R50/53 A few total NOOB questions
Old May 14, 2010 | 02:39 PM
Cavalier Cooper's Avatar
Cavalier Cooper
Hey guys, my car didn't come with a manual. I tried searching for the answers to these questions, but I didn't find any.
1. how the heck do I turn the high beams on
2. What is the circular button on the other side of the hazards on top of the speedo that has a picture on it that looks like the speedo?
3. How do I adjust the intensity of the interior lights
4. Where can I download a manual
2004 R53. Thanks!
Old May 14, 2010 | 02:45 PM
GreenR53's Avatar
GreenR53
2004 R53. Thanks!
1. Pull back on the left arm behind the steering wheel
2. See question #3
3. Push this button and hold it down or push it a couple times this either brightens or dims the interior instrument lights.
4. I have no clue try to see if you can buy one at the dealer??
Old May 14, 2010 | 02:46 PM
LittleJoe's Avatar
LittleJoe
Welcome!
A couple of answers:
1. Pull the left stick on the steering wheel toward you for high beams
2. I think that button makes the interior dashboard lights go dimmer and brighter. Push it several times to go one way, push and hold to go the other way
3. See #2
4. Not sure.
Good luck!
Old May 14, 2010 | 02:47 PM
MDL8440's Avatar
MDL8440
Motoringfile has everything you need. Also try searching around here as people have posted .pdf files before.
Old May 14, 2010 | 02:50 PM
Cavalier Cooper
Pulling back on the stock only flashes the highs, it doesn't keep them on.
Old May 14, 2010 | 03:12 PM
ALTA_JOHNL's Avatar
ALTA_JOHNL
Twist the stalk forward to turn on headlights, then pull pack on entire stalk for high beams.
Old May 14, 2010 | 08:39 PM
KennyR's Avatar
KennyR
Try PUSHING the turn signal stalk forward to keep high beams on; pulling back only temporarily flashes the high beams for the R56, 57 models; while you indicated yours is R53, did you try this?
Old May 14, 2010 | 10:37 PM
Mello_Yellow's Avatar
Mello_Yellow
On my Mini, if you pull back until it clicks, the high beams will stay on. This kinda confused me at first as well.
Interesting to know what that odometer looking button was. I figured it couldn't have anything to do with the odometer as when I figured out how to reset the computer after an oil change it was never used. I'll have to try it out next time I'm in the Mini.
Old May 14, 2010 | 10:57 PM
minirooferS's Avatar
minirooferS
I lol'd here. Number 2 answers number 3
Old May 15, 2010 | 07:16 AM
klricks's Avatar
klricks
For a PDF manual - Register on Owners Lounge.
https://ol.miniusa.com/
You must have your VIN # to register. Must be U.S. market MINI.
Go to [Your MINI] menu.
For the high beam - Did you try pushing the stick forward toward the dash?
That's how my '10 Clubman works.
Old May 15, 2010 | 02:13 PM
Cavalier Cooper
Alright I'm just a moron wit the lights. I have no idea why I couldn't figure out the high beams the first night (to make myself feel better my sister had issues with it as well).
Thanks for the link to the online manuals Klricks, I'll register and get them there.
I think I have all the rest of the buttons figured out. Although, it appears sometimes the passenger window is one touch down, othertimes, it's not.
Old May 15, 2010 | 05:02 PM
jgohlke's Avatar
jgohlke
Both the windows should be one-touch. They are also controllable, you can stop them anywhere. The car knows what you want by how long you hold the button. Sometimes just a moment to long on the button makes the car think you want to have full control. Sometimes too quick of a jab at the switch, puts the window all the way up or down, when you really just wanted to move it an inch or two. It takes a bit of getting used to....
Old May 15, 2010 | 06:38 PM
ACEkraut11's Avatar
ACEkraut11
If you want an original hard copy of the owners manual then do a search on ebaymotors.com. They show up there quite frequently. I had the same problem and bought a replacement on ebay.
Old May 15, 2010 | 10:20 PM
klricks's Avatar
klricks
I made a 500 mile trip yesterday and had to figure out the high beam as well. Have had my MINI for over 3 months.
I think they only have the owners manuals on-line. None of the supplemental manuals.
For one touch up or down it must be a quick toggle. 1/2 second or maybe less. Note that no windows including sunroof will move if any door is open.
Old May 16, 2010 | 10:36 AM
minigma's Avatar
minigma
Google for owners manual I found it in a Pdf download no charge.
Colt45Magnus
Aug 27, 2024 05:03 AM
Manny_cooper
Sep 3, 2015 05:48 AM
desant89
R55 :: Clubman Talk (2008+)
Sep 2, 2015 11:24 AM
broncobuddha
Sep 1, 2015 06:32 PM
Drumsound
Aug 25, 2015 05:22 AM
