JCW boost pressure F56 JCW
Old May 23, 2018 | 03:26 AM
stardust88's Avatar
stardust88
anybody know how much bar ? , maks boost presure f56 jcw on stock
Old May 23, 2018 | 05:49 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
I think, think it is around 16psi maybe a bit more
Old May 23, 2018 | 07:39 AM
elsnaibs's Avatar
elsnaibs
15-16 seems accurate. I added 4 lbs boost and hit 19-20 peak currently.
Old May 23, 2018 | 07:53 AM
stardust88's Avatar
stardust88
what u mean added 4 lbs ? with remap or piggy back ?
19-20 peak in what speed ?
Old May 23, 2018 | 08:36 AM
elsnaibs's Avatar
elsnaibs
The Dinan Power Module adds up to 4 lbs boost depending on which setting is chosen, and the boost monitor via my smartphone allows me to track boost pressure. Not sure what speed I was at when I hit 20, but it was under WOT.
Old May 23, 2018 | 09:02 AM
stardust88's Avatar
stardust88
i use racechip Gts... i think racechip added 4 lbs too...
i use defi turbo gauge ... i see 1.3 - 1.4 bar in peak...
But i dont know again . The street in my country is not enough... must try in hight way...
did u use open filter?
People say if in tropical climate .... is not good...
better use a replacement ....
Old May 23, 2018 | 09:06 AM
elsnaibs's Avatar
elsnaibs
The Dinan App includes the boost pressure monitor, and at the time, I was not using an open filter, however I am now. I should re-test it, now that you mention it.
1 bar is about 14 psi, so 1.4-1.5 sounds about right.
Old May 23, 2018 | 09:21 PM
stardust88's Avatar
stardust88
people say, open filters for the daily will suck more heat from the engine, and make the engine power down.
but open filter sound very good .
non open filter sound like cat, open filter sound like tiger hahahaha
Old May 24, 2018 | 10:59 AM
Scottkenny's Avatar
Scottkenny
1.05 BAR with stock IC. .95 BAR with FORGE FMIC.
Old May 24, 2018 | 11:01 AM
Scottkenny's Avatar
Scottkenny
the dinan app includes the boost pressure monitor, and at the time, i was not using an open filter, however i am now. I should re-test it, now that you mention it.
1 bar is about 14 psi.
1 bar = 14.5037 psi
Old Jul 6, 2019 | 10:44 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
aT hIGH sETTING ON nm pOWER mODULE I have seen 21.2 thru Torque App...after adding the NM Exhasut and AWE Carbon Air Intake
Ketchup
Mar 16, 2018 08:59 AM
Capn How
Chicago MINI Motoring Club
Aug 29, 2017 07:52 AM
axleR56
Jan 10, 2012 02:10 PM
Barnabas
Mar 11, 2006 04:51 PM
sebis
17
Nov 21, 2004 09:19 PM
