Navigation & Audio Anyone that has Integral audio sub step in please :)
Today had my GP out and it was close to 90 degrees, had the sub cut out about 4-5 times for about 5 mins each time. anyone have this happen? My setup is not that old(put in last fall) and the Amp is HOT! anyone else?
my Arc amp seems to get pretty warm too, but haven't had it long enough to encounter issues. maybe you have your gains set too high, causing the amp to push itself too much? on mine, I lowered my sub channel gains way down, almost to minimum, instead of around 80% like suggested. also, is your remote **** set to max? ideally, I'd like to keep my remote **** near 50% for the majority of listening so I have some leeway to adjust for various music styles.
Pete,
If it is an overheat shutdown the amp power led will flash a red code (a series of long/short flashes). Check to see if you are getting an error code, and if so let me know what it is.
Gain levels will not actually affect the heat generated by the amp, only total output level. Unless you are driving the amp beyond capacity on an extremely hot day, you should not see a thermal shutdown. It's possible your problem lies somewhere else.
Email me directly with what you find (I know you bought the system used, that's not an issue - always happy to help with any of our products regardless of whether you were the original purchaser).
Kevin, haven't driven it since that day, yes it was a used(never installed system) lol
amp is only driving the subwoofer, nothing more or less...it hasnt happened before, then again i havent used it that much, the car only has 4500 miles and maybe 1k since install...
I will say it WAS HOT! i couldnt touch it longer than a split second(this was on the silver oval)
Roger that, thanks Kevin.
That said, the arc amp aways seems to run a bit on the hot side to me, and I still haven't put the side panels back on.....
gar56
Nov 15, 2016 06:41 AM
vetsvette
Oct 20, 2015 07:42 AM
