Navigation & Audio Is it possible to mirror iPhone display to mini connected?
Old Feb 9, 2014 | 07:35 AM
  #201
fatihv's Avatar
fatihv
I start it with 800x600 or some 720hd numbers, when it doesn't mirror; I go in to the settings and change it the another lower or upper resolution. It is not important which one you choose, just change the choice. Then it mirrors again.
Old Feb 9, 2014 | 10:57 AM
  #202
bratling's Avatar
bratling
Super Moderator
Originally Posted by mbabischkin
f you knew or understood just why Apple shifted from the 30Pin to the Lightning connection you wouldn't find it so amazing. The move had nothing to do with functionality...
Actually, it did. When the 30-pin adapter was introduced in 2003, it had pins for everything and more in reserve for future use. Within five years, all the pins were used and to add functionality such as HD video output Apple was hacking its own pinout, using first resistors to change voltages as a way of signaling that certain pins should be treated differently, and implementing hacks to the USB protocol to modify data connections.
It's been clear for years that the 30-pin adapter was no longer sufficient for all the uses people have found for iPhones, iPods and iPads. The lightning connector is an all-digital re-programmable connector intended to address those problems. It has been a painful transition for those of us with lots of older equipment—I have docks, several iPod speakers, chargers, VGA/HDMI/component video cables, SD card readers, and our cars which depend on the older 30-pin connector—but it had to happen sooner or later.
And interestingly, with AirPlay for audio and video and cameras that do their own photo uploads, I don't need most of those anymore! My MINI is virtually the only place I need an adapter now. Everything else is wireless and far more flexible than a wired setup.
YMMV.
Old Feb 14, 2014 | 12:18 PM
  #203
pidge1114's Avatar
pidge1114
So I gave up trying to get a working solution for my Iphone 5. Either way too much trouble or too expensive to get around streaming video from it.
I wound up picking up an old Ipod Touch on Ebay for $50 and the damn thing works great now. I still can have my iPhone connected via bluetooth for calls or navigation updates.
Old Feb 20, 2014 | 11:06 AM
  #204
yetilicious's Avatar
yetilicious
I was finally able to get it to work by renaming the Ipodout.app file, but now when I when ever I touch the screen a white dot shows up only on the Mini screen. Sometimes only one but I've had up to six once and they won't go away unless I toggle Displayout off/on.
Anybody else seen these and know a way to get rid of them?
Old Feb 20, 2014 | 11:23 AM
  #205
TXNemo's Avatar
TXNemo
I think its a setting under DisplayOut called show taps. Toggle that to "never".
Old Feb 20, 2014 | 09:24 PM
  #206
yetilicious
Originally Posted by TXNemo
I think it's a setting under DisplayOut called show taps. Toggle that to "never".
That did the trick. Thanks a million.
Old Mar 3, 2014 | 07:04 PM
  #207
Ricardo Mares's Avatar
Ricardo Mares
Exclamation Dots, video sharp, carplay
Hi Friends
I`m from Lima-PERU (sorry my english) and just succeded
making an iP4 works with my R56 with iOS7, but have 3 questions, maybe you can help me:
1. I have several white dots on screen, I try disable Displayout but nothing, they still there.
2. The resolution in Displayout is set in HD 1080 (not sharp) but I wonder if the iP4S have better video signal than iP4 or is the same and its because the analog signal.
3. I see the Apple Carplay news and read about it comes with the new iOS7 update, I wonder if this feature override Displayout like iPodOut app and maybe have to rename it or something like that. Or maybe its a better interface to display in Mini Connected, but seems to work only in Lightning devices.
Thanks to all
Old Mar 4, 2014 | 05:30 AM
  #208
yetilicious
Originally Posted by Ricardo Mares
Hi Friends
Thanks to all
Hello Ricardo, in the DisplayOut settings did you turn off "Show Taps"
After I did that and restarted my phone the dots went away.
Old Mar 4, 2014 | 05:47 AM
  #209
Ricardo Mares
Thks!
I will tried turning off the Taps but around 8 older taps still remains on the screen, I will try restarting the phone.
About the resolution the iP4 and iP4S have the same quality?
the iP4 looks a little blur, I suppose its because analog but I want to confirm, thks!
Have you see the Carplay?
Old Mar 4, 2014 | 08:47 AM
  #210
yetilicious
I'm using a deactivated 3gS only as a iPod only in the car and for me the video is not the best but I was not expecting cinema quality, just something to make the drive from work to home easier.
Let me know if you get it worked out.
James
Old Mar 4, 2014 | 10:10 AM
  #211
pidge1114's Avatar
pidge1114
EXCELLENT!!!
Old Mar 4, 2014 | 12:02 PM
  #212
Ricardo Mares
I´m not looking for a digital quality but have an iPod Nano (sixth gen) and the artworks of the songs displays better than an older iPod Classic 160gb.
I don´t test the quality of iP4S maybe have better quality because its the last device with 30pin connector.
How you hold your iPhone? have the dock extension?
Bad news Carplay only works with lightning devices because its a better interface
thanks!
Old Mar 5, 2014 | 02:48 PM
  #213
mbabischkin's Avatar
mbabischkin
CarPlay will probably NEVER come to the current generation of MINIs... Supporting it would require a pretty major update to MINI Connected, and that's assuming that the current generation of the system is technically capable of supporting it...
Old Mar 5, 2014 | 04:00 PM
  #214
rkw's Avatar
rkw
Fixed it for you...
CarPlay will NEVER come to the current generation of MINIs
It will be a complete system replacement, just like MINI Connected was a new system introduced in 2011 and cannot be retrofitted to 2010 and earlier electronics. CarPlay won't be on MINI until they refresh the F56 electronics. Watch for adoption on BMW (which hasn't announced anything yet about dates or car models), and if history is any indication, expect MINI to lag another year or two behind BMW.
Old Mar 5, 2014 | 04:03 PM
  #215
Ricardo Mares
I know that, but I thought use the same plugin way, instead the springboard or the iPodout, show the Carplay interface. But only works with Lightning devices and their only output through Airplay. Thks
Old Mar 5, 2014 | 05:38 PM
  #216
pidge1114's Avatar
pidge1114
Carplay uses a touch UI, which the MINI don't have...
Old Mar 6, 2014 | 05:01 PM
  #217
ibla13's Avatar
ibla13
plugin mini connected r56 helpp i'm desperate!!=(
hello guys I'm new to all let me introduce myself my name is alberto and Italian. I wonder why I signed up here? because I see that you are much more talented than us Italian. let's go have a mini john cooper works r56 year 2011 mini connected, usb and av-in, bluetooth, steering wheel controls, hands-free. I have an iphone 4. Mini connected it works well. all ok. But I connected the mini screen shows "plugin" Why? I not mount the module interface ipod connection in the glove compartment? I find it strange.
please help me I'm desperate!! = (
I do not own the voice plugin = (why?
Old Mar 7, 2014 | 05:06 AM
  #218
yetilicious
thanks!
I'm curious if my girlfriend's 4S will display a better picture too. I'll have to check one day.
Right now the iPhone lays on the passenger seat at an angle to keep the screen in landscape mode. I just bought one of these cd slot mounted cell phone holders on eBay. I will have to make some extention cable to reach it too.
I did find out the tension **** hits our volume **** so I will have to modify the mount to make it fit better.
Old Mar 9, 2014 | 09:40 AM
  #219
Ricardo Mares
Hi, anyone have you tested the Kivic One to airplay Iphone 5 to Mini Connected?
one of these links seems to need an extra interface like Audison Bitone or similar to get RCA video input but I wonder if it works with the Mini 3.5mm input in dash, because comes with an 3.5mm a/v input/output cable in the box.
They say that Mini Coopers in Korea comes with HDMI input. : /
https://www.facebook.com/media/set/?...6526659&type=1
https://www.facebook.com/kivicone/po...?stream_ref=10
Old Mar 11, 2014 | 11:14 AM
  #220
dharvey1221's Avatar
dharvey1221
Actually it works with or without touch. Carplay has the mappings for input controls. I don't see why BMW or a hack couldn't use the plugin function of the iPod display. I get thunderbolt is digital and it doesn't carry analog video but it does plug in USB. You would think there would be a way. Digital to analog converter. Something.
I think it truly depends on how apple is triggering the Carplay. If its using Airplay maybe something like the kivic one could be the in-between device.
To bad there is no a thunderbolt to 30pin with video adapter.
Old Mar 11, 2014 | 11:39 AM
  #221
wkearney99's Avatar
wkearney99
I'd venture Apple will have nothing to do with the retrofit market for their unshipped solution. It's a morass, best left to 3rd parties and Apple's not shown a lot of support for anything other than trivial add-ons from that market.
Did the Kivic ever actually ship?
Old Mar 11, 2014 | 12:05 PM
  #222
dharvey1221
The Kivic shipped if you ordered directly from them in South Korea. I originally thought they had a plugin for the mini, but I think you need another adaptor to plug into the display. They have screenshots of it mirroring on a mini but no clear instructions on how they did it.
Old Mar 11, 2014 | 05:21 PM
  #223
Ricardo Mares
I wrote to KIVIC fanpage and they didnt know about connect through 3.5mm plug cable that they ship in the box, the pictures they show airplaying an iPhone 5 in Mini Connected screen was on korean Mini Cooper which comes with HDMI input.
When iOS 7.01 jailbreak will release, we can try to plugin with an iPhone4S if that system runs on it.
Old Mar 18, 2014 | 12:33 PM
  #224
Ricardo Mares
the right cable (miniplug with 4 divisions) should work with Mini Connected input, and Airplay with iPhone 5
http://kivic-one.com/kivic-one/board...=0&id=29927827
Old May 18, 2014 | 10:59 PM
  #225
mrgentleminh's Avatar
mrgentleminh
So I guess this doesn't work for an iPod 4th gen eh? I can only hear the audio.. Can't see any video in plugin or the external devices. Whoomp womp... Any help?
