 | 04:37 PM
CosmicBlue15
Passenger side, in the front just off center.
Old Feb 8, 2014 | 05:15 PM
AndyPWR53's Avatar
AndyPWR53
I'd check the hydraulic motor mount first. They tend to leak a lot when they fail. Feel around for oil at the bottom where it contacts the frame.
Old Feb 8, 2014 | 07:58 PM
CosmicBlue15
Thanks for the picture and the possible problem.
Old Feb 9, 2014 | 10:48 AM
Eric_Rowland's Avatar
Eric_Rowland
Could be the Crank Position Sensor (CPS) - they often leak. There are several threads describing the fix. The motor mount fluid is much thicker than oil.
Old Feb 9, 2014 | 11:34 AM
ZippyNH's Avatar
ZippyNH
Check your PS fluid level....
When it gets old, it can change color....and look a bit like engine oil....
If it is low...DO NOT USE REGULAR PS FLUID/TRANNY OIL...it is a special fluid...[QUOTE]
Pentosin CHF 11s hydraulic oil for power steering on MINI and BMW cars. If your doing any steering system work on your MINI or BMW you'll need this fluid to refill the system.
http://www.waymotorworks.com/chf-11s...ing-fluid.html
Some info on it, and other cars that use it!!
CHF 11S (synthetic oil based)
Size: 1 liter (1.06 quarts), Part# 1405116
5 liters (1.32 US gallons), Part #1405216
20 liters (5.28 US gallons), Part #1405208
Color: Dark Green
CLICK HERE FOR CHF 11s SPEC SHEET
Audi (1990-2005); Spec. TL 52 146.00
BMW (1990 on; check owners manual)
Chrysler Crossfire
Dodge Sprinter (all years)
Jaguar (1990 on)
Land Rover (all years)
Mercedes-Benz (staggered models starting 1990 - check vehicle owners manual); Spec. 345.0
MINI (all years)
Porsche (1990-2005)
Rolls Royce
Saab (1990-2005)
Volkswagen (1990-2005) Spec. TL 52 146.00
Volvo (03/1998-2002)
Old Feb 9, 2014 | 02:28 PM
captainslow's Avatar
captainslow
Yup. One of my PS lines was leaking..
Old Feb 9, 2014 | 08:02 PM
CosmicBlue15
Thanks for the responses so far and the different possibilities. I need to find a heated garage to scope things out....otherwise the windchill temps are just too cold right now.
woodstudio
Mar 15, 2020 08:28 AM
ShadyCoop
Aug 24, 2015 06:05 AM
danraabe
Aug 18, 2015 09:32 AM
elightbo
Aug 17, 2015 01:50 PM
azntaiji
Aug 13, 2015 03:24 PM
