Navigation & Audio Aftermarket infotainment Options
Old Jun 7, 2019 | 02:54 AM
  #151
bluescreen's Avatar
bluescreen
Originally Posted by Redleif
That looks awesome howiestt! Now if only I can find that same display (without ODO around it) for the gray non-LCI radio. All the displays I have found like that are for black, LCI models. The gray non-LCI options I have found all have the ODO ring in kmph with a smaller screen. If anyone can find the larger display with the gray non-LCI setup that would be info a lot of us 2nd gen guys would cherish!
just buy an lci dash and use the radio for the lci without the odo ring.
Old Jun 7, 2019 | 10:53 AM
  #152
Redleif's Avatar
Redleif
Yeah that was my initial idea, however, I have read mixed experiences on using the black A/C controls & window switches with the pre-LCI vehicles. One write-up said the black A/C controls were plug-n-play, while another had to swap the electronics from the gray A/C to the black A/C controls? Just seems simpler to find something designed to fit the pre-LCI setup.
Old Jun 7, 2019 | 10:58 AM
  #153
bluescreen's Avatar
bluescreen
I believe that the grey a/c controls fit the lci fascia, i am waiting my radio to test it. i have already bought the new fascia
Old Oct 15, 2019 | 05:12 AM
  #154
hawtdogflvrwtr's Avatar
hawtdogflvrwtr
Originally Posted by jiggersplat
I don't think you need it. On my 2013 with the H/K amp, the amplifier can be turned on just like any aftermarket amplifier, just by hooking up the remote lead to 12v.
Do you happen to have photo's of how you wired this? I'm about to install this unit and I have a HK setup. I saw your spreadsheet and discussion on rca -> 4mm bullet connectors, but was curious if you had any photo's so i'm not scrolling through the feed during my install. Also, any suggestions on the LOC you used and where you got the bullet connectors?
Old Oct 15, 2019 | 07:10 AM
  #155
jiggersplat's Avatar
jiggersplat
don't have any photos, but i will poke around this evening. if i recall correctly, it is pin 12 or pin 13 that is the remote lead for the amp. the harness that came with my stereo did not have that pin populated. i think i posted a link to my wiring spreadsheet somewhere in this thread. there is a 12v+ remote lead (usually blue) on the stereo harness that you can either insert into the harness if you can find an appropriate pin to crimp it on or just splice/bullet connector it to the backside of the car's connector. i prefer the bullet connectors to t-taps just because if i ever want to go back to stock, it's a plug and play affair, or if you ever need to take the stereo out for some reason, you can just unplug.
these are the bullet connectors i used
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
and here is the crimper (there are cheaper ones that will do the job though)
here is the LOC i used, although it's a bit large. you might look for a physically smaller one. find one that is adjustable (the bigger the range the better probably) and can handle 40 watts per channel (i think is what these android units are rated at). make sure you adjust the levels before you cram it back into your dash and button everything up.
Old Oct 15, 2019 | 07:13 AM
  #156
hawtdogflvrwtr
AWESOME! This is exactly what I was looking for.
Old Nov 3, 2019 | 10:13 PM
  #157
hardkhor's Avatar
hardkhor
Been following this thread and others for a while to look for a plug and play option for my 2011 R56 MCS. Was planning to install a camera on it too.
This thread has since fizzled out but is a bit outdated anyways
https://www.northamericanmotoring.co...ereo-unit.html
Looks plug and play and the poster answers a lot of questions. Seems to work fine but is on the expensive end. Prefer one with the speed on the edges (like the one howiestt has)
This looks attractive but have no idea what works and what doesn't. Of course it might not be plug and play either. Comparing wiring pictures of whats included, it makes me think it is plug and play
https://www.alibaba.com/product-deta...56226afbhOedMS
Old Nov 4, 2019 | 03:17 AM
  #158
hawtdogflvrwtr
I installed the brand new px5 model on aliexpress (https://www.aliexpress.com/item/3299...384c4c4doMfVoQ), this weekend. Was a breeze and it turns out, they now detect system amp and turn off the preamp in the head unit automagically. I didn't need to install the LOC to get sound lowered before being tossed to the factory amp. Pretty happy about that to be honest, because I wasn't looking forward to the additional work. The only two issues I had with the device were the radio being set to Europe (After entering factory settings with password "m123456" I was able to change it to America1. ) And the fact that I can't set the date on the tach cluster, thus having to endure the tiny exclamation mark next to the mileage (anyone know how to fix this? Looks like it pulled time from the radio).
Old Nov 9, 2019 | 05:52 AM
  #159
jame5_b's Avatar
jame5_b
@ hawtdogflvrwtr
looks good. Did you install a new skin on the unit or is they the software it comes with?
Old Nov 9, 2019 | 07:00 AM
  #160
hawtdogflvrwtr
Originally Posted by jame5_b
@ hawtdogflvrwtr
Its car launcher pro with a custom layout.
Old Nov 10, 2019 | 04:06 AM
  #161
Scudder44's Avatar
Scudder44
You should be able to change the tach date and time using the DC stalk control on the column in SET/INFO.
Old Nov 10, 2019 | 04:32 AM
  #162
hawtdogflvrwtr
sadly, it's not there. I believe that at some point, they removed it. There are several other people with the same issue. I have no setting under set/info, for my model.
Old Nov 13, 2019 | 04:29 AM
  #163
hawtdogflvrwtr
@jiggersplat , do you have any issue with bad feedback and hissing when you use the phone app? I received a call for the first time yesterday and it hissed and whined like mad. The radio/music streamer doesn't have alternator whine, so i'm at a loss as to where to attack it.
Old Nov 13, 2019 | 04:44 AM
  #164
Scudder44's Avatar
Scudder44
OK the feedback problem. if your car has a mic fitted for the previous head unit, you need to disable it, unplug it as you are using it and the built in one on the unit = feedback.
Old Nov 13, 2019 | 04:48 AM
  #165
hawtdogflvrwtr
I did when I installed the head unit because I saw a post WAY up there about it. I will take a look at the back of the factory mic to verify I guess.
Old Nov 17, 2019 | 09:38 PM
  #166
Dinoco's Avatar
Dinoco
Any CarPlay options available?
Old Nov 18, 2019 | 03:53 AM
  #167
hawtdogflvrwtr
There appears to be a usb dongle that adds carplay support, for the model that I purchased. I can't attest to the quality of functionality, but it exists:
https://www.aliexpress.com/item/3292...184937d8hxg8ji
Old Dec 13, 2019 | 04:58 PM
  #168
Kazy's Avatar
Kazy
Originally Posted by peregrine48
In case anyone else ends up in the same place as me on the issue with AUX and USB... after literally 5 hours of searching I found this... which can be be used with the OEM ports on my 2012 R56 to go straight into my aftermarket Seican head unit.
https://www.aliexpress.com/store/pro...4836518cz1cMw4
Does this charge from the new head unit at full speed? (5V 1A)
edit: Also, does anyone with this also have parking sensors? Does the chime for that still come in through the radio?
Old Dec 14, 2019 | 12:03 AM
  #169
Scudder44's Avatar
Scudder44
YEs to charging. Yes to chimes being present.
Old Dec 14, 2019 | 06:55 PM
  #170
Kazy's Avatar
Kazy
I'm talking about the linked adapter specifically for charging, it doesn't look like it has all the USB pins in the back connector. Which unit are you answering about? I'm asking specifically about the one without the speedo (the black one)
Old Dec 19, 2019 | 06:31 AM
  #171
dellboy88's Avatar
dellboy88
has anyone changed the radio app so it displays the station names?
Old Dec 20, 2019 | 06:01 AM
  #172
Kazy's Avatar
Kazy
Does anyone have a link to a Carplay/Android Auto dongle that works with steering wheel controls?
Old Jan 1, 2020 | 07:54 PM
  #173
Kazy's Avatar
Kazy
​​​​​​Can you share your car launcher pro layout?
Old Jan 3, 2020 | 09:48 AM
  #174
hawtdogflvrwtr
I will do it this weekend and figure out how to post it.
Old Jan 3, 2020 | 07:51 PM
  #175
Kazy's Avatar
Kazy
I actually found a different launcher I really like, and it has deeper integration with the PX5 chips these use. It's called FCC Car Launcher. I was also able to get the steering wheel controls working with third party apps, as well as the voice control button set to activate Google Assistant.
