Interior/Exterior Driving light ideal mounting location for actual use?
Old Jan 31, 2012 | 04:59 PM
VtwinPower's Avatar
VtwinPower
Anyone have advice on where the best lighting is projected from? The upper grill or the lower?
I've got the two 500ff's & 100w h3 replacement bulbs and now I'm debating on where I should mount them.
Anyone have a light spread picture? A picture to use for reference? Also outmotoring selling the adjustable brackets, but they are only as adjustable as your heart can be when hacking away at the lower facia grill.
I would assume that mounting them on the bottom would render them almost useless unless they were fogs. I will actually be using these.
Recap:
I have two driving lights, lower vs upper mount? (upper or lower grill)?
Old Jan 31, 2012 | 06:07 PM
inh's Avatar
inh
The lower you mount the, the longer shadows are going to be for things in the road, and over hilltops.
Old Jan 31, 2012 | 07:03 PM
TSR53's Avatar
TSR53
The best place to mount Hella 500FFs is higher up. You want the beam pattern to be on the road.
Unfortunately, for the MINI R53, that means mounting the Hella 500s in the flow of the radiator and high, they don't look too good as they are larger than the curve of the bonnet and will stick up.
I mounted my rallye lights in front of the bumper as this is the best place for my driving conditions in Vermont. The lights I have are also H4 bulbs and feature low and high beams in each light. This allows me to toggle on high beams when going down a hill and there is an uphill approaching. Also when coming over a crest of a hill, the low beams work great and don't point into the trees.
If you can find the kit that mounts them in the middle would be the best. They won't be in the way of the radiator and will work. I think outmotoring.com sells these for the R56 or the Alta kit? You can also try to fabricate something like I did.
Full write up
http://www.tsrennsport.com/weblog/?page_id=404
Old Feb 1, 2012 | 12:35 AM
MiniKar's Avatar
MiniKar
Check with the State laws as to how high or low you can mount Aux driving lights.
Also find a way to make sure its not easy to remove the lights as I am sure some kids would love to take those off your car for you.
Old Feb 1, 2012 | 01:30 AM
Doug Fowley's Avatar
Doug Fowley
TSR, When you get a chance I would love to see these lights without the covers. Thanks, doug
Old Feb 1, 2012 | 06:46 AM
VtwinPower's Avatar
VtwinPower
Thanks TSR for the helpful insight. I ordered the bonnet mounted brackets as for the time being I don't have the time to design one off brackets. Thanks MiniKar, I would think the airborne sticker on the back would deter them...if only they knew the firepower my EB r53 carries. :0 I'm thinking some sort of special locknut? I was actually thinking the same thing, "what would deter an adolescent male from removing my lights"...I really like those piaa 80's. They are quite large I might add. And to think that I thought that my 100w replacement lamps would be adequate. Looks like I have some competition. Good thing I purchased some replacement D2r's. Hey TSR, how difficult were those brackets to fab? I'm assuming Home Depot has the pieces I need. If so I would really like them mounted where you mounted yours. Looks especially cool since they aren't mounted to the bonnet.
Appreciate the advice,
Christopher
Old Feb 1, 2012 | 07:38 AM
BlwnAway's Avatar
BlwnAway
Brackets:
http://www.outmotoring.com/mini-coop...-brackets.html
Also don't forget, when it comes to some factory parts, (driving light brackets & driving lights for example), vendors who also work on Mini's will sometimes have used as well as new parts at reduced prices.
http://www.detroittuned.com/shop/
http://www.waymotorworks.com/
http://www.helix13.com/
Old Feb 1, 2012 | 08:45 AM
TSR53's Avatar
TSR53
Originally Posted by BlwnAway
Yes, these are the correct middle mount brackets. I would have used these for a set of Hella Rallye 1000 Black Magics or Hella 500s. But, as I said at the shop we had the PIAA 80 Racings on the shelf for a great price.
Old Feb 1, 2012 | 08:49 AM
TSR53's Avatar
TSR53
Here you go.
Attached Thumbnails Driving light ideal mounting location for actual use?-img_1751.jpg   Driving light ideal mounting location for actual use?-img_1752.jpg   Driving light ideal mounting location for actual use?-img_1749.jpg
Old Feb 1, 2012 | 08:54 AM
TSR53's Avatar
TSR53
Originally Posted by VtwinPower
Thanks TSR for the helpful insight... Hey TSR, how difficult were those brackets to fab? I'm assuming Home Depot has the pieces I need. If so I would really like them mounted where you mounted yours. Looks especially cool since they aren't mounted to the bonnet.
Christopher
Not that hard, but, they were extremely time consuming to fabricate. I must have taken the front aero kit on and off at least 10+ times, took over a full weekend. The end result is exactly what I wanted. I guess it would have gone quicker if I used a band saw and a drill press at the shop. I took my pokey time at home instead - cut everything, drilled and rat tail filed, painted all by hand.
Old Feb 1, 2012 | 09:16 AM
05Greenie's Avatar
05Greenie
I have Hella 500's on my MINI with the outmoroing mounting brackets.
The install was fairly easy. I had to remove the front spoiler to mount them, not a tough job at all.
Old Feb 1, 2012 | 10:53 AM
IQRaceworks's Avatar
IQRaceworks
Those lights look great! Are the Hella 500's a pretty popular light for the mini's? Any "how to" writeups on wiring them up?
Thanks!
Old Feb 1, 2012 | 02:41 PM
VtwinPower's Avatar
VtwinPower
IQ, as for wiring there are two options. You could wire them in parallel with your highbeams using a relay etc. Or go the route I will be and wire them independently so I have the controls specifically for those at my fingertips. As for wiring writeups. Well just check out outmotoring I believe and they have the OEM driving lights manual there. Just a matter of the supplied on/off switch, power & ground and an inline fuse. Not sure the amp for the fuse yet. Find a grounding point and make sure to attach that before the power. Find an engine mount bolt or something that is anchored to the physical body w/o paint covering the metal's natural surface. Run the power back to your battery and make sure to install the inline fuse before attaching it to the positive post. You have to do this twice I believe, one for the switch as well as the lights themselves. Two grounds but most likely one hot wire from the switch since that'll be controlling the circuit.
As soon as I get back from Korea I'll take some pictures to explain.
I couldn't bring myself to spend 110 plus shipping on brackets when the lights costed 69 bucks with a set of 100w bulbs.
DIY Links
Alkaidovich
Jan 30, 2021 01:35 AM
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
Phantogram
Aug 12, 2015 12:11 PM
joelcseymour
Aug 7, 2015 12:43 PM
