Interior/Exterior Discreet GPS mod
Old Sep 22, 2009 | 09:29 PM
Supercoop55's Avatar
Supercoop55
Discreet GPS mod
Okay, I'll start this with the disclaimer that lots of thought went into the location of the GPS, and this is not the best location. It is instead a compromise arrived at due to the following motivation: A recent rash of thefts where the criminals looked for the GPS mount or tell tale GPS suction cup ring left on the windshield in the morning condensation, not wanting to see a power cord dangling, and a "mini" glovebox where the GPS occupies prime real estate.
The best location seems to be next to the tach, which many mounting kits are available for. Problem with that is it is still noticable and it prevents adding piggyback guages. So the visor it is. It already has a power source, it's as easy to glance at as the rear view mirror, and folds up for zero visibility. You can even fold it up and listen to the directions sans the screen.
Here's where the compromise comes in; The taller you are, the more the visor being down blocks your view. For shorties it's great though.
I push the visor all the way against the windshield which makes the screen less visible, but opens the view.
The mod is not terribly difficult. A few hours should do. Start by unscrewing the visor and unplugging the vanity molex.
Next, slide a flathead between the vanity housing and visor and pop out the vanity
Using the GPS mounting clip provides a solid mount and the ability to easily remove the unit to take with or use in other vehicles. This also ensures that with the window down and visor pointed out the window, your GPs will not end up bouncing down the street. Cut through the first layer of plastic to flush mount the clip. Use plastic epoxy and be sure to abrade the mounting surfaces before applying. Do not put epoxy on the upper third of the clip. This will leave it free to flex for GPS removal. The key in this step is to create a recess for the power plug. Slip an insulator between the visor and registration strap. That will protect it from the heat necessary to mold the recess. A pyropen with shrink attachment works great for heating the plastic. Once complete, remove the insulator and all that is noticible from the other side is a slight bump.
Since the GPS plug houses a 5v power supply, it is easiest to cut the end off and solder on the vanity plug from the vehicle. This will mate with the plug on the vanity, maintaining it's disconnectability.
Solder the cut end inside the visor and you have effectively routed the power supply into the visor using the factory mini disconnect. Observe polarity.
Cut the lid of the vanity into trim pieces and epoxy in place on the left and right.
Solder about 2' of wire to the input of the GPS plug. Remove factory clock and run the power supply input and output (already with factory plug installed) wires to the visor opening. Connect the power supply input wires to the factory wires that fed the visor. Observe polarity. Plug in the visor and mount.
Wrap the power supply in something soft to prevent rattles in the overhead.
Place in void to the left of clock.
This step is optional. I wired a switch to the power input so that the GPS would not turn on every time I turned the key on.
Sorry this is hastily put together. I'm not sure if anyone will find merit in this mod, but if there is interest, I'll clean it up and expand on the details.
Tim
Old Sep 22, 2009 | 09:57 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Good work there. Do you need the gps on a daily basis or something? On trips I take the gps out of the car at hotels.
Old Sep 22, 2009 | 10:35 PM
M3NTAL's Avatar
M3NTAL
neat idea! well executed.
Old Sep 22, 2009 | 10:52 PM
Eric_Rowland's Avatar
Eric_Rowland
Very nice! I've got the factory Nav, but this is a great option for those who don't. Just had a friend who got to buy a $300 window to replace a $150 Nav.
Old Sep 23, 2009 | 04:53 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Well done!
Old Sep 23, 2009 | 04:57 AM
N2MINI's Avatar
N2MINI
I like!!!
Old Sep 23, 2009 | 05:35 AM
rhawth99's Avatar
rhawth99
Really creative thinking! Nice job!
Old Sep 23, 2009 | 06:29 AM
ron-s mini's Avatar
ron-s mini
Ingenious - Nice Works
Old Sep 23, 2009 | 07:23 AM
markusw's Avatar
markusw
Nice mod!
Old Sep 23, 2009 | 07:32 AM
Bigshot's Avatar
Bigshot
But I need to see out of the windshield..........
Old Sep 23, 2009 | 07:33 AM
Tall Mini's Avatar
Tall Mini
cool
Old Sep 23, 2009 | 07:44 AM
Supercoop55
Ironically enough, no. I use it infrequently, so I tend to forget it when I go places. This gives it a home and the ability to take it out. (also why I don't mind the compromise of location)
Old Sep 23, 2009 | 07:47 AM
Supercoop55
Details, details, Bigshot
Old Sep 23, 2009 | 08:12 AM
iwashmycar's Avatar
iwashmycar
very sleek. nice work!
Old Sep 23, 2009 | 10:15 AM
jbkone's Avatar
jbkone
Great work! Just wondering if you could put the internals of the power supply in the visor as well and just leave the visor wiring as it is? That way you don't have to mess with the clock at all. And you could put your switch there somewhere too. Hmm... maybe the visor isn't powered if the lights are off?
Anyway, clever idea
Old Sep 23, 2009 | 11:14 AM
Supercoop55
Tried that
Anyway, clever idea
The actual power supply with no casing was too tight a fit between the front and back cover. The in line filter just below the plug also kept me from fitting it in there. I originally hoped it would all fit nice and consolodated in there (was surprised at the size of the board). Just as an FYI the visor is powered with the rest of the accessories, so it will work as long as the key is on and for 15-20 mins after removed.
Old Sep 23, 2009 | 11:22 AM
STLMINI's Avatar
STLMINI
Great idea! How's the reception?
Old Sep 23, 2009 | 11:55 AM
Supercoop55
I've noticed it picks up the sats faster. Could be in my head, or as a result of being higher in the vehicle.
Old Sep 23, 2009 | 01:04 PM
NightFlyR's Avatar
NightFlyR
That came out real nice, if I did not have the factory Nav ( and I wish I did not) I would look to do that
Old Sep 23, 2009 | 01:29 PM
Supercoop55
Thanks to all for the great responses! This is a great community To think I was hesitant to post a project.
Old Sep 23, 2009 | 02:12 PM
jbkone's Avatar
jbkone
Originally Posted by JRoca
... if I did not have the factory Nav ( and I wish I did not) I would look to do that
Wouldn't it be nice if some automotive company would license Garmin's GPS for it's cars? I mean, why couldn't BMW or whoever just stick a Garmin in there!
Old Sep 24, 2009 | 06:46 AM
N2MINI's Avatar
N2MINI
In the end it probably comes down to MONEY!!!
Old Sep 24, 2009 | 10:41 AM
wyefye's Avatar
wyefye
hah, i wish i didnt have the stupidly huge spedometer in the center of my dash...
Wanna trade?
actually, i would be willing to get rid of my single tach above the steering, and the speedo with appropriate mounting bezels in return for a trade of the dual cluster and just the empty nav bezel and rings. they are extraordinarily easy to switch out. i dont know if coding is needed or not though.
if your interested. pm me.
-Ryan
Old Sep 24, 2009 | 02:34 PM
MrCooperS's Avatar
MrCooperS
Moderator
That's not a bad idea at all. Looks great. Very innovative.
Old Sep 24, 2009 | 02:51 PM
ElPolloDiablo's Avatar
ElPolloDiablo
Great idea! I think I may have to give that a go!
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
