Suspension R53 Budget Coilover Thread
Old Dec 17, 2019 | 10:45 AM
R53Madness's Avatar
R53Madness
Alright guys I am in the market for a budget coilover (under 1k). All the treads are pretty old and since alot of the coilover company's now have updated their coilovers. Reasons for choosing budget coilovers:
1: It has 218k miles on them. Seriously doubtful that I will make it to 300k with that being said I don't need coilovers that will last me a long time.
2: I don't drive but maybe 5k miles a year and roads I drive on are very good roads.
3: It's for my DD so no track use.
I want fist hand accounts of your coilovers not "I knew someone". I would like fairly recent accounts as well. I feel 10 years ago companies have probably changed there products. Also I want a set of coilovers with front camber plates. With all that being said here are the coilovers in question.
Rev9 $550
Godspeed $650
Ksport $ 892
Megan racing $900
Bc racing $1000
Old Dec 17, 2019 | 03:17 PM
Thinker2112's Avatar
Thinker2112
I had the Megan Euro 2's on my R50 for 5 years as a daily driver. I pulled them off last fall because all 4 were shot and needed a rebuild and had decided to sell the R50. I had the the dampers set at 16 of 32 on the front and 17 of 32 on back, so essentially half of full stiff and it was a stiff ride. Wife HATED it. I LOVED it. They were durable. They did see some track use as well. You may notice a nearly identical look between the BC and the Megan's. There is a reason for that. It is thought that the BC's are made with better materials but they are made in the same factory. They are very similar. The BC's may last longer. My Megan's needed to have the damper valves replaced 5 years on as a DD with some track use . Had I set them to a much lower setting, they probably would still have been on the car when I sold it this summer. Oh, and I think that the adjuster cables for the rears came with the Euro 2's though they are not pictured.
Old Dec 18, 2019 | 07:16 AM
MINI33342's Avatar
MINI33342
Why do you think you need coilovers?
Lots of great options available for just springs and dampers.
You are going to get what you pay for.......cheap crap coilovers.
Old Dec 18, 2019 | 08:33 AM
R53Madness's Avatar
R53Madness
Because I want to go lower than springs will go and good shocks for lowering springs are $700 (koni yellows) so for that + $200 lowering springs I'm at $900 so might as well spend $100 more for BC coilovers or for the same price go with Megan Racing coilovers
Old Dec 18, 2019 | 08:45 AM
Derek86's Avatar
Derek86
There is a lack of inexpensive, quality options in the suspension world for these cars given their price range. And the factory or stock replacements are mediocre and aging out. I've got some clunking from the top of my front shocks but I haven't found a solution I'm satisfied with to replace the factory package.
I built Bilstein based coilovers for my NA that were great, for about $400. It is ridiculous and we need to figure out a good budget suspension option, because people are not spending $2,000 for coilovers to put on a $3,500 car.
Old Dec 18, 2019 | 09:42 AM
R53Madness's Avatar
R53Madness
I agree there isn't much options under the 1k mark except Megan's. Which from what I have read actually are pretty good. So I think I'm going to give them a shot and do a good review on them.
Old Dec 18, 2019 | 09:55 AM
Derek86's Avatar
Derek86
The biggest issue I see is lack of second hand aftermarket parts. I'm not sure where they are all going, but I don't see much for sale.
I will probably attempt to put together my own budget coilovers at some point but I'm not motivated to figure it out on my own.
Old Dec 18, 2019 | 10:02 AM
Here is some more info for you to help decide. Godspeed review here: https://www.northamericanmotoring.co...ilovers-2.html Megans: https://www.northamericanmotoring.co...53-2006-a.html
We have a guy running Ksport here and he likes them on his R53 JCW. For the price he felt they were the best,
New ECS Coilovers: https://www.ecstuning.com/b-ecs-part...ion-coilovers/
Old Dec 18, 2019 | 10:09 AM
Thinker2112
I got mine through here:
https://www.meganracingperformance.c...ufacturer=3261
They are listing two varieties but all the specs are the same on both.
I feel that these are a good value. There is always a better and more expensive set up. Again, I really liked mine. They are "entry level" coil overs and they are durable. Portland roads are far from smooth and they lasted 5 years of daily driving at half of full stiff.
Old Dec 19, 2019 | 07:07 AM
MINI33342's Avatar
MINI33342
The spring/damper combo for the price is going to be a better product in the end. Lots of bad issues with the cheaper coilovers after a few miles. Questionable build quality and consistency, springs are not of a high quality.
Do what you want, but why do it just to do it......
Old Dec 25, 2019 | 01:45 PM
R53Madness's Avatar
R53Madness
Megan Racing and BC is not questionable in build quality but I would say you are correct with the other brands. BC/Megans are apparently made in the same factory hence why they are so similar. BC's are thought to be made with a little bit more quality parts which are why they are more expensive.
Old Dec 25, 2019 | 02:50 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I vote bc, if I wanted cheap I would go with those or MeisterR ZetaCRD, meister is more popular in the UK forums, I have a set on my 135i and I really like them
Old Jan 12, 2020 | 05:16 AM
daviday's Avatar
daviday
Solo Werks makes a very nice solution. Swapped out my Megan EZ Streets for the S1 and couldn’t have been happier. A lot more comfortable.
perucho
Oct 28, 2018 05:36 PM
The Guarachero
Apr 13, 2015 06:31 PM
Porthos
Suspension
61
Feb 14, 2010 06:10 AM
D Unit
Suspension
20
Jul 7, 2008 11:43 AM
Minirowski
Suspension
Apr 24, 2006 11:10 AM
