How To Electrical :: AutoMeter Boost Gauge Install
Old Jul 6, 2006 | 06:53 PM
  #126
DarkMiniCooperS's Avatar
DarkMiniCooperS
Here's a quick picture to show where the screws that hold the speedometer console. There's also that dimmer wire behing it, connected to the dimmer button.
Just remove the 2 surrounding moldings around the dimmer button and the hazard button in order to remove that part.
Old Jul 16, 2006 | 06:30 PM
  #127
DarkMiniCooperS
Last Friday, I've seen Bahamabart's custom bracket for a VDO gauge and it looks great! It's a little more "involving" job than buying an AutoMeter kit, but it is still "do-able" for anyone that wants a different gauge brand!
Old Jul 17, 2006 | 08:13 AM
  #128
Bahamabart's Avatar
Bahamabart
While DarkMini's cup holder works, the extended bracket gives you a little bit more play in the sense of being able to angle the guage as well as a little more space between the guage and the tach. The part is 6 bucks and its made out of aluminum so the "fabrication" required is actually very easy, requiring minimal tools and time.
Either way you go - you can easily add a boost guage to your MINI bringing boost entertainment to the cockpit.
Old Jul 29, 2006 | 06:21 PM
  #129
polizei's Avatar
polizei
I was thinking of doing this...but had a question.
I have to buy a bulb for the gauge?
How many do I buy, and how do I put them in, and where do I put them in at?
BTW: I was thinking of this one: http://store.summitracing.com/partde...5&autoview=sku
And is there anyway to mount to on the right side? I'd like to add another gauge on the left side later on, but I want the boost gauge on the right so I can see it.
Edit* After reading more, I figured out I can buy the "extended" bracket, but where can I buy that? Also, what is the dimension of the tubing I need, so I can pick up some.
Thanks!
-Cody
Old Jul 30, 2006 | 07:04 PM
  #130
polizei's Avatar
polizei
Bump...anyone?
-Cody
Old Jul 31, 2006 | 11:30 AM
  #131
polizei's Avatar
polizei
Bump #2....I would like to order these soon. Anyone out there!?
Thanks,
-Cody
Old Jul 31, 2006 | 06:37 PM
  #132
Bahamabart's Avatar
Bahamabart
Peter of MyMini had always liked the guage bracket I had fabricated out of an extended bracket. Peter has fabricated his own MyMini single guage bracket (made out of steel and painted blank).
These aren't even posted yet on his website www.myminiparts.com.
The bracket is designed to accept an autometer cup and he is offering them for $15 bucks. While modding the extended bracket is a fun project, when you add up the bracket and paint - $15 bucks isn't bad at all.
worth considering and stays true to the $70 guage.
take a look -
Old Aug 1, 2006 | 06:28 AM
  #133
JoeCool's Avatar
JoeCool
The bracket looks nice. Do you know if Peter will be selling the bracket with an appropriately sized screw to fix the bracket onto the tach?
Old Aug 1, 2006 | 06:57 AM
  #134
Bahamabart's Avatar
Bahamabart
Good question but I don't know. I know he was thinking of putting together a few kits - guage, cup and bracket for those that want one stop shopping.
Since I only used 1 screw, I supplemented it with double stick tape. I recently used some of the 3M tape and I bet that stuff would afix it to the tach alone just fine. The stuff really sticks.
If anyone is interested in this - you gotta call Peter since its not even on the website to get one (code word is "bahamabart" ).
Old Aug 1, 2006 | 07:22 AM
  #135
polizei's Avatar
polizei
So the bracket comes like that for $15, then I also have to buy the mounting cup, correct?
-Cody
Old Aug 1, 2006 | 02:30 PM
  #136
Bahamabart's Avatar
Bahamabart
-Cody
CORRECT.
This thread has covered two approaches using the bracket that comes with the guage cup or modding an extended bracket. The extended bracket which costs like $5 bucks requires a little fabrication and then painting which this bracket eliminates. You still have to drill a hole in the bracket to attach to the tach based on location. Ths bracket is generic so it requires fitment based on where you want the guage.
So this bracket is additional to the guage and the cup but I think it gives you a little more flexibility when mounting a guage. In particular the ring that goes around the cup ends up in the middle as opposed to using the little bracket that comnes with the pod, the ring ends farther back. You also get some left right angle justment for that cockpit view.
Up til now any guage holders has been high end like alta, promini and others. Each gorgeous - some out of billet aluminum.
This bracket is for the budget enthusiasts who wants a Mini project by adding an autometer guage to the cockpit. Again designed to take an autometer cup! The placement is your choice and you decide on how to attach to the tach pod.
Old Aug 1, 2006 | 03:36 PM
  #137
ada722's Avatar
ada722
Will this bracket work for those of us with chrono or nav packs?
Old Aug 1, 2006 | 04:44 PM
  #138
ncirillo31's Avatar
ncirillo31
i have a jcw recommended boost guage and where to get it??
Old Aug 1, 2006 | 08:24 PM
  #139
Bahamabart's Avatar
Bahamabart
Yes, its a a generic bracket.
From here its your imagination - 1 bracket, 2 brackets, 9 o'clock position, 8 o'clock position, 3 o'clock position, ............
Old Aug 2, 2006 | 09:31 AM
  #140
DarkMiniCooperS
The gauge I installed has a max boost reading of 20psi, so you'll be fine!
Thanks Bart for the link to the bracket. I received 2-3 PM lately about it
Old Aug 5, 2006 | 10:56 PM
  #141
duglas's Avatar
duglas
well... I ordered my gauge and cup from Summit and I ordered the bracket from myminiparts.com... it is on there site now, it was like $21 shipped though....
Old Aug 6, 2006 | 07:51 AM
  #142
xizor's Avatar
xizor
I noticed a problem with the one I installed some monthes ago, the boost reading was slowly getting lower and lower until finally there was no reading at all, the needle stayed at 0 psi.
Pulled apart the intercooler yesterday and like I figured, the hose had come off the fuel regulator. I put the hose back on but it would just slip right off. I ended up using electrical tape to keep it up and it reads normal now
Old Aug 6, 2006 | 07:55 AM
  #143
polizei's Avatar
polizei
Thanks. When I get mine I'll tape it so I don't have to go back later!
-Cody
Old Aug 6, 2006 | 09:20 AM
  #144
Bahamabart's Avatar
Bahamabart
Couple of things -
1) the holes in the bracket are just there - you will want to drill "the" hole. in my case I wanted my guage to be in the 7-8 o'clock position. As you can see I did not get it exactly where i wanted it the first time.
But this is the beauty of the bracket in the sense that you "customize" the fit and location.
2) adding a curve to the bracket just ties it all in to the tach and allows for the double stick tape.
have fun
Old Aug 27, 2006 | 04:18 PM
  #145
JCWGurl's Avatar
JCWGurl
Coordinator :: Manitoba MINI Motoring Club
Just to add to this thread for people with the Chrono dash, I used the smaller (2 1/16th") Auto-meter boost gauge. I did not use the mounting cup at all but instead I used a 2" wide piece of flat aluminum and drilled holes to bolt the gauge directly to it. I painted the aluminum piece and the gauge flat black (except for the part where I needed two sided sticky tape) and using sticky tape, I just stuck it to the back of the Chrono gauges-it works and looks awesome. No holes drilled in the car and no messing with weird bolts or screws. I followed the directions on this thread for where to attach the hose and the electrical, it was all easy and I didn't scrape any knuckles and got the right wire on the first try. Here's pics:
Old Aug 28, 2006 | 12:17 AM
  #146
fj0's Avatar
fj0
I installed this Saturday when I did my 15% pulley and it was a really straightforward install, no problems. You had to wiggle the IC quite a bit though to get it off, but then again I might not have done it correctly.
I'm now boosting 1 BAR.
Do you guys also have a special sound when boost gauge is pointing inside that box on the gauge, the 0?
Old Aug 28, 2006 | 01:53 PM
  #147
ICEMAN's Avatar
ICEMAN
Wow, 1 bar, that's about 14 psi, correct? Our stock JCW MCS hits 12 psi anytime but at high revs will hit 13 psi.
Old Aug 28, 2006 | 02:27 PM
  #148
fj0's Avatar
fj0
Google says 1 BAR is 14.5 PSI.
Old Aug 28, 2006 | 02:56 PM
  #149
TwOMINIs's Avatar
TwOMINIs
Did this boost gauge install a while ago with the directions posted and im still staring at the gauge.
What fun. With the -15%/ + 2% crank and MTH tuner I hit ~16 psi at redline.
I wonder what the additional "whisker" of psi gives me in terms of power...likely not much...still fun all the same.
This is a great Mod
Old Aug 29, 2006 | 02:58 AM
  #150
fj0's Avatar
fj0
This is a great Mod
Nice!
