Navigation & Audio HK amplifier location?
Old Feb 19, 2011 | 08:47 PM
steddy's Avatar
steddy
I have tried to find on the forums in any information as to the location of the OEM amplifier in my MCS. I do not want to deconstruct my whole interior. I have a 2005 MCS Convertible with HK system. I am replacing the HU and amp but am not sure where the amp is located. Can anyone help point me in the RIGHT place?
Old Feb 19, 2011 | 09:33 PM
Eric_Rowland's Avatar
Eric_Rowland
It's either under the driver or passenger's seat. I think it's the driver's, as the Nav unit generally resides under the passenger seat.
Old Feb 19, 2011 | 11:03 PM
rkw's Avatar
rkw
In the convertible, HK amp is under the passenger seat.
Nav unit in the convertible is on the drivers side (opposite of the hardtop).
Old Feb 22, 2011 | 05:54 PM
steddy's Avatar
steddy
rkw you are the man, or woman. Your advice was spot on. Pulled the amp this weekend and replaced. Interesting little compartment they have designed under the seat. New amp fit in their perfectly. I now have an amp for sale on e-bay. Thanks for the help. I was worried that I was gonna have to strip down the interior.
Old Aug 18, 2016 | 02:38 PM
mkeaton1967's Avatar
mkeaton1967
HK Amplifier Location
Hoping that you guys from back in 2011 are still getting replies on this thread....
I need to bypass the amp, possibly replace, but the new stereo is powerful enough for me. Rather than manually run wires to all the speakers, take door trim off, remove back seat, etc I was thinking that I might just run new wires to where they come out of the amp.
Did getting to the amp require removing the seat?
Any other good place to pick up the speaker wires coming out of the amp that is easier to get to?
Thanks in advance for your feedback and thoughts.
Old Aug 19, 2016 | 06:16 AM
Capt_bj's Avatar
Capt_bj
rkw is still around .... try PM
Old Aug 19, 2016 | 09:23 AM
rkw's Avatar
rkw
Originally Posted by mkeaton1967
Did getting to the amp require removing the seat? YES
Any other good place to pick up the speaker wires coming out of the amp that is easier to get to? NO
Removing the seat is trivial. Unplug the wires underneath and remove the 4 bolts from the seat rails. And with the convertible, you have the advantage that you can put the top down first which makes it much easier to move around the interior. Don't turn on the car while the seat is unplugged, or it will trigger an airbag fault (disconnect the car battery first to be completely safe).
Old Jan 17, 2017 | 11:47 AM
DRMCDAVE's Avatar
DRMCDAVE
For anyone considering running new wiring. I'm doing it now and getting a new wire into the door is pretty horrible. I assume it to be the worst part of the install but it wasn't pleasant.
richardsperry
Jul 30, 2018 04:48 PM
vbmike
Oct 15, 2015 04:32 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
old81
MINI5280
Sep 3, 2015 09:03 AM
