Navigation & Audio Is it possible to mirror iPhone display to mini connected?
Old Mar 31, 2015 | 06:13 PM
  #251
Agito's Avatar
Agito
Video and iPhone 4s
Here's a little more information it cost about $125 but you can program so many more things than just video in motion . video audio, lights, annoying seatbelt sound, it's just an amazing feature . you should check into it thank you
Originally Posted by Agito
Okay I have the secret to getting if iPhone 4s with the cradle to show video in your car even while moving go on a website called codemycar @gmail. Com...it's run by a gentleman called Okee .. okay
Old Apr 1, 2015 | 12:57 AM
  #252
Sherry87's Avatar
Sherry87
Thanx for reply agito👍 but i dont understand what you mean.
I was on the website codemycar but there is no explanation.
Should i email them?
Old Apr 1, 2015 | 07:55 AM
  #253
Sherry87's Avatar
Sherry87
Does it have to be a certain mini software??
I've tried everything but it just does not work.
I always get a black screen and few seconds later, the plugin is thrown out.
and what about displayout on ios 7.1.2?? its not working..
pls help
Old Apr 1, 2015 | 03:15 PM
  #254
Agito's Avatar
Agito
Mini connected and iPhone 4s
Go ahead and update everything to the latest version of iOS 8... something also go to the mini dealership and update software Also make sure that I phone is not jailbroken and reset to normal settings I do not use any part of the mini connected I run it directly through the cradle in the armrest also make sure your patient sometimes it takes up to five minutes for it to connect it'll show a black screen but eventually it will come onQUOTE=Sherry87;4063864]Does it have to be a certain mini software??
pls help[/QUOTE]
Old Apr 2, 2015 | 07:42 AM
  #255
Sherry87's Avatar
Sherry87
I think you dont understand me. I want to mirror my iphone to the connected screen. I saw in this thread some posts that is possible to do this but i dont know why this is not working in my car
Old Apr 2, 2015 | 02:49 PM
  #256
Agito's Avatar
Agito
I do understand but it's a pain because you have to jailbreak the phone I jailbroke my phone tried all the apps it never worked for me. The only thing that works for me is exactly what I described earlier but anyway good luck
Old Apr 2, 2015 | 05:02 PM
  #257
wickywack's Avatar
wickywack
Hello guys,
I need some help. The mirroring is not working in my paceman (r61).
I have downgraded and jailbroken my iphone 4 to ios 6.1.2 and i have the y-cable with the number (2 179 623-01) on the triangle.
The version of the mini software is MX-003.004.031.
I downloaded all tweaks from cydia but its not working. I even renamed ipodout with iFile..
Can anyone tell me what the problem is?
I'm from germany so sorry for my english
Did you try downgrading cydia mobilesubstrate as I described a few posts ago?
Old Apr 3, 2015 | 02:25 AM
  #258
Sherry87's Avatar
Sherry87
No i dont. Can describe it again?? Thnk you
Old Apr 15, 2015 | 06:07 PM
  #259
s0ph34k's Avatar
s0ph34k
mirroring and video in motion off my itouch
Attached Thumbnails Is it possible to mirror iPhone display to mini connected?-4149433188524978717.jpg   Is it possible to mirror iPhone display to mini connected?-img_20121024_112828.jpg
Old May 30, 2015 | 10:21 AM
  #260
Mofakhoury's Avatar
Mofakhoury
Failure!
I did exactly the same as described, yet, it works 1 out of ten times. Most of the times it gives black screen with iPod launched automatically even though I changed its name! Any clue?
Old May 31, 2015 | 04:36 AM
  #261
Agito's Avatar
Agito
Several things I did that helped I went to the mini dealership and had them upload the newest version for my mini connect system also what really helped me was when that would happen I would turn my iPod off and then reboot it I am running iOS 8.2
Old May 31, 2015 | 04:39 AM
  #262
Agito's Avatar
Agito
Also I spoke incorrectly I am not using an iPod I'm using an iPhone that is not connected to any server I only use it for music and videos in the mini connect armrest. Also I spoke incorrectly I am not using an iPod I'm using an iPhone that is not connected to any server I only use it for music and videos in the mini connect armrest
Old May 31, 2015 | 04:40 AM
  #263
Agito's Avatar
Agito
And the most important thing do not run it under Mini connect run it under USB out when you connect .. Other wise it will never work...at least it never does for me
Old Jun 1, 2015 | 04:29 AM
  #264
Mofakhoury's Avatar
Mofakhoury
Originally Posted by wickywack
Just an update. It looks like a recent cydia mobilesubstrate update broke displayout. I was not able to get it to mirror again until I downgraded back to this:
http://apt.saurik.com/debs/mobilesub...honeos-arm.deb
You can download on the iphone via safari and install via ifile.
I downgraded the mobilesubstrate as wickywack said and it worked like charm, thank you wickywack
Old Jun 22, 2015 | 01:16 AM
  #265
alpalpha's Avatar
alpalpha
Hello!
I am trying to pretend to "play a video" and then use another video cable, not the one from the Iphone.
I tested with a backup camera using this setup:
But the result is this:
What can be the reason?
Maybe the display thinks the resolution coming in is same as the video from the iphone? So it has problems showing it?
Camera is: 628 x 582 PAL Signal System (I live in Sweden.)
Thank you very much for support!!
Take care friends.
Old Jun 23, 2015 | 01:38 PM
  #266
Bossworld's Avatar
Bossworld
Thanks to everyone who's contributed on this thread, I've picked up a cheap-ish Y cable and was given a hand-me-down 8GB iPhone 4. I've installed all the bits, I've been able to get display mirroring working reasonably well via the Plugin menu.
I'd love to get the full screen working (presumably via External Devices) but haven't had any luck with this yet.
Only other thing I've noticed (my main phone is an iPhone 5) is that the iP5 seems to support other apps being open when Mini Connected is open, whereas the iP4 drops the Mini Connected menu if the Mini Connected app isn't the current app (if that makes sense).
Also, is there any way to fix the audio delay when watching videos?
Dec 23, 2015 10:36 AM
tippin
Aug 5, 2015 08:43 AM
