Navigation & Audio Show pics of your subwoofer install!
Old May 31, 2010 | 02:49 PM
  #251
Cavalier Cooper's Avatar
Cavalier Cooper
I've been waiting to show this off for a while the sub is a Rockford Fosgate P3S412 a 12 inch shallow mount. We built the box so that it has 1.1 cubic feet of air space, the amp recommends .7 or 1.3. We erred on the side of caution, but probably could have gotten it a half inch shorter and still have been good. It sits flush with the rear seats went folded down. I painted the sub grill hot pink for fun.
Box pre-false floor
Finished product
With the privacy shield down so you can see how much space I still have
Old May 31, 2010 | 03:36 PM
  #252
Dave.O's Avatar
Dave.O
Custom 10 subwoofer enclosure made by audio integrations.
I am running a JL 10 W3v2. I have an RMW Meth kit installed on the left side so I built a false floor between the two units that is level with my covered rear seat delete. I also have easy access to the battery below.
Old May 31, 2010 | 03:42 PM
  #253
rhcp4life's Avatar
rhcp4life
both look good, chili and cavalier
Old Jan 27, 2011 | 08:04 PM
  #254
MyMiniGidget's Avatar
MyMiniGidget
Bump
Old Sep 5, 2011 | 10:14 AM
  #255
Achilles honor's Avatar
Achilles honor
bump
Old Sep 5, 2011 | 07:25 PM
  #256
user 837978240's Avatar
user 837978240
10" shallow Pioneer sub with Alpine amp, with plenty of space in the trunk. =)
Old Sep 5, 2011 | 10:04 PM
  #257
Achilles honor
how much did that system cost?
Old Sep 6, 2011 | 04:10 AM
  #258
user 837978240
I had a trusted local shop install the system, ran about $1100, including installation.
Old Sep 6, 2011 | 09:19 PM
  #259
Kevin@Integral Audio's Avatar
Here are a few photos of our Model 1101S Subwoofer for the MINI, which fits all 1st gen MINIs as well. Happy to answer any questions.
Old Sep 6, 2011 | 10:04 PM
  #260
onefish2's Avatar
onefish2
Integral Audio Sub in my 09 JCW. Installed by Kevin as well. Soundstage next week .
Old Sep 7, 2011 | 01:20 AM
  #261
Achilles honor
im soo close to getting these.. im choosing between these or more performance mods
Old Sep 7, 2011 | 08:50 AM
  #262
mariocaz's Avatar
mariocaz
Hi guys,
I want to install a sub in my MCS 06, only want to know what do I need to do it ??
An amp ?? and do u think also I need to replace my factory stereo/radio ???, because I don´t want to do it. =(
Old Sep 8, 2011 | 05:43 PM
  #263
Swank1975's Avatar
Swank1975
I like the cover on the Intigral Audio box. I need to protect mine better. I worry about lacrosse gear hurting my sub. Going to get a new pic after carpeting my box.
Old Sep 9, 2011 | 12:50 PM
  #264
astrochex's Avatar
astrochex
That is a sweet install. Any pics of the amp installation? Thanks.
Old Sep 9, 2011 | 02:13 PM
  #265
Swank1975's Avatar
Swank1975
You know looking back on my install I would have put my Apline PDX 5 channel amp under one of my seats. They are so small and generate so little heat it can pretty much be tucked away anywhere. That would allow more room to spread the box out lower and wider for a cleaner install back there and make battery access easier also.
Old Oct 3, 2011 | 11:14 PM
  #266
SLapDeBass's Avatar
SLapDeBass
These all look sick. I'm working on a box for 2 ten inch kicker l5 solo barics as we speak. I'm bought to throw up some pics in a bit.
Old Oct 4, 2011 | 05:57 PM
  #267
kmyerslp's Avatar
kmyerslp
This is my first post on the forum. I just bought an 06 R53 MCS and this is also my first custom sub box ever. I liked the idea of Integral Audio's box plus top but just couldn't bring myself to pay that much for it, so I designed and built my own version. The amp is a HFi1000.1D and it's installed under the driver seat. I am 6" tall and wouldn't be able to scoot much forward anyways to allow a passenger behind me so I figured on the floor would be fine. The speakers are D10F Boss 10" Phantoms. They are a shallow mount sub with a depth of 3-3/8". The corrugated sheet metal is 16 gauge, liquid nails fastened and is inset in the 1/2" plywood the thickness of the sheet metal so when it's carpeted you wouldn't see the 12" by 12" squares. The edge of the board on top has weather stripping around the edge to make it soft and give it a snug fit in the back so it doesn't move around much when the subs are thumpin'. It's 16 gauge sheet metal so I don't have to worry about things puncturing the subs if tossed in the back. Anyways, enjoy the pics. Any questions about the build I will try to answer.
Old Oct 4, 2011 | 07:13 PM
  #268
AXO's Avatar
AXO
Really Impressive!
Old Oct 6, 2011 | 09:42 PM
  #269
SLapDeBass's Avatar
SLapDeBass
one real quick question. When you guys installed the systems did you use the stock head unit or aftermarket?
If you used the stock headunit how did you set it up?
Old Oct 7, 2011 | 08:04 AM
  #270
kmyerslp's Avatar
kmyerslp
I decided to keep the head unit. If you keep it you have to splice a line convertor to your speaker wires heading out of the head unit. The lije convertor takes regular wire and converts it into rca. I took the rear left and rear right speakers and added it to them. Aftermarket head units have sub out already in the back in rca form.
Old Oct 7, 2011 | 08:24 AM
  #271
All our systems are designed to work with the factory head units, but will also work with aftermarket units. 1st/2nd Gen and Standard/HK-HiFi systems are each a bit different. Our kits come with everything you need, and our soon-to-be released Soundstage and new 1102 Subwoofer system will be shipping with Plug-n-Play OEM wiring harnesses.
Old Oct 8, 2011 | 03:33 PM
  #272
MotorMouth's Avatar
MotorMouth
11" sub?
Old Oct 12, 2011 | 07:24 AM
  #273
Originally Posted by MotorMouth
11" sub?
Yes and no. The sub is the same, but the Sd (cone area) is somewhere between a nominal 10" and a nominal 11".
The primary change for the 1102 is that it adds the factory harness in place of the old connection method.
Old Oct 13, 2011 | 03:40 PM
  #274
MiniSuperDuke's Avatar
MiniSuperDuke
kmyerslp, very impressive
Old Oct 13, 2011 | 04:02 PM
  #275
MiniSuperDuke
what is the soundstage and new sub system (1102)
