JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW exhaust
Old Aug 7, 2003 | 12:40 PM
mobygjc's Avatar
mobygjc
JCW exhaust
Question about the JWC exhaust, is it good??? any draw back that anybody has heard or seen? Thanks for all the info
Old Aug 7, 2003 | 12:57 PM
MGCMAN's Avatar
MGCMAN
Do you mean the JCW exhaust?
Old Aug 7, 2003 | 01:20 PM
OpusMini's Avatar
OpusMini
I can say that when I drove one I found the exhaust to be very unobtrusive and pleasant. Reviews of the JCW are guessing but they peg the power advantage as nominal a bit less than a regular Borla exhaust somewhere between 3-5 hp improvement over stock.
Old Aug 7, 2003 | 01:43 PM
mobygjc's Avatar
mobygjc
Only a little bit over improvement stock......as normal as borla exhaust.... This does not sound good to me. Won't I be better off to have like quicksilver exhaust??? or is the average on upgrade exhaust 3-5 hp? Another question I had was, With the JWC kit, I was going to add a Quicksilver or London Headers, now if I do this will the JWC exhaust handel this?? I don't want my exhaust to heat up so much that it begins to warp or do other under damage, because of flow problems, Thank you for all the info guyz.
I am the Question Man!
Old Aug 7, 2003 | 02:52 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The JCW kit exhaust (looks great in my opinion) is not so loud (in tune with the standard Borla for the MCS) probably gives slightly increased HP (est less than 6 HP) and should work fine with the London Stainless exhaust header upgrade.
As far as exhausts for the MCS goes there are many options that might be better than the JCW kit exhaust but the whole point of the kit is to stay within warranty and get the WHOLE upgrade kit. The kit's exhaust is just along for the ride so to speak-it's the other components of the upgrade that make the additional power.
Old Aug 7, 2003 | 03:00 PM
bbt4's Avatar
bbt4
i agree minihune; the JCW exhaust is the best looking one.
i hope they (MINI) release it as an option.
bbt4
Old Aug 7, 2003 | 03:06 PM
Moorlockx's Avatar
Moorlockx
>>The kit's exhaust is just along for the ride so to speak-it's the other components of the upgrade that make the additional power.<<
But couldn't a more freeflow exhaust design help make more power? and doesn't the JCW kit use the stock airbox?.....if so, then both of these are poor choices for a so-called performance kit.
I've heard the JCW exhaust and to me, it actually sounds a little quieter than the Borla. The sound doesn't come on until you get into the higher revs.
Old Aug 7, 2003 | 03:18 PM
minihune's Avatar
minihune
If the JCW kit exhaust sounds less loud than the regular borla then that is great because the borla was one of the most quiet exhaust options for the MCS. There isn't anything wrong with a quiet exhaust- except if you want to have a louder exhaust. HP gains tend to be on the modest side with the quieter exhausts.
Yes a better straighter free flow design would make more power and yes a better cold air intake would also help but this is not the aim of the JCW kit maybe. They have to look at their audience and figure out what combination of upgrades to offer.
Everything is designed with a certain balance in mind.
I don't know if I could call the intake and exhaust "poor choices" as I would be second guessing the intent of JCW. Why don't you email or call them and ask them why they did not do more. Maybe they are leaving room for improvement?
Old Aug 7, 2003 | 06:15 PM
red03miniS's Avatar
red03miniS
is it possible to buy jcw tips?
Old Aug 8, 2003 | 07:30 AM
marksmith's Avatar
marksmith
-JWC exhaust is fabricated for Cooper by Supersprint in Italy (or so says a BMW tech person at Mini HQ.)
-JWC exhaust can be installed w/o a center resonator using a Supersprint straight pipe w/ flange provide by Promini) for a clean looking system(it will be a meaner sounding exhaust & MAY create a marginal gain the low-end torque.)
-I will be installing the Supersprint headers w/ the JWC exhaust next week & will report back. Very straight-forward install.
FYI: My impression of the JWC exhaust after 3000 miles is very positive: The tone has deepened a bit, sounds great w/ the backseat folded down & is quite agressive from the outside (parking garage test & drive-bys.) Before the Works kit install I ran a Supersprint exhaust (sans center resonator) & I can not tell much if any difference in performance other than the subdued sound.
Old Aug 8, 2003 | 07:31 AM
marksmith's Avatar
marksmith
-JCW exhaust is fabricated for Cooper by Supersprint in Italy (or so says a BMW tech person at Mini HQ.)
-JCW exhaust can be installed w/o a center resonator using a Supersprint straight pipe w/ flange provide by Promini) for a clean looking system(it will be a meaner sounding exhaust & MAY create a marginal gain the low-end torque.)
-I will be installing the Supersprint headers w/ the JCW exhaust next week & will report back. Very straight-forward install.
FYI: My impression of the JCW exhaust after 3000 miles is very positive: The tone has deepened a bit, sounds great w/ the backseat folded down & is quite agressive from the outside (parking garage test & drive-bys.) Before the Works kit install I ran a Supersprint exhaust (sans center resonator) & I can not tell much if any difference in performance other than the subdued sound.
Old Aug 8, 2003 | 08:19 AM
mobygjc's Avatar
mobygjc
ty guyz, thanks for the info. 1 more question, if I wanted to go with a exhaust system that pushes alot of HP and I don't care about noise, which one would be the best on the market, Including HEADER setup too. I might just get the JWC kit, and replace the exhaust with a completely diffrent Exhaust system. Unless the aveage exhaust sytem only make just as much as the JWC exhaust.
dyeLucky
Sep 11, 2015 10:41 AM
Pyrs
R55 :: Clubman Talk (2008+)
19
Sep 8, 2015 01:43 PM
Longjas
Aug 24, 2015 06:06 AM
ASRman
Aug 13, 2015 09:33 AM
papawhiskey
Aug 10, 2015 09:31 PM
