Interior/Exterior Joey mod R56!
Old Jun 29, 2008 | 11:25 AM
  #201
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by davo_florida
also would there be any risk of re-opening the light to clean it? how many times do you think you can cook the poor bastards?
I personally, would be ok opening it one more time. But repeatedly, could cause and issue, but mostly to the glue, which this time it appears you might add a little something to it anyway.
Use some GOOD plastic cleaner when you have em apart to get the smudges, off and not leave any other issues behind.
GOOD LUCK! Let us know if we can help further!
Old Jun 30, 2008 | 10:12 AM
  #202
x SPUD x's Avatar
x SPUD x
sweet! i think yours is the first ds i have seen. have any 3/4 shots of the whole car? i cant decide if i want to do mine black or a dark silver inside the lights so i was hoping to see the black on yours. also, did you paint the rings ds also? thanks
Old Jun 30, 2008 | 11:59 AM
  #203
davo_florida's Avatar
davo_florida
its hard to photograph due to the reflections. I did the xenon rings DS and the chrome bits a semi gloss black.
Old Jul 5, 2008 | 04:26 PM
  #204
mellotron's Avatar
mellotron
yo joe!
thats the DIY clear lens job too.
What does that mean? Can you actually get or make new turn signal lenses for the headlights?
Your joey mod is lookin' good!
Here is what I did to mine:
https://www.northamericanmotoring.co...38#post2346338
Old Jul 6, 2008 | 03:32 PM
  #205
davo_florida
same thing you did. just removed the lens. until they sell it solo, this is it for me. where did you get your bulbs?
Old Jul 7, 2008 | 12:32 AM
  #206
Coen_de_K's Avatar
Coen_de_K
Can you JUST remove it.. is this easy?!
isn't it possible to buy a white reflector somewhere and cut it in the right shape?! Just an idea...
:D
Coen
Old Jul 7, 2008 | 07:01 AM
  #207
davo_florida
yeah you dont have to split the headlight to get the whole turn signal out. it is held in by 4 torx screw i believe. its really simple once you look at it.
im sure a clear lens could be made from something... im not THAT crafty. i'd love to see someone make one though.
Old Jul 7, 2008 | 05:29 PM
  #208
mellotron's Avatar
mellotron
Thanks! I ordered them here:
http://www.motorbulbs.com/product_in...roducts_id/140
These bulbs have offset pins which made them not fit. Maybe because my turn signals were designed to have clear bulbs? My husband dremeled one pin off each bulb, then they fit just fine. I do not know if the offset pin slots are different for MINIs that came with amber bulbs & clear lenses to begin with.
After all that, I found this site:
http://www.visionbulbs.com
The 'Silver Extreme' item looks like the same thing, but with different options including pins that would've fit. (1156/7506)
Either way, its over $10 a bulb.
I would also like to see someone come up with a way to make the lenses.
In your pictures, the 'naked bulb' doesn't seem to stand out as much as mine does. That's why I thought you had some clear lenses.
Old Jul 7, 2008 | 07:51 PM
  #209
pillar's Avatar
pillar
let me get something straight... i didnt get the white turn signals for my mcs and now i am fully regretting that decision. To my understanding, one can purchase light bulbs that do not have the amber color but shine bright orange when turned on, HOWEVER, one CANNOT purchase a clear lense that would replace the stock orange turn signal lense in the front of the cooper.
The only thing preventing me from doing the joey mod is that i dont think it will look good with the orange lense cover that i currently have. anyone know any alternative besides completely removing it?
thanks~!
Old Jul 8, 2008 | 04:39 AM
  #210
davo_florida
you've got it.
Old Jul 8, 2008 | 10:42 AM
  #211
pillar's Avatar
pillar
i guess ill wait untill someone decides to make it....
Old Jul 9, 2008 | 08:15 PM
  #212
pillar's Avatar
pillar
anyone else having issues with their paint blistering? i plan on using the satin black krylon fusion with some krylon primer. I guess engine paint can solve this problem but it can still warp the plastic which is what i fear the most currently. ghosthound... hows that heat shield working out for you? any issues with the double sided foam melting?
Old Jul 9, 2008 | 09:35 PM
  #213
ADAMSALTAMINI
no issues here!
Old Jul 9, 2008 | 09:41 PM
  #214
checkercoop's Avatar
checkercoop
No paint bubbling here (though I have halogens not the xenons...I used only the krylon satin, no primer, and I have no bubbling even on the metal cover thing for the light
Old Jul 9, 2008 | 10:06 PM
  #215
fongaroos's Avatar
fongaroos
thats weird... i guess its just luck. some people have had no problems with the joey mod, and others have said that the heat is so high that a heat shield is necessary...
at first i thought perhaps it might have been different brands of paint, but for the majority people are using the krylon fusion (with no sanding and no primer)
Old Jul 10, 2008 | 08:07 AM
  #216
pillar's Avatar
pillar
wonder if its nessesary to even sand down the surface with some steel wool and priming... im not an expert with this stuff but whats the point of purchasing krylon fusion if you are gonna coat the plastic with primer?
edit: did a test run on some clear plastic, one without primer and one with... def. a difference in coat eveness, and the one with primer looks a lot glossier than the one without.
Old Jul 12, 2008 | 12:36 PM
  #217
enron29's Avatar
enron29
Quick question. Hopefully someone can help me right away. How do you guys clean the smudges off the reflector part after removing the tape? Please help asap. Thanks.
Old Jul 12, 2008 | 04:00 PM
  #218
enron29's Avatar
enron29
Ok guys, just finished. Had a couple errors. On one, I rubbed the reflector portion too hard rubbing off the mirror finish. So that sucks. Anyone know a fix for that? Some type of mirror tape??? And I have smudges on the other one because I was afraid to wipe it down too much. How does everyone clean the smudges from the tape off the reflector portion???
Old Jul 12, 2008 | 04:36 PM
  #219
Creeve's Avatar
Creeve
i used windex
Old Jul 12, 2008 | 05:28 PM
  #220
enron29's Avatar
enron29
Originally Posted by Creeve
i used windex
Yeah, that's what I was trying, but I was worried about rubbing through the mirror finish again. Were you able to get all the smudges off?
Old Jul 13, 2008 | 12:01 AM
  #221
Creeve's Avatar
Creeve
like fingerprints? if so then yes.
Old Jul 13, 2008 | 12:42 AM
  #222
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I think if you have the Xenons you would do well to use a high temp paint. The Halogen Joey mods do not seem to have any issues with standard spray paint. I did my Xenons with the Krylon Fusion and I do have some small cracks in my black near the projector lens.
Old Jul 13, 2008 | 11:28 AM
  #223
ADAMSALTAMINI
PrepSol!
Old Jul 13, 2008 | 01:04 PM
  #224
enron29's Avatar
enron29
Originally Posted by ADAMSALTAMINI
PrepSol!
This won't rub right through the finish??? Can I get this at a pepboys or something like that??? Thanks.
Old Jul 13, 2008 | 03:24 PM
  #225
enron29's Avatar
enron29
Here are some pics. Not the best. I apologize for the dirt. Unable to clean it before. Big thanks to checkercoop for the help.
