Navigation & Audio Aftermarket infotainment Options
Old Aug 30, 2020 | 06:53 PM
  #226
scottyb043's Avatar
scottyb043
Originally Posted by scottyb043
Apologies for posting this but after reading this thread and looking elsewhere, I haven't seen a definitive answer regarding installing one of these units in a 2010 R55 with the factory Nav. Mine has the second "slot". Anyone know if there is an option for this?
Well, several hours later and a bunch of messages with Aliexpress Sellers, it seems I've landed on a kit that will bring CarPlay to the 2010 Nav System in my R55:
https://www.aliexpress.com/item/4001250003287.html
Pic of it installed:
This one reuses the existing screen, and frankly, looks a bit more elegant compared to some of the others that replace the entire centre section of the dash. Everything will appear to be factory, but with the addition of CarPlay. I'll report back once it is installed.
Old Sep 1, 2020 | 02:58 PM
  #227
BRG56's Avatar
BRG56
Interested to see how this turns out. This would be the ideal option
Old Sep 1, 2020 | 04:00 PM
  #228
scottyb043's Avatar
scottyb043
So it turns out that one won't work as my car has the CCC system and not the CIC system found in the 2011+. This was a good read and I wish I started here, as once I knew what the underlaying system was, it made shopping much easier and took out the guess work: https://en.wikipedia.org/wiki/IDrive
If you happen to have the early NAV that updates via the DVD (2008 - 2010) it is slim pickings for plug and play options. I've landed on this one: https://www.navtool.com/mini-clubman...e-carplay.aspx
They confirm it will work with the 2008 - 2010 Nav System, but the resolution won't be quite as nice, as the factory screen doesn't have as many colours etc. I can live with that as I just want the functionality of Car Play and not necessarily the ability to watch movies etc.
I'll report back when its done.
Old Sep 1, 2020 | 04:15 PM
  #229
BRG56's Avatar
BRG56
Better to find out now than go through the pain of install and have it not work. Either way, looking forward to the install. Good luck!
Old Sep 3, 2020 | 04:22 AM
  #230
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Anyone install one of these into a Harmon Kardon vehicle?
https://www.seicane.com/hd-touchscre...ontrol-s018835
My Clubman is a 2012 LCI with the HK system, and I’m interested in adding this unit to gain CarPlay. I’d like to verify usability before purchase. The online manual is pretty useless, and the manufacturer seems only interested in physical fit to the dash board for compatibility.
Old Oct 10, 2020 | 02:43 PM
  #231
Husky44's Avatar
Husky44
I took a run at NavTool. I'd recommend against it: https://www.northamericanmotoring.co...l-warning.html
Old Oct 31, 2020 | 11:47 AM
  #232
Tronix's Avatar
Tronix
Anyone got the Chinese ones into their 2015 R60 Countryman S? I tried the following 2 and they both gave me the exact same issues, not sure how I can fix these issues:
1) Getting error CC-ID 167 since I can't configure the cars date and time via these aftermarket radios, the only way to fix this error is to use the default radio
2) The speedometer light always stays on these units (the first speedometer bar) hence draining my cars battery.
These are the 2 models I tried:
1)
Amazon Amazon
2) https://www.aliexpress.com/item/4001...27424c4d4oeXpv
My car did not come with a nav system so what are my options?
Old Nov 17, 2020 | 03:45 PM
  #233
jbourne's Avatar
jbourne
Originally Posted by carpecervisi
Sorry updates have been sporadic, but I finally buttoned up everything last night. First drive impression is that it's a very well made product and fits great in the MINI.
Second impression is that it was a super pain in the ***** to install. Thank god there are a few really good disassembly videos on YouTube.
To answer ECSTuning's question, you only see the speedometer screen when you press the MPH button. All other functions are available via that screen though so it's not like you're missing out. One issue that I haven't figured out yet with the stock ROM is how to change the speedometer from kph to mph. It has me completely stumped.
On the plus side, these units have pretty good developer support from XDA and they have theirs running in miles per hour. I just don't think the ROM is all that attractive.
Here's the final shot with the nav unit and LCI center stack. I'm really glad I changed out my old gross grey climate controls. It's a much better look.
So I know the thread has moved on by a few years, but I just got my hands on this unit (I got @howiestt 's old unit, hehehe). It seems pretty decent. Agree the sound maker puck is hideous, but what can you do.
Question - has anyone gotten theirs to run with the key in ACC mode? (single press of start button)? I don't really want to run it with ignition on - if I'm waiting for someone, I kind of want to just play with it or something, don't necessarily want ignition on, but every time I shut off the ignition, it actually shuts down (so the powerup also takes a pretty long time). Any way to have it sleep?
Also did the pre-LCI to LCI console swap. So much nicer!
Old Nov 18, 2020 | 10:25 AM
  #234
jbourne's Avatar
jbourne
Doing some more investigation, it looks like the R56 harness does not have an ACC (switched) wire on it. On the main harness, there is 12V but no switched wire. This is REALLY confusing. But the ISO connector between the Topnavi display unit and CD unit DOES have an ACC wire (but I have no idea where it gets power from... or maybe it doesn`t, seeing as the unit does not stay on).
Im not even sure I’m going in the right direction here, because the unit DOES know that there is a switch happening (because it DOES power on and it DOES power off), I just want it to stay powered though. Maybe I need to replace the 12V power in the harness by a switched ACC wire from somewhere, maybe fuse box?
Old Nov 18, 2020 | 10:39 AM
  #235
jiggersplat's Avatar
jiggersplat
https://docs.google.com/spreadsheets...t?usp=drivesdk
Mine turns on in the ACC position. You could try A13, I'm not sure if that is an input to the radio or driven by the radio to turn the amp on. I suspect it's the latter but you could probe it.
Old Nov 18, 2020 | 11:14 AM
  #236
jbourne's Avatar
jbourne
A13 doesn’t seem to go to 12V .... very odd indeed. Thanks for that link though. I have some weird wires in the B/C part of the connector that have nothing matching on the car side, not sure why they are there or where they go to.
Old Nov 18, 2020 | 11:33 AM
  #237
Keith Chisholm's Avatar
Keith Chisholm
New Carplay option from Bimmer-tech
It looks like Bimmer-tech finally came out with the 2016-2020 MMI retrofit kit. I don't think I am ready to make the leap yet, but would like to hear impressions from anyone that does. Here is the link:
https://www.bimmer-tech.net/products...ay-mmi-nbt-evo
Happy motoring!
Keith
Old Nov 18, 2020 | 01:52 PM
  #238
jbourne's Avatar
jbourne
I think this post has identified the issue. There's no ACC (switched) power on the harness. But then .... I'm really confused. Should I rewire the yellow (12V+) to the fusebox switched power? Do I assume it was intentionally designed this way and I'm doing something wrong, or do I assume it was designed this way out of laziness? Heh.
Old Apr 1, 2021 | 07:57 AM
  #239
takrdown's Avatar
takrdown
Originally Posted by treowx
So my first attempt got deleted. I will try again without links.
Has anyone tried to use a ground loop isolator for the alternator whine feedback? I am thinking about ordering one of the nav units here soon.
Just installed one of these units and there is a bit of an alternator wine. Did anyone have any luck with a ground loop isolator and if so which one and how was it installed? Thanks!
Old Apr 1, 2021 | 08:10 AM
  #240
jiggersplat
I've been wondering this too. Not sure how one would install it. I've used them in the past with an aftermarket head unit and an aftermarket amp and a ground loop isolator with RCA in/outs. I've got the H/K amp so I'm guessing my choices are splice a ground loop isolator into the harness in the speaker connections or run a ground wire between the head unit and the H/K to tie the grounds together better. I assume this is only affecting people with HiFi or H/K amps?
Old Apr 1, 2021 | 08:16 AM
  #241
jiggersplat
Couple people here seem to think it's an internal issue and not something easily fixed without opening up the head unit.
https://www.audizine.com/forum/showt...ckground-noise
Old Apr 1, 2021 | 09:27 AM
  #242
takrdown's Avatar
takrdown
Thanks for the reply! I have an integral audio system and I’m wondering if I can put one in line right before the amp. I noticed I only seem to have the whine in the front integral audio speakers and not from the back oem speakers .I’ll order a ground loop isolator and see what happens. Now to find one...
Old Apr 1, 2021 | 10:00 AM
  #243
takrdown's Avatar
takrdown
SO I posted too soon. I looked at the link you provided and I'm wondering if the line out converter might work as described. That and taping up the extra RCA cables and whatnot with electrical tape. I have a rattle from the install that I want to address anyway.
Old Apr 3, 2021 | 10:24 AM
  #244
takrdown's Avatar
takrdown
Realized that the input to the integral amp is rca so I got two rca style ground loop isolators. No joy. In that Audi forum thread it sounds like one guy had luck with the noise isolators. I may go that route next. I’m pretty happy with the unit none the less.
Old Apr 3, 2021 | 02:33 PM
  #245
takrdown's Avatar
takrdown
Another update to the alternator whine: seems like I only get it with my wired apple CarPlay. When I use the headunits radio I don’t get the whine....any thoughts?
Old Apr 5, 2021 | 09:02 AM
  #246
takrdown's Avatar
takrdown
I’m curious if anyone with a wireless CarPlay solution gets the alternator whine...
Old Apr 5, 2021 | 09:19 AM
  #247
jbourne's Avatar
jbourne
I do not, no. I don’t think I can reach the CarPlay box to try it wired… once my backup camera arrives I’ll be taking it apart to check, so if nobody replies by then, I can try.
Old Apr 5, 2021 | 09:36 AM
  #248
takrdown's Avatar
takrdown
Interesting. My current theory is that my alternator whine is coming from the apple CarPlay wired unit. At least in my case.
maybe I’ll purchase a wireless one and see...I hate throwing money at troubleshooting.
Old Apr 5, 2021 | 09:47 AM
  #249
jbourne's Avatar
jbourne
It would seem illogical that a wireless one would fix it, because your noise isn’t over the Lightning cable - so if anything, your noise point would remain the same somewhere in the system, no?
Are you plugged in using the car harness alone or do you have any extra wiring?
Old Apr 5, 2021 | 10:07 AM
  #250
takrdown's Avatar
takrdown
The reason I think it may is only because the USB is providing power to my iPhone and I wonder if that is causing the interference. Like I said earlier, I don’t get the whine from the Android radio or videos, etc...just when I use apple CarPlay
I don’t get any interference in my wireless CarPlay in my M3, but that isn’t an android unit either.
