Interior/Exterior New STRI gauges
Old Feb 23, 2007 | 05:08 PM
  #101
shooler's Avatar
shooler
Originally Posted by LordOfTheFlies
That's what I was thinking as I have the promini gauge kit (boost + oil pressure) that uses a brass T fitting there as well.
I thought perhaps there was an easier way. Do you have the sepcs on the T-fitting? Where did you get it? And how much if you don't mind sharing?
You can probably buy these pcs at any Home Depot or hardware place. There is the main pc that threads where the oil pressure sending unit goes. It has 2 "ports". One accepts the stock oil pressure sender and the other has an adapter that accepts the oil temp sender. I paid $8 for all the pcs. Don't forget to use anti seize and teflon tape when putting the pcs together. I'll post a pic in a bit.
Old Feb 25, 2007 | 10:31 AM
  #102
hosmer's Avatar
hosmer
Mine are installed and working
For the oil temp, I just used a M14x1.5 plug with the sensor already on it. I got it from ebay for like $12
This is actually the one I used.. VDO part # 323 055D
Old Feb 25, 2007 | 01:12 PM
  #103
newbs49's Avatar
newbs49
Are you sure the sensor is the same rating. Others have used the MINI sensor and their gauges read the temp wrong. Nice looking setup.
Old Feb 25, 2007 | 02:36 PM
  #104
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Same thing I was wondering. Tell us if you get correct readings
Old Feb 25, 2007 | 04:47 PM
  #105
hosmer's Avatar
hosmer
Its about 200-210 normal driving backroads
225 on the highway (85 mph)
230 spirited driving
Old Feb 25, 2007 | 10:58 PM
  #106
loveminis's Avatar
loveminis
Hey Hosmer, can you tell me where to hook up the T for the boost gauge? Where it has been installed now, the reading on the boost gauge needle only goes up to the 10 below the 0 reading. Can you explain which is the correct hose to splice it in to? thanks
Old Feb 26, 2007 | 06:28 AM
  #107
shooler's Avatar
shooler
I can help you with this. Under your intercooler (easy to remove) is the fuel pressure regulator (located about center of the block under the fuel rail). Pull off the line connected to the bottom of the regulator and tee into that. Make sure the connection to the regulator is tight or you will get low/false readings on the gauge. Run the other end to your gauge/sending unit. It's really easy to do.
Old Feb 26, 2007 | 09:50 AM
  #108
loveminis's Avatar
loveminis
thanks; I'll check that out.
Old Feb 26, 2007 | 02:35 PM
  #109
hosmer's Avatar
hosmer
yeah, thats where I have mine
One end of my tee was sealed/blocked...check yours out before you install it
Also, your gauge will read vacuum alot of the time...you really have to get on the gas up to/over 5k rpms to get up to 10psi
Old Feb 28, 2007 | 10:45 AM
  #110
loveminis's Avatar
loveminis
Since I'm new to minis and not particularly mechanically inclined as well I have a few questions. What should the boost gauge be reading at idle; at full acceleration? I see that the gauge reads from 0 to + 30 and down to -30. What about the water temp? Mine reads when warm about 190. this would help me know if they are installed correctly.
Old Feb 28, 2007 | 05:31 PM
  #111
hosmer's Avatar
hosmer
you can see in the pic that at cold idle my car is reading 12psi on the vacuum side
full acceleration - it'll usually jump to +5psi then climb up to between 8 and 10psi when you get over 6k rpms.
180-190 is normal water temp, you can get a low temp (160) thermostat also
Old Feb 28, 2007 | 07:52 PM
  #112
kapps's Avatar
kapps
Just for a comparison, the built-in water temp sensor (accessible through the trip computer hidden functions) shows between 87 and 93 C (188 - 200 F).
Old Mar 1, 2007 | 12:04 PM
  #113
loveminis's Avatar
loveminis
thanks, that helps alot
Old Mar 1, 2007 | 04:03 PM
  #114
KevinBaker's Avatar
KevinBaker
Hi Em, sorry have not had chance to let you know they arrived fine in Australia, have not had time to do anything apart from look at the boxes though .
Thanks again!
Old Mar 1, 2007 | 08:31 PM
  #115
StoopidGirl's Avatar
StoopidGirl
Thanks again!
YAAAAAY! glad I could help ou get a set all the way accross the big ocean.
I'm unable to post for a few days and wow! look at all the info woot
Old Mar 3, 2007 | 09:43 PM
  #116
golden_child
Where are you guys finding the easiest place to tap the power and illumination? I've followed DarkMiniCooperS's post but it's a pain in the @ss to get to the wires by the fuse panel.
thanks for any help.
Old Mar 4, 2007 | 05:24 AM
  #117
golden_child
Oh, Yeah does the dimmer work with where you hooked the wires up?
Old Mar 4, 2007 | 06:36 AM
  #118
shooler's Avatar
shooler
I used 2 "add a fuse" at the fusebox for 12v constant and 12v switched (very easy to do). For illumination, I tapped the gray/red wire from the harness connected to the tach. Again, very easy to do and the dimmer works for the gauges as well.
Old Mar 4, 2007 | 08:28 AM
  #119
StoopidGirl
Shooler I'm so glad you can help...I keep getting asked install questions and ufortunately I don't know much about the process. So thanks a million (and to everyone else who has helped)
Old Mar 4, 2007 | 08:37 AM
  #120
shooler's Avatar
shooler
No problem . Sharing my experiences is the least I can do to give back to the NAM community for all the valueable (mostly) info I have received.
Old Mar 4, 2007 | 12:39 PM
  #121
RoadFly's Avatar
RoadFly
Ok heres my gauges finaly installed !!!
https://www.northamericanmotoring.co...43796&cat=1590
sorry its a link but I never can get photos to post
Old Mar 4, 2007 | 01:09 PM
  #122
Tüls's Avatar
Tüls
Turbius Maximus
OooooooOOOOoooo I like the pillar pod... very nice!!
Old Mar 5, 2007 | 08:48 AM
  #123
StoopidGirl
yeah seriously impressive set up....mmmmmmm perty
here's the "OFF" position for everyone to see
Old Mar 7, 2007 | 01:14 PM
  #124
golden_child
Shooler--
Thanks for all your help on this. I plan on doing the Add-A-Fuse this weekend. are you using a 5 or 10a fuse on the I counldn't find the amperage draw on the gauges or I just missed it.
I'd like to use the smallest fuse possible so I won't blow out the gauges.
--golden_child
Old Mar 7, 2007 | 06:17 PM
  #125
shooler's Avatar
shooler
Shooler--
--golden_child
Happy to help! I am using a 10 amp fuse in both constant and switched.
