Navigation & Audio Shark Fin with a 2005?
Old Mar 5, 2006 | 03:07 PM
Peepers's Avatar
Peepers
Hey guys,
My 2005 MCS (equiped with H/K radio and Navigation) has the long (VW style) antena. I did some searches and found out the 2005 models are not offered with the shark fin style antena. Is there anyway I can put one on?
Peepers
Old Mar 5, 2006 | 03:46 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The big problem you'll encounter between your '05 and the earlier cars with the shark fin is that the radio antenna was integrated into the right side rear window (it's a grid). Newer cars incorporate the Nav antenna into a base with a conventional whip antenna for the radio. You could put the shark fin in place of your current antenna, but you'll lose the radio antenna, with predictable results. All is not totally lost, since all MINIs also use the rear defroster grid as a radio antenna as well, in a 'diversity tuner' arrangement. Removing the roof antenna completely will not kill all reception, but since the defroster grid is not a very good antenna by itself, your reception will still suffer a noticeable amount.
You can fit the car with an aftermarket 'on-glass' antenna in place of the rooftop one to regain your lost reception.
Old Mar 5, 2006 | 04:04 PM
dickdavid's Avatar
dickdavid
Get a nice stubby and you're almost there.
Old Mar 8, 2006 | 06:34 AM
Peepers's Avatar
Peepers
So let me see I got this right
2004’s with Nav got a shark fin antenna. Then in 2005 Mini’s with Nav got the whip style antenna. So couldn’t I just order the shark fin antenna from the dealer for a 2004 model and install it? Will I have any radio reception / navigation reception issues??
Old Mar 8, 2006 | 07:56 AM
stevecars60's Avatar
stevecars60
No navigation issues, no radio reception.
Like dickdavid says "Get a nice stubby and you're almost there" & you are good to go....
Old Mar 8, 2006 | 08:00 AM
DrkSilvrMini's Avatar
DrkSilvrMini
just take the atenna off of a S2000 or honda Element
Old Mar 8, 2006 | 10:23 AM
Peepers's Avatar
Peepers
I don't like the appearance of the stubby antennas. I like the look of the shark fin units. I guess it's a person preference.
So, does anyone know this answer?
Old Mar 9, 2006 | 03:43 AM
stevecars60
"No navigation issues, no radio reception"
You won't have an antenna for your radio. The shark fin mounts the same as your antenna....
Old Mar 9, 2006 | 05:31 PM
Peepers's Avatar
Peepers
OK, let me ask a dumb question? Why won't I have an antenna for the radio? Isn't the shark fin an antenna?
Old Mar 9, 2006 | 08:37 PM
mbabischkin's Avatar
mbabischkin
Well, you could just look at the second post....
The shark fin houses a GPS antenna ONLY. There is no AM/FM antenna in the MINI shark fin. That's why all of the 2002-2004 MINIs without Nav still have the whip. The whip is the AM/FM antenna.
Vehicles that have the shark fin have the AM/FM antenna in a metallic grid on the rear passenger side window. Which means that if you have a whip antenna currently on your car and you replace it with a shark fin, you will have poor to no AM/FM reception unless you get an aftermarket antenna system that can be applied to a window just like what the 2002-2004 MINIs with Nav currently have...
Old Mar 13, 2006 | 06:50 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Shark fin solution:
fabricate your own!
Contains the XM Direct antenna and gives reasonable broadcast (AM/FM) reception in town (of course, with XM who would care if you got broadcast radio reception or not?)
phil
Old Mar 23, 2006 | 01:17 PM
Z-Mini's Avatar
Z-Mini
Originally Posted by gandini
Shark fin solution:
fabricate your own! - Contains the XM Direct antenna and gives reasonable broadcast (AM/FM) reception in town (of course, with XM who would care if you got broadcast radio reception or not?)
phil
Care to share the details on how you did this? Is the AM/FM just coming from the rear window as mentioned in post #2? Any pictures of you placing XM direct inside the fin?
Thanks-
Randy
Old Mar 25, 2006 | 10:58 AM
Z-Mini's Avatar
Z-Mini
Thanks-
Randy
Never mind. I came across another thread where you linked to your DIY article. Thanks!
-Randy
Old Mar 28, 2006 | 09:50 PM
hexproject's Avatar
hexproject
anyone has the part # for the grid antenna.. i like the shark fin and want to do a retro on my 06 with NAV...
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
bahman
Sep 30, 2015 01:59 PM
dutchhome
Sep 30, 2015 07:17 AM
yyj3869
Sep 28, 2015 06:53 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
