Interior/Exterior Black Web Spoke Rims 17's
Old May 19, 2008 | 11:15 PM
speedmini's Avatar
speedmini
I have 06 MCS that came with 17 inch Web Spoke Rims and i'm thinking of powdercoating them matte black. Does anyone have a picture of their Web Spokes powdercoated. I'm curious to see how they look.
Old May 20, 2008 | 12:18 AM
glnr13's Avatar
glnr13
uhhh how about spray painted black with a matte clear
Old May 20, 2008 | 08:36 AM
speedmini's Avatar
speedmini
Wow looks nice!!! That basically solves my problem. I'm going to have it done but i'm going to change it up and have them done all black. I was going to purchase a set of rims but I like the web spokes to much to give them up. Did you do these yourself or at a shop? They look really nice!!
Old May 20, 2008 | 01:55 PM
glnr13's Avatar
glnr13
thanks i disassembled, painted, clear coated, and reassembled them in my back yard
Old May 20, 2008 | 03:14 PM
miniconcarne's Avatar
miniconcarne
Going to do something similar. Any more issues with the Ti bolts backing out?
Old May 20, 2008 | 03:24 PM
ngweibing's Avatar
ngweibing
is it a EASYYYYY job?
Old May 20, 2008 | 03:31 PM
speedmini's Avatar
speedmini
Yeah I heard it was pretty easy, but alot of people recommended powdercoating so it will last longer. How long have you had your rims painted and did you run into any issues with the paint?
Old May 20, 2008 | 06:03 PM
Malcon's Avatar
Malcon
i've been thinking about doing this for a while.. but I'm thinking about dark silver...
Old May 20, 2008 | 08:40 PM
glnr13's Avatar
glnr13
ah, you remember my situation nope, last i checked with a torque wrench and they are all still in place nice and snug. mustve been a bad batch of loctite i had /shrug
it's fairly simple, just time consuming. 56 bolts total, cleaning, sanding, more cleaning, paint, more paint, clear, more clear, reassemble.
daily driving these wheels and i've had the paint on since the weekend before amviv with no scratches/nicking/pitting.
Old Mar 15, 2010 | 04:01 AM
James B's Avatar
James B
heja,
I just did the upgrade - what do you think?
Old Mar 15, 2010 | 09:35 AM
glnr13's Avatar
glnr13
factory painted or custom? looks good either way
Old Mar 15, 2010 | 10:02 AM
LaLa Rocks's Avatar
LaLa Rocks
looks good. I just picked up crown spoke 17's I'm going to powder coat white gloss with a flake.
Old Mar 19, 2010 | 03:31 AM
James B's Avatar
James B
hi,
I just get them painted.
Old Mar 23, 2010 | 01:12 PM
jsilvers3043's Avatar
jsilvers3043
This is what I did to my fathers... He gets compliments on them all the time.... I also put the dice to mess with him...
Old May 22, 2011 | 08:57 PM
SaintR56's Avatar
SaintR56
Hey jsilvers3043 how did you paint them?
Old Jun 26, 2012 | 08:52 AM
bugman58's Avatar
bugman58
painting black spoke wheel
This is to 6th Gear - I am thinking of doing the same to my wheels, I have the same wheels - BUT how do you get the screws out, looks like they take a special tool, what tool, where do you get it or what did you use??? And are the rims sealed to the face of the wheel, did you have to beat it off? Looks great by the way!!
Last edited by bugman58; Jun 26, 2012 at 08:55 AM. Reason: to make clear who I was asking
Old Jun 29, 2012 | 12:36 PM
bugman58's Avatar
bugman58
also does anyone know the torque pressure needed to screw the screws back in when putting the black web spoke wheel back together, if not torqued right its not safe!!
Old Jun 29, 2012 | 01:00 PM
PapaVolume's Avatar
PapaVolume
are they a true multipiece wheel? I want to paint the ones on our 08 MCS too, but have been wondering about doing them all black, or black with the polished lip and chrome bolts and what the best procedure would be to do the latter.
Old Jun 29, 2012 | 01:48 PM
bugman58's Avatar
bugman58
Yes they are a true two pice wheel. However I am giving up, I dont know where to find the tool/bit to take out the screws or the torque lbs needed to put them back together right, no one seems to know, I emailed Ronal but no answer. Poweder coating the face would be easy and not expencive but I do not want to strip out the heads or drive on the wheels if there not set right.
Old Jun 29, 2012 | 01:51 PM
PapaVolume's Avatar
PapaVolume
in another thread I read it was an 8mm 12 point hex tool that is needed(ive been doing my research since my last post)
https://www.northamericanmotoring.co...23-post17.html
Old Jun 29, 2012 | 02:00 PM
bugman58's Avatar
bugman58
If you find out any more let me know - and thanks!!!
Old Jun 29, 2012 | 05:11 PM
miniconcarne
The tool is a triple square drive, got mine at Autozone. You will need blue loctite for reassembly. Be carful, these bolts are titanium and you can not
buy them if you break one. Also be aware of powdercoat build up, making
the center piece tight. DO NOT try to suck down center with the bolts if fittment is not right. Trust me.. If I remeber right, torque is only 18-20
foot lbs. for these guys.
Mine: Gloss black/clear centers with body color rims.
Old Jun 29, 2012 | 08:58 PM
bugman58's Avatar
bugman58
Did you break one? Being Titanium I would think they are not easy to break?? After powder coating should we file off any powder build up if they dont fit tight at the center? Also are they sealed in any way?
Old Jun 30, 2012 | 06:05 AM
bugman58's Avatar
bugman58
Also we need to know for "sure" what the torque pressure is for the titanium screw/bolts, I have been told all the way from 18 to 24 lbs per (it must be per inch) of pressure, too tight and you can break the head, (not good!) not tight enough its not safe. Can anyone help with this? thanks.
NYXF56JCW
Nov 17, 2024 05:06 AM
Dec 23, 2015 10:36 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
caiken
Aug 27, 2015 06:55 AM
skippermini
Aug 12, 2015 10:05 PM
