F55/F56 JCW Pro exhaust question.
Old Nov 14, 2019 | 01:38 AM
TRBOLAG R56's Avatar
TRBOLAG R56
I purchased a jcw pro exhaust for my 2017 f56 jcw. However I forgot to order tips (which ill get soon) however this Saturday I have access to a heated garage with a lift and my only free day. Would I be ok putting the exhaust on without the tips for a few days? (Itll look goofy I know) Or would I run into issues like melting my bumper or anything the like. Also could I use the regular jcw tips off my original exhaust in the interim, would they fit? Thanks.
Old Nov 14, 2019 | 06:27 AM
robby71's Avatar
robby71
Should be ok without the tips as the exhaust doesn't touch the bumper
Old Nov 15, 2019 | 06:59 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Yeah, tips are more for show than anything
Old Nov 15, 2019 | 11:28 AM
You will be fine.
Old Nov 15, 2019 | 01:09 PM
TRBOLAG R56
You will be fine.
i just bought an NM module and 2 chrome tips from you guys this morning with 1 day shipping. Lol
Old Nov 15, 2019 | 01:15 PM
Thanks for the order! Got some fast tunes and tips flying through the air.
Old Nov 20, 2019 | 03:27 PM
Beemerchef's Avatar
Beemerchef
You will love the NM module! Even on the 93 Octane setting...
Old Nov 20, 2019 | 04:45 PM
TRBOLAG R56
just installed it last night, ive driven about 70 miles with it since, cant say i've noticed a difference really. im sure ive hooked it up right.
Old Nov 20, 2019 | 05:49 PM
Beemerchef's Avatar
Beemerchef
If you have the ability to install the exhaust I am sure you hooked it up correctly. Yet, you might want to check again...
No code errors? Is the switch on the low? [maybe stuck in the middle?]
Worse scenario is to exchange it for another one.
Old Nov 20, 2019 | 07:45 PM
TRBOLAG R56
correct i have no CELs and I don't believe that maybe its stuck in the middle i will look again though and yes its on the low setting. maybe I'll also flick it to high and see if i can notice anything. is the difference with the tuner night and day? or is it something that I should kinda notice a little?
Old Nov 20, 2019 | 08:06 PM
Beemerchef's Avatar
Beemerchef
There is NO DOUBT you should feel it from the first mile. Of course getting better with time...
Be careful with the high setting while on 93 Octane as the JCW has a pretty high already compression.
That is what I was told anyhow as we only have 91 Octane here. I have never tried the 100 Octane setting... I would not want to get used to that! The stock suspension is already at its limit on the low setting even with the Cravenspeed Big Pair and the NM Engineering engine tie bar [which however both have helped...]
You see, once you start... there is no ending! I will however not change the suspension any further.
* Maybe push the connections also a bit harder together.
Mini-LSE
Factory JCW talk
Apr 27, 2013 10:48 PM
Rich.Wolfson
Aug 30, 2010 03:05 PM
kyungjomoon
Jun 9, 2009 06:55 AM
ngweibing
Aug 26, 2008 10:32 AM
