Hi new member socal r53
Old Jan 14, 2016 | 12:30 AM
Jimmyjamesphan's Avatar
Jimmyjamesphan
What to upgrade...
Attached Thumbnails Hi new member socal r53-1d5be2e5-1837-4839-9844-6c528bcd264e_1.jpg
Old Jan 14, 2016 | 07:42 AM
Hello and welcome.
Looks like the headlight would be the first thing as they are pretty yellowed and most likely hard to see.
Two options:
https://www.northamericanmotoring.co...storation.html
Or
Depo headlight upgrade
https://www.northamericanmotoring.co...-days-ago.html
Old Jan 14, 2016 | 07:58 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Welcome to NAM! What part of SoCal are you in? If you're near us in Harbor City we do local pick up for anything you need for your MINI. Is there anything done to it currently or is it all stock?
888.280.7799 | 6am - 5pm PST
Old Jan 14, 2016 | 09:26 AM
Jimmyjamesphan
Thank you. I'm located in Huntington beach
Old Jan 14, 2016 | 09:29 AM
Jimmyjamesphan
It's currently bone stock
Old Jan 14, 2016 | 09:44 AM
PelicanParts.com
Vendor
Ah fabulous! You're not too far from us and I actually live in LB, right up the way from you. Best thing to start off with is making sure routine maintenance items are up to date and cared for. Then, as far as mods, look into a supercharger pulley. They're popular to do along with a rear sway bar, which is a very good bang for your buck mod. Let me know if you ever have any questions as I am here to help.
Old Jan 14, 2016 | 10:56 AM
Jimmyjamesphan
Currently the car has like a rattling noise I'm trying to locate. Sounds like there is a nut bouncing around
Old Jan 14, 2016 | 10:57 AM
PelicanParts.com
Vendor
Where exactly do you hear the rattling coming from? i.e. rear suspension, engine bay, etc.
Old Jan 14, 2016 | 11:02 AM
Engine location ? Might be a throw out bearing chatter ?
Old Jan 14, 2016 | 11:23 AM
Jimmyjamesphan
Front passenger side
Old Jan 14, 2016 | 11:27 AM
Jimmyjamesphan
Front what I remember it was around the belt tensioner... the car is currently at home. May look more into it this weekend. Plus there is an oil leak I believe it's from the valve cover. Just ordered a new gasket kit.
PelicanParts.com
Vendor
edit: When you get time to investigate further post up a separate thread in the vehicle specific section of the forum HERE so that you can get a wider range of help. If you feel the tensioner is an issue, depending on mileage and if it has been replaced, I would investigate it as they have been known to have issues. Over time, the tensioner can fail, possibly causing damage to the crankshaft pulley if the tensioner stop fails. Check out all the other pulleys in the area as well.
Old Jan 14, 2016 | 11:33 AM
Tensioner might be the issue: https://www.northamericanmotoring.co...ock-strap.html
When you replace it check the hardware as it tend to rust :
The gasket is not too bad, its those old rusted bolts that can be a pain if the heads are rusted.
Hardware linked:
https://www.northamericanmotoring.co...er-screws.html
Valve cover gasket set here: 11121485838
http://www.ecstuning.com/Search/SiteSearch/11121485838/
Old Jan 14, 2016 | 01:41 PM
Jimmyjamesphan
The car has 80k miles. Thanks for the links. I'll do my homework tonight
Old Jan 14, 2016 | 01:42 PM
Looks rusted on the bolts , get new ones. You are welcome.
Old Jan 19, 2016 | 02:45 AM
Jimmyjamesphan
Any mini cooper car meets worth going to? I wanna see some ideas
Old Jan 19, 2016 | 07:23 AM
quikmni's Avatar
quikmni
Welcome to NAM and the Mini Cooper world.
Looks in the club section for clubs in your area, such as SCMM at www.scmm.org.
Use the search function to look in the specific forums for your car problems because you will probably find solutions or at least ideas on how to isolate the problem to a specific cause. Such as some of the common oil leaks are from valve cover, heat exchanger, crankshaft position sensor, or oil pan. You need to isolate the cause before spending time and money on replacement parts. We can help you find the problem.
RCThrine
Hawaii
Aug 24, 2015 07:22 PM
jimjam19927
Apr 30, 2014 01:41 PM
Poppa Bear
Nov 25, 2007 08:23 AM
