Interior/Exterior OEM Cooper S Upper Gauge Kit
Old Oct 30, 2007 | 05:06 PM
verveAbsolut's Avatar
verveAbsolut
http://www.outmotoring.com/mini-coop...gauge-kit.html
I would have preferred boost and oil temp...oh well...I can always use the mounts to fit something custom.
Anyone know if it limits range of motion on the steering column?
- Matt
Old Oct 30, 2007 | 06:29 PM
M3NTAL's Avatar
M3NTAL
I like that one the most out of all the aftermarket kits, but it seems like not many people are using it. Anyone have photos of theirs?
Old Oct 30, 2007 | 06:39 PM
mcs22004's Avatar
mcs22004
- Matt
Voltmeters seem to be common to some of the best gauge mount kits for some reason.
It appears to sit the gauges pretty close to the dash.
Old Oct 30, 2007 | 08:58 PM
verveAbsolut
I would agree...really hoping it doesn't affect column range.
- Matt
Old Oct 31, 2007 | 05:32 AM
BGA's Avatar
BGA
I've had this gauge set for a couple of years. my $.02:
I don't think it significantly affects wheel tilt travel. I do not recall how far up the wheel goes with out the gauges installed - with them, I have 1/4" to 3/8" gap between the back of the tach and the padded dash lip when the wheel is at it's max height setting.
The inboard gauge housing - to the right of the wheel when you are driving - is touching the dash when the wheel is at max height setting - I have no scratches / damage resulting from that - the back of the gauge housing is a curved shape to match the dash contour.
A couple other things:
- the boost gauge moves all over the place as you accelerate and such the volt gauge just moves to about 14 and stays there.
- note the needles are not illuminated as they are on the standard MINI gauges ~ I switched to blue illumination to add some contrast at night.
- Also note there are a lot of other gauge set ups available (Outmotoring sells several of them).
I hope that helps.
Brian
Old Oct 31, 2007 | 05:47 AM
mcs22004's Avatar
mcs22004
There must be a rule that kits that come with the right gauges are the wrong color. http://www.outmotoring.com/images/P/...ost_oil_md.jpg
Old Oct 31, 2007 | 05:56 AM
Big Daddy's Avatar
Big Daddy
- Matt
I picked up one of these gauge pods used at MOTD this year (don't ask for how much, it will make you cry) and installed Autometer Ultralite Boost and Oil temp gauges in it at Detroit Tuned. I love the look of it and it has not affected the steering column motion a bit. (I'm 6'2" so that was a concern for me). The boost gauge is really kind of useless after the initial install and I wish I had put an oil pressure gauge in instead. I may still. Hope this helps....
Old Oct 31, 2007 | 08:20 PM
verveAbsolut
Wow...thank you all for the responses...answered my question as to affecting steering wheel tilt (none).
Yeah, boost I can deal with...the voltmeter really bothers me; after all, what is the point unless you're planning on putting in, or have something, that puts serious strain on the electrical system. Oil temp would let me know when I'm good to mash the fun pedal on warm up. Ideally, I'd love an OEM looking 4-way setup with oil temp, oil pressure, EGT, and...something else cool .
Again, thanks for the response guys.
- Matt
Old Nov 1, 2007 | 05:01 AM
Big Daddy's Avatar
Big Daddy
- Matt
I think the Scangauge II might be worth looking at then.
Old Nov 1, 2007 | 06:54 AM
mcs22004's Avatar
mcs22004
Too bad they don't sell the pod without the gauges.
Old Nov 1, 2007 | 09:28 AM
BGA's Avatar
BGA
pods with out the gauges: http://www.outmotoring.com/mini-coop...pod_mount.html
ALTA offers a pod ~ and probably others do too - this cravenspeed set up look very flexible (iPod mount capability too)
Note that the OEM gauge set originally referenced in this thread (the one that I have) - those gauges match the background / face color of the tach and speedo (grey / silver). And the illumination that comes with it is orange ~ just remember that the needles do not light up. The included gauges are Stewart Warner sourced - I think the only thing custom about them is the Cooper S logo on their faces.
Brian
Old Nov 1, 2007 | 10:21 AM
mcs22004's Avatar
mcs22004
Brian
I was referring to the oem-looking pod rather than the widely available frankenpods.
Is it difficult to see the needles at night?
The gauges look similar to the 2 1/16" Competition gauges:
http://www.sw-performance.com/upload/114537.jpg
I could be wrong, but it appears that this same item is currently listed at $276.25 at the dealer.
http://www.trademotion.com/sfimages/...Image30587.jpg
Old Nov 1, 2007 | 11:16 AM
verveAbsolut
They are different...the OEM one is the only one which replaces the black panel below the tach...all the other, to my knowledge, bolt to the back of the tach instead.
If you're interested, MiniMania has the official install instructions available on their site. You can see the difference in install there.
- Matt
Old Nov 1, 2007 | 12:16 PM
mcs22004's Avatar
mcs22004
- Matt
Thanks. They have better pictures as well:
http://new.minimania.com/imagesbig/nmi7625.jpg
http://new.minimania.com/imagesbig/nmi7625a.jpg
Doc:
http://new.minimania.com/images/inst...7625_INSTR.pdf
Old Nov 1, 2007 | 01:15 PM
BGA's Avatar
BGA
I meant no offense - and I agree that the OEM pod looks, well ... more like OEM
To me, it is not as easy to see their needles at night ....
conversely, with their darker needles, they are a little easier to see during the day.
I think the blue LEDs give good contrast to see the needles much better at night than the std. orange illumination. And I am quite happy with the way they make the dash look.
Old Nov 1, 2007 | 02:47 PM
verveAbsolut
I think I may go with two options...the first of which being the ScanGauge II. BigDaddy posted it earlier; after doing some research I am quite fascinated now.
If they made the OEM mount alone available, I would go with the ScanGauge II and Oil Temp/Pressure in a heartbeat, and stick the ScanGauge in my new handy-dandy parcel shelf.
On that note, anybody know of any way to get the OEM mounting piece alone? I can't believe the only way to get it is to buy the full gauge set-up. What if you had this installed at the dealer and they broke just that one piece? I can't believe they would re-buy the whole package much to their loss. Part number has to be somewhere...
- Matt
Old Nov 1, 2007 | 02:59 PM
mcs22004's Avatar
mcs22004
- Matt
The install doc only references one part number: 82 94 0 393 994.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
M7Speed
Aug 6, 2015 01:48 PM
