R50/53 Navi screen blank, what to check?
Old Dec 22, 2011 | 05:24 PM
atikovi's Avatar
atikovi
I bought this '04 and the navigation screen is blank, but the backlighting seems to be on. Nothing happens when I press or turn the **** and there is a nav disc in the drive. What could be the problem?
Old Dec 22, 2011 | 05:41 PM
JPMM's Avatar
JPMM
I have read that a battery that is low or is faulty will cause problems
Old Dec 22, 2011 | 05:55 PM
atikovi's Avatar
atikovi
Well, the car has been sitting a few weeks and I did have to jump start it but once it's running the battery voltage is normal so it shouldn't be a problem then.
Old Dec 22, 2011 | 06:45 PM
rkw's Avatar
rkw
If the Nav isn't receiving full voltage while it is starting up, it can go into a state that it won't recover from (even if the voltage rises to normal levels later). Check the condition of the battery.
Old Dec 23, 2011 | 04:39 AM
atikovi's Avatar
atikovi
OK I'll put a charger on the battery for an hour and then try it.
Old Dec 23, 2011 | 10:04 PM
Eric_Rowland's Avatar
Eric_Rowland
Do you hear the Nav unit spinning up? It's usually pretty audible.
Old Dec 24, 2011 | 05:11 AM
atikovi's Avatar
atikovi
So is the exhaust so I can't tell. The red light on the DVD unit works.
Old Jan 16, 2012 | 06:14 PM
Leviathant's Avatar
Leviathant
If you turn on accessories but not the engine, the nav unit will spin up without all that obstructing engine noise covering up the sound. It will spin up, and then you should be able to hear the head in the drive moving back and forth while it reads the initial map data.
rob&JCW
Feb 13, 2023 07:03 PM
kevinminict
Jun 3, 2016 01:31 PM
cawwwtun
May 3, 2016 08:03 AM
Alkaidovich
Aug 10, 2015 08:20 AM
nismo4life
Aug 5, 2015 08:31 AM
