JCW low boost
JCW low boost
I have a 2004 JCW it is stock. I recently just installed a boost gauge and im only reading 10 psi at the max. I always thought JCW were suppose to be more then that. Whats the problem? I did install the vac line into the fuel pressure regulator. If you have any thoughts let me know.
10.5 PSI is stock on '02-'04 MCS's. With the teflon-coated rotors, the '05-06' MCS's get about 11.5 PSI. The JCW comes with a 10-11% reduction pulley. The head is ported a bit, which will actually reduce boost (but increase flow, which is good). You should see 13-14 PSI. It's possible your bypass valve spring is worn out, or you have some other vacuum/boost leak. Check the seals on the intercooler.
phrza81
Oct 10, 2015 11:37 PM
Aug 12, 2015 01:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
