R50/53 Headlights shoot to low, even on bright...
Old Aug 3, 2008 | 04:02 PM
rynegold's Avatar
rynegold
error/15690
Old Aug 3, 2008 | 04:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
There are adjustment screws on the light housing. I forget where on the housing they are, but you will find them. You'll have to get at them with the hood open. It will move the entire assembly, high and low beams.
Old Aug 3, 2008 | 04:50 PM
rynegold's Avatar
rynegold
error/15690
Old Aug 3, 2008 | 07:52 PM
rrcaniglia's Avatar
rrcaniglia
Me too. Same problem. If the lows were a few inches higher, they'd be OK.
Old Aug 4, 2008 | 03:34 PM
dougc's Avatar
dougc
Similar problem here--low beams seem ok; high beams seem more like driving/fog lights. I have always felt the bright should light up the night. Please let me know how to adjust the lights when you figure it out.
Old Aug 4, 2008 | 04:56 PM
rrcaniglia's Avatar
rrcaniglia
This seems opposite my problem. My brights are great. Wish the low beams illuminated like them. I can't imagine how the highs can act like fog lights while the low beams are OK.
My goal is to get the light horizon of the low beams to go out farther. They're plenty bright, but they curtain off too close.
Old Aug 6, 2008 | 07:10 PM
dougc's Avatar
dougc
They light up the road immediately in front of the car and do little futher out--I can't understand it either. At first I thought high beams could be adjusted independent from the low beams. Maybe I'll just adjust the lights up and see (no pun) what that gets me.
Old Aug 6, 2008 | 08:08 PM
rrcaniglia's Avatar
rrcaniglia
I did a quick scan of the light housing under the bonnet. Didn't immediately see the adjusting screws. Does anyone have a pic?
Old Aug 7, 2008 | 10:36 AM
J Marshall's Avatar
J Marshall
If you have the Xenon's then they are self-leveling and adjust themselves with speed, the faster you go the more they rise up.
Old Aug 7, 2008 | 10:57 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Uh, no, I don't think this is true. They DO self level to accomodate vehicle loading (if you have back seat passengers, it adjusts them down, otherwise they'd be too high). It does this using suspension sensors.
Sorry, couldn't find the pics... but here's another thread with more details:
https://www.northamericanmotoring.co...ad.php?t=77164
Old Aug 7, 2008 | 04:08 PM
rrcaniglia's Avatar
rrcaniglia
Right. Then, let's say I want to calibrate them.
Old Aug 8, 2008 | 08:16 AM
DixonL2's Avatar
DixonL2
Nicely stated, "calibrate". On my '06 MCS with xenons, the adjusting screws are actually bolts with hex shapes and flat-blade screw ends, on the back top right and left of the headlight housing. The cutoff is really sharp, be careful you're not blinding oncoming drivers.
Side comment: A set of fogs is nice because it gives a bit more beam scatter, which can light up the reflective signs etc. a little better (insert smart comments about running with fogs on all the time here). I find the xenons do blind the folks I'm passing a bit, due to the higher beam on the passenger side, but no problems from oncoming traffic.
Here ya go, pic of adjusting screws:
Old Aug 8, 2008 | 03:52 PM
rrcaniglia's Avatar
rrcaniglia
DixonL2, thanks for the pic. I'll be looking at my 08 to see if I can find the same set-up.
As to blinding oncoming traffic, my wife says if I touch the lamps, she wants to test them by driving towards me on our street. If I have gone too far, she won't let me out of the neighborhood. So much for using the garage door at 25'.
Old Aug 8, 2008 | 09:09 PM
DixonL2's Avatar
DixonL2
You have a great wife for helping out like that!
Old Aug 9, 2008 | 04:38 PM
rrcaniglia's Avatar
rrcaniglia
Yeah. She is very motherly, and that includes the whole world.
Old Aug 11, 2008 | 04:26 PM
PenelopeG3's Avatar
PenelopeG3
So, which screw does what? I tried one but it didn't seem to do anything. Before I go wasting any more time, I figured I'd ask.
Thanks.
Old Aug 11, 2008 | 04:50 PM
BlimeyCabrio
Pretty sure the inner screws are height, the outer screws are left-right adjustment (leave those alone).
Old Aug 11, 2008 | 07:50 PM
DixonL2's Avatar
DixonL2
Park on a level surface facing a wall, measure on the wall (use a yardstick), turn screw 2 full turns, measure again. Be sure the measurement to the top of the cutoff is lower than the middle of the projector beam lens - I think there are measurements on www.rallylights.com. Adjusting Mini headlights isn't fun and can be blinding... sorry!
potterstein
Dec 30, 2024 05:18 PM
molala
Oct 2, 2015 01:53 PM
tylewis
Sep 6, 2015 01:07 PM
potterstein
Sep 4, 2015 09:52 AM
Ntety
Sep 2, 2015 08:39 PM
