R56 How to Install New Style Shift Linkage Clip?
Old Mar 23, 2023 | 09:41 AM
joseph.pokorski@gmail.com's Avatar
Can anyone give me some help installing this clip at the end of my shifter linkage? It looks different from the original clip and not sure how it goes, or even if its the right part. The part number dealer gave me is 25112754813. Even a picture of it installed on your car would be great.
Here's the existing part:
Here's the new part:
Old Mar 24, 2023 | 06:54 AM
Hello,
Here is the part: https://www.ecstuning.com/b-genuine-...p/25112754813/
Located here: https://www.realoem.com/bmw/enUS/sho...40#25112754813
For this cable: https://www.ecstuning.com/b-genuine-...r/25117594646/
On the end near the transmission.
Snaps on the ball end on the transmission https://www.northamericanmotoring.co...spd-trans.html
Then the clip finishes the job after the cable link is snapped into that.
The other side has a diffrent clip also
https://www.ecstuning.com/b-genuine-...e/25118609053/
It holds those cables in places. Narrow U clip side goes down and slides in from side, pair of pliers should work.
See the numbers on the diagram.
Old Mar 24, 2023 | 08:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I am still fascinated at these clips. When I did my clutch R&R, those clips were not on my cables. Maybe I'll have to pick up a couple and stick them on....
Old Mar 24, 2023 | 10:46 AM
This is VERY helpful, thanks. I'm thinking the part I call the old clip goes onto the end of the shift rod FIRST and then the clip i pictured as the new part slides over the top, keeping everything together. Agree? Picture of Clip installed anyone?
Old Mar 24, 2023 | 10:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That's how I would understand it to go together. The clip becomes the secondary point of security.
Old Mar 24, 2023 | 11:51 AM
Calling the dealer to install the safety clip at no charge. This is a workmanship issue that made it dangerous to drive. :(
Thanks all for your help.
Old Mar 24, 2023 | 11:56 AM
Thank you sooo much. Not installing the safety clip when the clutch was replaced created a safety issue that made it dangerous to drive. I will arrange to have the dealer install it at no charge.
Old Mar 27, 2023 | 07:16 AM
Yep its was a fix down the road. I dont know when they issued them But part came out in 2011. I checked my 2012 R58 and i did not have them. Sometimes parts are warranty fix, and never become repair bulletins.
Old Mar 27, 2023 | 10:58 AM
All really useful information and explains why the safety clip was not installed in '09 MINIs, the fix did not yet exist. Now that it does, I sure want it in mine.
The dealer is installing it today, I don't want that rod end coming loose again.
BTW, if you don't want to install the safety clip, the part number for the rod end clip shown below is N90815903, Yes, its a VW part but it is identical and will fit. Available from ECS Tuning. Good to have a couple spares in the glovebox JIC..
Old May 4, 2023 | 04:35 AM
Yoshimura 1's Avatar
Yoshimura 1
What's the part ## for the new style clips....... Tried clicking on the link it's corrupted....
I see 2 different one's the ECS site but can click on those either......... Need these like
yesterday.......Maybe I'll just call this morning....
Old May 4, 2023 | 04:53 AM
Xplct's Avatar
Xplct
Hello,
do they make these for R53?
Old May 8, 2023 | 01:15 PM
No that i have seen. But its very close the same design, might be worth a chance to try to install one. I did both my cables on my R52 already. Have not tested the clip yet.
Links all working above for my post.
Mar 23, 2023 09:25 AM
ChiliRedS
Oct 9, 2007 08:22 PM
minirab
DC Metro MINIs (Archive)
Nov 4, 2006 07:10 AM
mikeo
Sep 5, 2005 09:07 AM
d-mini-ero
Nov 20, 2003 04:20 PM
