Navigation & Audio Bluetooth compatibility list
Old Mar 23, 2009 | 06:28 PM
  #601
hizhonor's Avatar
hizhonor
Originally Posted by nicknbecka
The PN-820 has been added the list, along with Pantech, actually. Thanks! I also added a note that the initial pairing took longer than normal.
And if you'd like, the AT&T Epix (Samsung SGH-I907) pairs and handles all telephone functions well. My phone contact list is sync'd with the car, however I must manually select the name from the radio control panel if I want to use it.
Steve
Old Mar 26, 2009 | 09:09 PM
  #602
AK.JCW's Avatar
AK.JCW
Blackberry Bold works flawlessly.
Old Mar 27, 2009 | 04:36 AM
  #603
schatzy62's Avatar
schatzy62
Originally Posted by howie289
Without NAV, all phones will need recorded voice tags?
Yes this is correct. Why? it's just the way they programed it. the NAV cars don't have this problem
Also, when I'm using my Bluetooth headset, I push the headset button and say "call home" and it dials home. This wouldn't work using the MINI bluetooth without recording voice tags?
Yes, same as above.
It is very unfortunate that MINI will not change this. I do not see why they could not but after speaking with MINI Customer Service they can not get an answer to why.
EDIT: and BTW at least in my 08 (i do not think it changed for 09) there is a limit of 20 names/numbers that can be recorded.
Old Mar 27, 2009 | 10:28 AM
  #604
nicknbecka's Avatar
nicknbecka
Originally Posted by sgsuperman105
Good= HTC S740
Pantech Matrix Pro
Bad=Samsung A737
Thanks, much appreciated! I had the A737 in the list as pairing and dialing, but not syncing the address book, does that match what you experienced?
That would imply that the S740 and the Matrix Pro at least sync'd the address books?
Old Mar 27, 2009 | 11:00 AM
  #605
nicknbecka's Avatar
nicknbecka
Steve
Thank you Steve! I've got it entered. It's odd that you need to do the manual selection from the radio- (I'm assuming by your problem and description that you don't have the factory installed nav...) Have you setup voice tags for the numbers you want to dial by voice command?
If not, you'd most likely get the error 'Phone book is empty' when you press the voice command button and try to use the dial/call command.
Old Mar 28, 2009 | 05:42 AM
  #606
hizhonor's Avatar
hizhonor
You are correct --- I do not have the factory nav. Judging from other comments in this thread, I suppose that explains why I can't access the book via voice. Lacking that feature does tend to limit the usefulness of the system. All that **** twirling and button pushing is a major distraction. I have over 1,000 contacts and locating the one I want is more than I care to put myself through. I generally just grab the phone and find them that way.
I have entered a couple of voice tags and that works just fine --- after moving the microphone. Before that, the system couldn't understand what I was saying.
Steve
Old Mar 30, 2009 | 05:49 PM
  #607
howie289's Avatar
howie289
Here's my contribution to the cause:
Car: 2009 MC Conv, No-NAV (picked up today!)
Phone: Verizon Chocolate 3 (picked this up last week)
SW Version: VX856V05
Pairs, Dials, Transfers Address Book with no problems
Must create new voice tags
Old Mar 30, 2009 | 07:21 PM
  #608
dvhone's Avatar
dvhone
nicknbecka,
thanks so much for the info you've gathered and maintained. I used it to pick a new phone (Sony Ericson W580i) before I picked up my Clubman, and it worked perfectly, just as your data said.
Thanks, thanks, a thousand thanks!
Old Apr 1, 2009 | 09:24 AM
  #609
nicknbecka's Avatar
nicknbecka
Thanks Howie! The Chocolate 3 has been a common question recently, so it's really great to have the info on it.
Old Apr 1, 2009 | 09:35 AM
  #610
nicknbecka's Avatar
nicknbecka
Originally Posted by dvhone
nicknbecka,
Glad to hear that it worked for you- almost all the Sony Ericcson phones listed were tested by TheOfficeMaven long before I started keeping track.
In all honesty, maintaining the list is pretty easy. Most of the work is done by the people who are actually trying the phones out and posting about them
So, a huge thanks to everyone that's posted about their experience with their phones!
Old Apr 1, 2009 | 01:12 PM
  #611
D Unit's Avatar
D Unit
Anyone find a permanent fix for the Treo 700wx?
Old Apr 5, 2009 | 08:20 PM
  #612
nicknbecka's Avatar
nicknbecka
Hmm- a permanent fix for which problem?
Old Apr 5, 2009 | 09:55 PM
  #613
D Unit's Avatar
D Unit
Originally Posted by dominicminicoopers
I've been reading thru threads about bluetooth and compatibility with the MINI system. Some people had alluded to other people who sync'd phones that wasn't on the http://www.wireless4mini.com/phones.html list. I'd like to make this thread be a list of phones people have found to be compatible with the MINI's factory system. For discussions about bluetooth, or how to sync phones, where to buy phones, aftermarket bluetooth, etc, please let's leave that out of this thread.
I'll keep a list of good and bad in this first message.
BAD:
Motorola v555 (connects, phonebook transfers, can receive calls, drops bluetooth connection when dialing out)
Motorola v551
Motorola v555
Motorola v557 (connects, phonebook transfers, can receive calls, drops bluetooth connection when dialing out)
Samsung A-870 does not work
Samsung Blast (no connection/sync to bluetooth)
Samsung Katalyst (drops bluetooth connection but not the call)
Samsung SGH-A707
Samsung SGH-X820 (can't call out)
Samsung SPH-A900 might work, but must be re-paired for each start of the car
Samsung SGH-D900 pairs, but disconnects after about five minutes (maybe a power save issue?)
Sony Ericsson K850i (works for two weeks, then craps out the BT module)
Sprint 6700
Treo 650 (works for a short time before messing up the BT circuits see link Post #9 in this thread)
Treo 700wx works, but must be reset for each start of the car
Treo 755p (works for a short time before messing up the BT circuits see link Post #9 in this thread)
UT Starcomm 6700, works but is interrupted by powersave functions
Specifically, I have to reset my phone after I turn on my ignition in order to get the bluetooth working correctly. Even then, it only works only half the time.
Old Apr 6, 2009 | 10:19 AM
  #614
NotPortlyNJ's Avatar
NotPortlyNJ
I have the HTC Touch Pro, which includes voice command, which interprets my speach and dials. I currently have a Motorola bluetooth earpiece, and when I hit the dial button, I can say "Call Home", and it dials -- no voice tag necessary.
My question: is it possible to set up this same functionality via the MINI bluetooth setup? I really don't need my contacts synchronized over -- I have them in my phone.
Old Apr 6, 2009 | 10:34 AM
  #615
schatzy62's Avatar
schatzy62
If you have NAV it should work just as with your ear piece.
If you D Not have NAV then your MUST set up vice tags to get it to voice dial. Unfortunately that is how the software works. Why I do not know but that is the unfortunate reality. I have even complained to MINI USA about this but just get their same canned response "Thank you for your interest"
Sorry for the bad news
EDIT: BTW there is only 20 slots for numbers in the voice dialing system on the 08's and i have heard but have not been able to verify that the 09's have gone up to 30.
Old Apr 6, 2009 | 10:55 AM
  #616
NotPortlyNJ
Bummer. I may have wasted my money on this.
Oh well.
Old Apr 6, 2009 | 01:46 PM
  #617
nicknbecka's Avatar
nicknbecka
Have you tried upgrading the firmware yet? There's links to Verizon and Sprint updates here
I'm guessing that you've already tried adjusting or disabling the Bluetooth power saving settings? (Power Settings -> "Advanced" tab -> "External Power Settings" and Uncheck "Turn off device if not used for...")
Old Apr 7, 2009 | 08:51 AM
  #618
M1NN1E_'s Avatar
M1NN1E_
Hi Everyone!
I am having a really difficult time finding a current phone from AT&T that works with my MINI.
Anyone recently gotten a phone from AT&T?
Or does anyone know of one that will work?
I like "easy to use" phones- LOL
Thanks!!!!!
Old Apr 7, 2009 | 09:17 AM
  #619
Minidrivr's Avatar
Minidrivr
Originally Posted by M1NN1E_
Hi Everyone!
Thanks!!!!!
If you are a current AT&T customer, buy an unlocked phone and put your sim card in it. I use an unlocked Razr from Amazon. They are easy to use and work 100% with the Mini.
http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
Old Apr 9, 2009 | 10:56 AM
  #620
howie289's Avatar
howie289
I have Comfort Bluetooth that includes the armrest wired for an cradle. Does anyone have suggestions for easily hooking up a USB cable to use for charging a phone or other portable device? Is there an adapter that could clip onto the armrest connector? Would the best idea be to buy any cradle and solder a USB cable to the proper power/ground pins?
Old Apr 9, 2009 | 11:45 AM
  #621
Minidrivr's Avatar
Minidrivr
That's been pondered here before and no one has come up with a cable to connect to the cradle connector. The round part in the middle is the antenna connector. Probably the best way to make your own would be to buy a cradle chop it up to figure out where to connect to. When I dismantled my Razr cradle it has a circuit board inside directly above that connector in the armrest. There were no loose wires that I could have attached to, although anyone with soldering experience on circuit boards could have figured it out I'd bet.
Edit: Considering a razr uses a small USB connector (looks like a Mini-A type I think), you might be able to just cut up the cradle and tag onto the wiring to that jack.
Old May 4, 2009 | 04:13 PM
  #622
Flyinace2000's Avatar
Flyinace2000
My new 09 has the buetooth option which is new for me in a car. I use a bunch of Nokia phones but currently i am using the 5800XM. It pairs fine, adress book works fine, but seems to drop connecting in the middle of a call. Any ideas?
Old May 4, 2009 | 11:06 PM
  #623
nicknbecka's Avatar
nicknbecka
How far into the call? is it always around the same time?
Old May 14, 2009 | 09:34 PM
  #624
PatM's Avatar
PatM
Blackberry Storm Update?
Can anyone give me an update on the Blackberry Storm? I'm wanting to buy that phone but I want to make sure that it works perfectly with my 09 MCS. No nav.
Updates would be great.
Regards,
Pat
Old May 15, 2009 | 03:37 AM
  #625
Otra's Avatar
Otra
Did you check out nicknbecka's spreadsheet link? http://spreadsheets.google.com/ccc?k...HjCm-AfA&hl=en the Storm looks like it's all good news.
