Interior/Exterior Urgent advice needed on fitting Aero sideskirts
Old Nov 19, 2006 | 02:14 AM
fozworth's Avatar
fozworth
Im fiiting my Aero side skirts tomorrow but am a little worried about one part of the fitting.
In the instructions it says to fit the skirt to the car in the following order,first attatch with the clips then fix the underside poppers and finaly peel the double sided fixing tape from the underside of the top of the skirt .This is what im concerned about.surly once all fixings are in place you wont be able to lift up the top of the skirt to peel the tape back or does the skirt flex enough in order to get hold of the tape.
Old Nov 19, 2006 | 04:48 AM
TWISTER's Avatar
TWISTER
pull the tape back approx 5 inches on each side so u can grab them once its on the car. fold those ends toward the interior
Old Nov 19, 2006 | 06:48 AM
fozworth's Avatar
fozworth
Ok thanks but dont the exposed sticky ends end up sticking to the top section of the sill before you want it to.?
Also the black foils that stick to the front bumper around the lower spots,well \are they included in a full Aero kit or do you have to buy them.
Old Nov 19, 2006 | 07:22 AM
TWISTER's Avatar
TWISTER
they might, but just try and not let them
black pieces and tow cover are sold seperately. MINI screws us on these
Old Nov 19, 2006 | 07:45 AM
fozworth's Avatar
fozworth
cheers,
Old Nov 19, 2006 | 08:52 AM
Red Ryder's Avatar
Red Ryder
Coordinator :: Tar Heel MINI Motoring Club
BMW cannot part with the tow cover as part of the kit. I had to purchase mine for a whopping $0.85. Can't imagine how much not including these in the kit adds to the profit for the company.
Old Nov 19, 2006 | 09:30 AM
fozworth's Avatar
fozworth
What about the black foils that fit either side of the radiator grill ,are these included.Plus the turning signal lenses that fit on the bumper,are these included,or if not how much are they.
Old Nov 19, 2006 | 11:57 AM
Smokey's Avatar
Smokey
According to the instructions, yes the decals (foils) are included. As far as the lights go; you have to mod your current ones to fit. The instructions show how to do it. You basically have to cut about 1/2" off one of the tabs. The instructions also call for the movement of the fog lights, that is only required if you are fitting a kit on a Cooper. The MCS lights are already in the correct location.
Peeling back a little of the covering on the adhesive strip won't hurt anything. Just make sure you have cleaned the doorsill with rubbing alcohol. To help hold back the ends of the covering I taped them to the top side of the sideskirt, that way they didn't work their way back under the sideskirt.
Good luck and make sure you have enough of each type of body clips. When you remove the current sideskirt, the chance of reusing any of them is slim.
Old Nov 19, 2006 | 12:35 PM
fozworth's Avatar
fozworth
As im using a new kit i think all the clips come with the kit
SosoMINI
Nov 22, 2015 03:17 PM
Aug 12, 2015 01:24 PM
mdorn98
Aug 11, 2015 08:49 AM
