JCW JCW boost psi.
Old Nov 21, 2019 | 05:55 PM
TRBOLAG R56's Avatar
TRBOLAG R56
JCW boost psi.
2017 F56 Jcw with the nm power module on 91oct setting. Im only seeing a max boost of about .7 and .8 bar (which google calculates to 10.1 and 11.6psi) does that seem low or normal? also what is the normal(s) for stock boost pressures? thanks.
jcw pro exhaust
40*F
50' elevation.
Old Nov 21, 2019 | 06:33 PM
Richieb0y28's Avatar
Richieb0y28
This thread says stock pressure is 15-16 psi: https://www.northamericanmotoring.co...e-f56-jcw.html
Old Nov 21, 2019 | 06:40 PM
TRBOLAG R56
ya i did find that thread but they didnt seem too sure, alot of "i think" or "seems accurate" was hoping maybe theres a definitive answer out there somewhere :/
Old Nov 21, 2019 | 08:28 PM
J_L's Avatar
J_L
Something I don't think I've seen an answer to- will you get an accurate boost number though OBD with one of the piggyback tuners? I believe they basically tell your ECU you are at mountain elevation, so it's fooled into raising the boost a bit higher. So you might be making 14 PSI, but the ECU thinks it's 10, and that's what your OBD reader says. Right?
In any case, that does sound low! I'd try it without the nm, see what happens. And check for leaks.
Old Nov 21, 2019 | 08:44 PM
TRBOLAG R56
ya im going by the boost gauge in the factory cluster the non hud option. ya i might unplug
it this weekend when i have the time and see what it does.
Old Nov 21, 2019 | 10:42 PM
stardust88's Avatar
stardust88
i saw in my defi guage 1,1 bar max in stock f56jcw
now i running stage2 manic , its about 1,75 bar with evebturi intake , catless DP , jcw pro xhaust
Old Nov 21, 2019 | 11:11 PM
TRBOLAG R56
so my boost gauge reading .7/.8 bar even with an nm module is definitely low then.
Old Nov 21, 2019 | 11:49 PM
stardust88's Avatar
stardust88
but i use 98 octan ....
Old Nov 25, 2019 | 04:18 PM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
jcw pro exhaust
40*F
50' elevation.
Go to Amazon and order a Veep OBD reader for under $15...it will give you a true reading. My NM Module shows up to ~21psi and hits 18-19 consistently on the 100 setting
Old Nov 25, 2019 | 04:28 PM
TRBOLAG R56
i have one of the bluetooth veepeak obd readers that i use to code bimmercode with, will that work? Also what app or whatever would i need to be able to read boost.
Old Nov 25, 2019 | 07:18 PM
RockC's Avatar
RockC
jcw pro exhaust
40*F
50' elevation.
For a stock 2018 MINI JCW from a data logger I see manifold pressure values from 12.4 (0.85bar) psi to 14.2psi (0.97bar) with "spikes" to 18psi (1.24bar) and 19psi (1.31bar).
Various trips had different values. Average around 13.5psi (0.93bar) with spikes up to 26.4psi (1.82bar).
Or 13.3psi with an occasional spike to 24. In all cases the spikes really stand out and I do not have a good explanation for them.
Like I said this is a stock 2018 MINI JCW running 91 octane in middle mode. Not sport mode.
Oh this data was from trips back in Nov 2018 with the car almost a year old and with close to if not over 10,000 miles. While I can't tell you exactly where the car was almost certainly I was driving it to/from work and the elevation goes -- when leaving my house -- from around 500 feet above sea level to nearly 1000 feet above sea level then down to under 20 feet above sea level. Temperatures were probably in the 50F to 60F range.
Old Nov 29, 2019 | 06:26 AM
Darbys2019MiniJCW
Free "Torque App" … setup the profile of your vehicle … then when app is on and reading your profile click on Realtime Information
Old Nov 29, 2019 | 08:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would only feel comfortable with an actual boost gauge tied into the intake manifold.... My suggestion is to get an actual boost gauge, and monitor boost without the module. Then add the module and see what happens.
stardust88
Jul 6, 2019 10:44 AM
boubi
Jun 29, 2019 07:30 AM
eR1c
Nov 12, 2014 10:50 PM
shredthegnar
Aug 31, 2011 02:56 PM
MCSPR
Jul 17, 2010 12:50 AM
