Interior/Exterior 03 joey mod help
Old Jul 23, 2010 | 04:10 PM
soccerbummer1104's Avatar
soccerbummer1104
03 joey mod help
hey guys, im attempting to do a joey mod of my 03 factory xenons.
i know its supposed to be hard,
but after 15 min in @230 in the oven And using a heat gun, the stuff still doesnt melt, the plastic housing (black part) becomes soft-ish and slightly deforms when i try to pry the lens off, and will go back into shape when pressed back, but the lens will not move.
any suggestions? longer in the oven?
Old Jul 23, 2010 | 05:33 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Sounds like it was too hot, and where to pry is key.
https://www.northamericanmotoring.co...t-halogen.html
Post number 9 - https://www.northamericanmotoring.co...t-halogen.html
difficult with preface lift but apparently not impossible. JaMills worked it out.
Old Jul 23, 2010 | 06:50 PM
soccerbummer1104
hmm well i got a sliver of the black stuff out from one of the eposed beads, and hit it straight with the heat gun to see how hot i had to get it for it to turn soft or melt and nada. didnt melt under direct heat for 30 sec with the heat gun, didnt even smolder or anything, just got slightly softer, but not tacky or anything.
Old Jul 24, 2010 | 07:05 PM
Jahmills's Avatar
Jahmills
I tried heating them but it did not work, that glue is basically the consistency of plastic. I ended up cutting them open with a dremel tool w/1.5" cutting disk, just below the lip where the plastic lens sits in the light housing. Then slowly chiseled out all that glue I used fiberglass mesh tape with silicone glue to put it back together. It's been a couple of years, but it's held up great, no problems with the lights. The only thing I can offer at this point, is that it's very hard & time consuming, in my case about 2 weeks from start to finish. I wish I could offer more help, but I basically just went at it slowly, feeling my way as I went. But like I said, if you start by cutting at the base of that lip, then it all sort of makes sense as you go along.
Old Jul 24, 2010 | 07:36 PM
-=gRaY rAvEn=-
Moderator
Holy cow, that was some job !
Old Jul 26, 2010 | 01:39 PM
soccerbummer1104
haha, that takes "once you go black there aint no goin back" to a whole new level :P
(talking about the blacking out of the lenses guys..)
i may do that eventually, but for now i dont have the money to spend on a replacement headlamp if i screw these up.
Old Jul 26, 2010 | 01:50 PM
soccerbummer1104
btw, what kind of paint should be used to do a joey mod? my car is black ( i thought it was astro, but everyone in the club says its more black than that and think its midnight.)
gloss or flat?
should i wet sand down the faux chrome that i am going to paint first?
plasti-dip?
any priming necessary?
Old Jul 26, 2010 | 03:09 PM
-=gRaY rAvEn=-
Moderator
NO Plastic DIP !
Gets hot in those housings. I have not heard where it is necessary to prime but I would at least use Adheasion Promoter spray. I found the stuff when painting interior plastic parts, and it works well as a primer.
If you check the pass side front fender after lifiting the bonnet, there should be a black decal with a 3 digit paint code for your car and the color name imprinted with it. If there happens to only be a code, you would have to look it up or call a MINI dealer.
I also was under the impression that Way of Waymotorworks.com was picking up the task of selling OEM MINI paint in spray cans like Pete sold at Minspeed.net These spray cans are great for small parts projects just like this.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
