R50/53 Solution for dummy temp guage???
Old Jun 6, 2007 | 09:14 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Took Schultze in for some warranty work:
1. Temp guage is stuck in the middle and NEVER moves...not even after parking the car overnight.
2. Engine bay was extremely hot--bonnet was very hot to the touch--parked it at 3:30pm in the shade and the engine bay didn't cool down until 8pm or so.
3. Dealer checked thermostat, sensors, etc. and said that the guage is frozen (a "common" occurence).
So...I need some recs on where to get an actual temp guage, oil pressure guage, etc.
Thanks!
Old Jun 6, 2007 | 09:25 AM
chuckt's Avatar
chuckt
Try eBay, AutoMeter, Ultra-Lite series.
Old Jun 6, 2007 | 09:26 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Thanks!
If you went in for warrenty work, make the dealer fix it. Your under warranty, use it
Old Jun 6, 2007 | 09:53 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Dealer said everything was working fine...that the "stuck needle" is a common occurance and doesn't require replacing the guage.
The field rep is going to be taking a look at my car on the 13th...not just for the temp issue, but other issues as well.
Old Jun 6, 2007 | 10:12 AM
rc'S's Avatar
rc'S
I sure want to know how this comes out. Please tell us what CF does. The couple a few doors up from me hates them for their service issues so I would like to know what happens. (I didn't do this double post, the puter did it)
rc'S's Avatar
rc'S
Old Jun 6, 2007 | 10:46 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Whether the gauge is broken or not, the needle isn't working correctly, therefore it should be replaced. Fight this one, if that dealer says no, take it to another dealer.
Old Jun 6, 2007 | 10:51 AM
Loony2N's Avatar
Loony2N
The fact that something is "common" - i.e., a defect, doesn't mean it is okay. A temp gauge is supposed to show temp. If it don't, it's broken. Make them replace it. That would be like an insurance company refusing a claim becuase it's common for a car to get denting in a wreck.
Old Jun 6, 2007 | 04:38 PM
Capt_bj's Avatar
Capt_bj
different subject line....
Maybe the problem is that you need to regroup.....
the subject line might be: why does MINI-USA refuse to fix XXX despite my being under warranty? And..... Why I gave a ZERO on the service feedback survey.....
Can't hurt .... your current path doesn't seem to be going anywhere.
Old Jun 6, 2007 | 05:51 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks!
The temp gauge needle should fall to rest after turning off the key. I would have it fixed by a dealer, or you can try a cluster reset by the procedure on MINI2 that claims to be a ECU reset.
I also would like to know how they "checked" the thermostat. They must have x-ray vision to look through the housing to see if it's opening or not.
Is the extremely hot engine bay and bonnet an issue you just noticed? Did it cool down quicker before? My car used to bake for a while before I removed the hood insulation and installed hood vents.
Old Jun 7, 2007 | 03:32 PM
ASC's Avatar
ASC
Just a suggestion, but for a replacement gauge for your temp along with a whole slew of other metrics, how about the Scangauge?
http://www.scangauge.com/
I have the "older" and "clunkier" version of it, but it works great! It'll actually give you the temp in degrees or celsius depending on how you set it up. It won't affect your ECU, although it does run off the OBD port.
One of the most valuable features is its ability to read OBD trouble codes - AND reset them!
- Al
PsychoRallye
21
Feb 17, 2019 06:08 AM
rikaro
Nov 24, 2015 02:05 PM
navybsn
Oct 4, 2015 03:27 PM
Suspension Products
Oct 1, 2015 11:53 AM
