Navigation & Audio Subs in 6x9 locations
Old Oct 22, 2007 | 06:18 PM
Big K's Avatar
Big K
Has anyone else thought about using the 6x9 location for subs only? Is there an air tight enclosure there? I havn't seen any 6x9 subwoofers but JL Audio makes 6x8 component speakers that could be used for low end only. In professionel installs rear speakers are rarely used as they mess with the front sound stageing. My thought anyways.
Old Oct 22, 2007 | 06:47 PM
ScottRiqui's Avatar
ScottRiqui
Using 6X9's should work out pretty well. Even though the area behind the speaker isn't totally airtight, there's enough isolation between the front of the speaker and the back to make it work.
Also, a 6X9 has almost as much cone surface area as an 8" sub, so if you can find on that has good linear excursion (cone travel), you should be able to move a good amount of air with it.
I guess it's just a matter of finding a 6X9 that's not a coaxial/triaxial, since you just need it for the bass reproduction.
Old Oct 22, 2007 | 07:54 PM
PGT's Avatar
PGT
I have a pair of old school Kicker 6x9 free-air subs sitting in the garage. Should be nice with some power to them.
As for current sources, Parts Express sells 6x9 subs from Tangband
you an also cut out the 6x9 hole a bit and use an 8" midbass on an MDF baffle. Elemental Designs makes a nice, inexpensive product that works well. Also...JL used to sell some IB8's meant for this type install, if you can find them still.
Old Oct 23, 2007 | 11:48 PM
silnt_assn_009's Avatar
silnt_assn_009
Try this:
http://www.woofersetc.com/index.cfm?...roduct_ID=3077
CDTAudio is a relatively unknown brand to most people, but is well respected by car audio enthusiasts.
Old Oct 24, 2007 | 04:11 AM
snid's Avatar
snid
I think Ian (gbmini) at one point had some 6" JL Audio "subs" installed in the 6x9 openings in one of his MINIs...
yup:
http://www.gbmini.net/wp/2005/06/jam...io_specialist/
Old Oct 24, 2007 | 07:42 AM
a96bimmerm3's Avatar
a96bimmerm3
A 6" isn't really going to do very much. Look at my post about the sub enclosure. i don't think the low frequency is going to be there with a 6"
Old Oct 24, 2007 | 07:54 AM
AnnJones's Avatar
AnnJones
Subs
I first went with 6 X9 true subs, but now have 8" ED subs in sealed 1 cu ft enclosures. They fit behind the stock grills and are powered by a 400 watt amp under the drivers seat. There are a couple of pics in my gallery
Ann
Old Oct 24, 2007 | 05:51 PM
Big K's Avatar
Big K
Wow there seems to be alot of space behind those openings, at least on the 1st generation. Is it the same on the '07
Old Oct 31, 2007 | 03:28 PM
Storm180's Avatar
Storm180
I was thinking of the same idea, except I was hoping to use Kicker 8" L5's or L7's. With my first stereo for Charlie, I went with subtle and "factory look" (except the trunk). Now I think I'm going for a little more "in your face".
Don't know how its all going to work but the idea was Kicker SS 6.5 components up front, the 8" subs in the rear location and the amps in the trunk.
Old Nov 8, 2007 | 04:31 PM
LaserBlue07MCS's Avatar
LaserBlue07MCS
Has anyone else tried 6" x 9" subs? I really don't want to take up any of the precious space in the car or have to hack her up, but really want more bass.
Old Nov 25, 2007 | 11:31 AM
Nui's Avatar
Nui
i emailed then about those CDTs. They said they won't go low enough to be subs. If you look at their frequency response it shows it won't go below 45Hz. Here's what he said:
"Sorry but their specs show their capability. they won't go to true sub bass. But I have had customers mention they were using them in Mini's. I never got any feedback on results though"
Old Nov 25, 2007 | 12:38 PM
silnt_assn_009
45Hz is pretty low. You're not gonna get that from the fronts. You're right, they're not gonna be real subs, but you are gonna get some low bass. If you really want subs back there, try these:
http://www.focal-america.com/
They are 5'' subs.
or this:
http://mobile.jlaudio.com/products_s...p?series_id=23
Filmy
15
Jun 6, 2023 06:27 AM
vbmike
Oct 15, 2015 04:32 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
Filmy
Sep 7, 2015 08:27 PM
jesterofatlas
Sep 4, 2015 11:23 PM
