JCW Power Up!!!
Old Nov 30, 2016 | 08:11 AM
  #251
TheBigNewt's Avatar
TheBigNewt
Dinan does not have one for the Gen 2 MINI yet. Maybe in the future.
What's the best power module for my car do you think, as far as value goes?
Old Dec 1, 2016 | 09:02 AM
  #252
2017All4's Avatar
2017All4
Super Moderator
I've taken the plunge:
Old Dec 1, 2016 | 09:04 AM
  #253
We don't carry a power module or tune for the N18 Yet. But some people go the independent flash tune like Manic.
Old Dec 1, 2016 | 09:17 AM
  #254
Congrats
Old Dec 1, 2016 | 10:08 AM
  #255
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Got mine yesterday, will wait until service at dealership next week before install.
Old Dec 1, 2016 | 12:00 PM
  #256
chipfiev's Avatar
chipfiev
After living with the Dinan for a few weeks now, I have no regrets. None.
Old Dec 1, 2016 | 03:05 PM
  #257
2017All4's Avatar
2017All4
Super Moderator
Installation was straightforward but it's a bit tricky to line up the TMAP plug -- pretty tight in there between the radiator hose and the manifold. The sensor is mounted at a down angle so i used a needlenose to get it all lined up before locking it in. I unbolted the outboard 10mm bolt that secures the airbox, lifted that corner of the airbox assembly slightly, and slid the Dinan cable under so the fit is clean, as shown. (the bolt is near where I mounted the Dinan box).
Old Dec 1, 2016 | 03:22 PM
  #258
2017All4's Avatar
2017All4
Super Moderator
I'm a bit challenged with the iPhone app -- my phone linked with the Dinan easily but I'm getting readings that don't make any sense. I have a second call in to Dinan to get a little guidance. Surprised at the absence of any documentation/instructions beyond the simple installation guide on the Dinan web site.
Old Dec 2, 2016 | 05:24 AM
  #259
chipfiev's Avatar
chipfiev
Admittedly, the iPhone app leaves quite a bit to be desired. I've also found the boost gauge to be unreliable and simple configuration to be less intuitive than the Android version. My solution for this is to use a spare Android tablet when I want to play with the Dinan settings though, to be fair, I haven't changed it or used the boost gauge in a couple of weeks.
It would be nice for the iPhone app to work as well as the Android one does but, until then, I'll cope.
Old Dec 2, 2016 | 07:42 AM
  #260
2017All4's Avatar
2017All4
Super Moderator
My butt dyno says, even though the app is funky, this was $270 well spent:
Old Dec 2, 2016 | 08:24 PM
  #261
jessetaylor's Avatar
jessetaylor
How does it compare to the NM Engineering module? Sounds like the same thing for $130 less.
Old Dec 3, 2016 | 08:46 AM
  #262
TheBigNewt's Avatar
TheBigNewt
I think all 3 of them work pretty much the same way, including the JB+ unit.
Old Dec 3, 2016 | 09:02 AM
  #263
GPMini's Avatar
GPMini
I got a $100 ECS gift card with the KW coilovers I purchased a couple months ago. That + black friday sale = cheap Dinan! WOOHOO!
Old Dec 3, 2016 | 09:58 AM
  #264
2017All4's Avatar
2017All4
Super Moderator
NM is very robust packaging and longer leads. Dinan is less expensive and has blue tooth functionality (sort of). You can switch among modes from your smart phone with Dinan and it has a boost gauge on the free phone app. NM has 2 modes which are switched at the box under the hood.
NM and Dinan tap the single sensor (TMAP). JB 4 is more complex, taps more sensors, connects to the OBDII port under the dash, and has some cool instrument cluster features that use the tach and the turn indicators and the fuel gauge in 3rd gen cars. More $ for the JB.
The old JB+ isn't for B48's.
What you get with all of these is a few PSI added boost.
And you can feel it fo sho!
Old Dec 3, 2016 | 11:08 AM
  #265
al the mini man's Avatar
al the mini man
I have the TMC tuning modul fitted to my JCW and yesterday i had it on a rolling road at Arron Reeve Motorsport here in the UK.With it set on 4(mid power) it came out at 277.3 bhp and 286.9 lb ft torque.Very happy.
Old Dec 4, 2016 | 05:41 PM
  #266
BadakVT's Avatar
BadakVT
NM Engineering (Two Fixed Settings, No Bluetooth, TMAP Connection)
Low: +3 psi
High: +5 psi
Dinantronics (Four Fixed Settings, Bluetooth, TMAP Connection)
Valet: -3 psi
Sport: +2 psi
Sport+: +3 psi
Race: +4 psi
BMS JB4 (Two Maps Currently, USB/Bluetooth, TMAP/MAP/OBD)
Map 1: +4 psi
Map 2: +6 psi
From my dyno results, every psi is equal to approximately 8 HP and 8 ft-lbs on the B48/B46. Hence, just looking from power gain potential, the NM box might have a very slight edge on the Dinantronics.
I am running a JB4 on my F56 and a Dinantronics on the F48 X1.
Old Dec 5, 2016 | 09:42 AM
  #267
2017All4's Avatar
2017All4
Super Moderator
Low: +3 psi
High: +5 psi
Valet: -3 psi
Sport: +2 psi
Sport+: +3 psi
Race: +4 psi
Map 1: +4 psi
Map 2: +6 psi
Excellent detail. Thanks.
Old Dec 5, 2016 | 12:56 PM
  #268
2017All4's Avatar
2017All4
Super Moderator
NEW DINAN UPDATED iPhone APP.
I spoke with Dan at Dinan. They have reworked the iPhone app for the Sport Tuner. Should address connectivity and related issues, according to Dinan.
Old Dec 5, 2016 | 02:41 PM
  #269
2017All4's Avatar
2017All4
Super Moderator
New Dinan iPhone app version 1.1 is out
The new iPhone app is an improvement, once you get it working. Dan at Dinan walked me through the steps. After I deleted the old app and downloaded the new version 1.1 into my phone, Dan had me shut down my phone, reboot my phone, then, making sure my MINI was fully asleep and the red light on the Dinan box under the hood was not lit, I turned on the ignition (but did not start the car) and, upon opening the DinanS app, my phone found the Sport Tuner within seconds and I think the calibration was successful.
The bottom row of buttons on the phone screen for the various power settings now has white (instead of grayed out) buttons, the little blue down arrow is now a blue circle with a O instead of the down arrow, and connectivity seems to have improved.
Old Dec 5, 2016 | 02:44 PM
  #270
TheBigNewt's Avatar
TheBigNewt
Just curious, is there an Android app as well?
Old Dec 5, 2016 | 02:51 PM
  #271
Yes,
https://play.google.com/store/apps/d...bluegiga&hl=en
Old Dec 5, 2016 | 04:02 PM
  #272
MrMaxi's Avatar
MrMaxi
Hello everybody!
Just purchased the DINANTRONICS for my new F54 ALL4! I hope that I will see a little difference in a non-S cooper.
Old Dec 5, 2016 | 06:50 PM
  #273
2017All4's Avatar
2017All4
Super Moderator
Originally Posted by MrMaxi
Hello everybody!
You will!
Old Dec 5, 2016 | 11:56 PM
  #274
MiniF55's Avatar
MiniF55
This is making me want a Clubbie.
Old Dec 6, 2016 | 08:54 AM
  #275
Did you see the Clubman Sales? Looks like everyone wants one.
http://www.motoringfile.com/2016/12/...mbers-context/
