R50/53 Mounting the Scanguage II
I'm thinking of buying a Scanguage II but I'm in a quandry as to where to mount it. If anyone has a solution I would really like to see a picture of your mounting solution.
Frank
Frank
Here's my writeup with pics.
I love this spot. Easy to see, easy to reach, out of the way, easy to wire, no obtrusive cables, mostly hidden from the outside by my inspection sticker. I put a piece of black-out tape over the port on the end, which makes it look even better.
Nice, Blimey! I may have to do that.
No pics, but currently I have mine just laying in front of the OEM gauge bundle between the downtubes. Have to take out the lighter for it to fit, but it's stable, and low enough that I can still see the oil temp needle (I don't bother with the voltmeter
, though that shows, too)
edit: Blimey you should give some love to Way Motor Works in your writeup (he'll sell to NAM for $150 shipped, matching another 'group buy')
, though that shows, too)edit: Blimey you should give some love to Way Motor Works in your writeup (he'll sell to NAM for $150 shipped, matching another 'group buy')
Just edited my post to mention that - thanks!
That's where mine is - note that if you're really lazy, you can just lay it there (lighter removed) and wedge the wire behind the gauges (if so equipped.)
It reports actual MAP (Manifold Absolute Pressure), and it calculates theoretical HP based on various engine parameters. You can program it to calculate approximate boost by subtracting a constant for your local atmospheric pressure. Read my blog post and you'll learn more.
But there are LOTS of other things to know about your car (in fact, things you can actually use and do something with), other than boost and HP...
Really though, no. You're not CHANGING anything in the car, you're just listening to what it has to say.
I've got my Speedo, Tach, Air Fuel, Oil Pressure and Oil temp gauges all mounted directly ahead. It's nice to be able to glance to the right a bit and see that, but not have it right in front of me. I'll take a picture when i can.
Even if they did they wouldn't have a way to tell. The OBDII port is for diagnostics, and tracks quite a bit of information. There's no reason why they'd care if you plugged into it.
I like the way Miniac has it the best. I have my navi mounted there though. I have mine mounted like Blimey. It's ok, but I may move it to the center of the dash. There are two downfalls with the dash mount. One is that it can be seen from outside the car. The other is that it is slightly crooked. I may move it to the center. It would be hidden from outside view by the wipers and be more consistent with the rest of the car. If you have nothing under the radio I would suggest mounting it there, it's the most stealthy. The downfall is that you have to look down to see the readouts. It really depends on what you use it for I guess.
I have mine set for speed and I'm going to add boost. Those two I want to see as a heads up. The other two readings are intake temp and water temp. I just need to check those occasionally.
As a side note...the orange color does match well with the rest of the lights.
Scangauge far left - Navi under the radio
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
Sep 4, 2015 02:34 PM
