A Big Thanks
General consensus says the front neg. camber should be in the neighborhood of 1 degree more than the rear.I've played around with different combinations but haven't tried anything quite like what you've got. Have you tried this set-up on any real challenging twisties?
Wow, it sounds like your Mini drives like a whole different animal now.
What suspension components are you running. Can you give a list? This year, I'll probably pull the trigger on some new suspension items & I'd like to get a running start at experienced people's feedback. CAP49, can you chime in too?
1) adjustable front camber plates.
2) adjustable rear lower contol arms.
3) 3-way adjustable higher than stock rated rear sway-bar.( no end links )
4) Koni Yellows (Sport) with H-Sport springs.
Fairly simple and realitively easy to adjust. Why adjustable you may ask?
Because there are times you want to give-up a smooth ride for performance handling and visa versa.Or one performance type of driving, Auto-x vs. Track-day, requires different characteristics from your one and only car.
If you are @ 1/16 toe out in the front @ -1.5 camber than you'll have even more toe out at -2.25 if the toe isn't adjusted when the camber is changed.
Following your train of thought...I'm thinking of going back in, set it at -2.25 and see what the "toe" is? Re-set it to 1/16 out and then move the camber to -1.5 and see how much the toe changes. Depending on the difference, keep the 1/16 toe out when camber is -2.25. Don't really care about tire wear on the street.....but don't want to fight driveability issues either. My rear camber has not changed from the time I had the springs/shocks installed last March at AMVIV....2 track days and several autoX days, so I'm not sure I would feel a difference by going to to -1.25 in the rear......but now that I have the adjustable fronts, who knows? The alignment was so far off that anything would be an improvement!
That would make sense. Hasn't been out of the garage since I got done. But maybe this weekend.
Just keep "tweaking" it!
If you do what your talking about it will be a test of your relationship with you old buds at the alignment shop. Hopefully you will and you'll come away with some very valuable test data for everyone with a Mini.Remember from grammar school .... sharing is good.....
On the topic of your rear camber settings I can't help but think that that wide a stance is going to be a devil to break loose for any kind of induced rotation.
</lurk>
[quote=CAP49;2022580].... sharing is good....quote]
He must be old. I'm pretty sure the 'sharing is good' motto was dead by the 70's.
<lurk>
<lurk>
Just might have to start a new...sub club! Well Seasoned MINI Motoring Group. WSMMG? AARP is just a fading fancy.
Store bought body parts welcomed!!
My this really is a "Seasoned" group. Who knew?
Nice to hear from you Eric in Santa Cruz. If we ever get that run together with Minichief in your area please hook-up.
And Brad shame on ya for egging-on The Big Guy he doesn't need any help.
Hey I'm not so big anymore.
Eric is a good guy you'd like him cliff.
Thats true,
I guess thats a good way of looking at it no matter how seasoned I get I'll never be as seasoned as cliff.
Nope Bonus is for what I did last year.
I have work to do so I can get one in July and then again next Jan/Feb.
Should be here today or tomorrow. I guess then I'll take it over to Brad and Steve and say have fun.
I have work to do so I can get one in July and then again next Jan/Feb. Should be here today or tomorrow. I guess then I'll take it over to Brad and Steve and say have fun.
Two words: wheels-tires.
