Interior/Exterior M7 Vortex scoop
Old Mar 14, 2009 | 02:20 PM
ac415's Avatar
ac415
M7 Vortex scoop
I just put it on! I had it painted glossy black. Im still on the fence if I want to keep it. Something tells me I should black out the chrome.
Old Mar 14, 2009 | 02:31 PM
Bigjoeski08's Avatar
Bigjoeski08
Yes the scoop looks great but black out some chrome and it will look a lot better.
Old Mar 14, 2009 | 03:15 PM
SmokeM's Avatar
SmokeM
Friends don't let friends drive with chrome....finish the job you started.
Old Mar 15, 2009 | 07:00 AM
TerryD's Avatar
TerryD
More air modification
I got an M7 V scoop and did some modifying to create a larger opening in the stock hood scoop.
There is an obstruction behind the stock scoop that blocks half of the opening. The above picture is a view with the stock scoop removed.
The above is a picture of the practice cut. I wanted to see how easy the cutting would be and if the blade would follow the line I wanted. The final cut, followed the line just below the practice cut where the 2 pcs. of sheet metal overlapped. After the cut, I burnished everything smooth so it would be safe to fingers and a good surface to prime.
This is a view of how open the scoop is after the cut. The cut is smooth and straight. The irregularities are corrugations in the metal, not jagged lines.
Old Mar 15, 2009 | 07:12 AM
TerryD's Avatar
TerryD
Part II
I also slightly modified the scoop by removing a bit of the material as shown below. This is the bottom of the scoop. The line is the cut line that will make the scoop opening just a bit wider.
After the cut, I smoothed everthing to remove sharp edges and test fit the scoop.
Now its off to the painter.
The following is a picture of the pcs of material removed from the hood. Note the profile that diverted and blocked the air.
Thats it. It is now much more open. The thought behind this was/is, why have a CAI if no air gets in.
Old Mar 25, 2009 | 04:46 PM
ac415's Avatar
ac415
thanks for the info!!
Old Mar 26, 2009 | 06:18 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
Do you have much rain where you live? I'm curious how much water is able to collect around the coil packs. I live in the Northwest (lots of rain), and felt that the little up turned lip collected water that would otherwise collect around the coils.
Old Mar 28, 2009 | 06:16 AM
dtsoccer6's Avatar
dtsoccer6
I got one too, painted it body color, you could try that too!
I also have the AGS-R, a very good compliment lol
Attached Thumbnails M7 Vortex scoop-dsc01136.jpg   M7 Vortex scoop-dsc01135.jpg
Boverphoto
Jul 3, 2017 10:56 AM
Tortie
Oct 8, 2015 07:40 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
Sep 3, 2015 01:45 PM
