How To Electrical :: AutoMeter Boost Gauge Install
Old Aug 29, 2006 | 04:07 AM
  #151
polizei's Avatar
polizei
What's all this talk about hitting your knuckles?
I hope to do this soon...ahh I want the little gauge for piece of mind.
-Cody
Old Aug 29, 2006 | 11:12 AM
  #152
DarkMiniCooperS's Avatar
DarkMiniCooperS
-Cody
Everytime I work under the bonnet of my MCS, I lose some skin on my hands
It's part of the game now!
Old Aug 29, 2006 | 12:07 PM
  #153
JoeCool's Avatar
JoeCool
Here's a link for an extended bracket.
I figured out I can buy the "extended" bracket, but where can I buy that?
Cody-
I think Jegs has what you want.
http://www.jegs.com/webapp/wcs/store...tegoryId=10335
Old Aug 29, 2006 | 12:28 PM
  #154
DarkMiniCooperS
http://www.myminiparts.com/proddetai...od=MMGB&cat=10
MyMINI has some custom extended brackets in stock...
Old Aug 29, 2006 | 07:57 PM
  #155
polizei's Avatar
polizei
Thanks guys. I'll look into it when it comes time to actually place an order. As of right now I have...$21 to my name. So I'm not buying anything for a least a month or so.
Actually, on second thought I have -$15 because I owe my mom money....
-Cody
Old Aug 31, 2006 | 06:21 PM
  #156
DarkMiniCooperS
-Cody
lol
just make sure to keep some $$ to feed your MINI (fuel)
Old Sep 9, 2006 | 12:10 AM
  #157
cooper99's Avatar
cooper99
There are many issues to keep up with on this thread. So just to make certain before I buy anything, the latest recommendations are:?
1. Autometer Mounting Cup $14
2. Vacuum/Boost Gauge $50
3. Custom Extended bracket for more adjustabality? $15
And is it just as easy to install another Autometer mounting cup and place it on the opposite side with a different gauge (a/f ratio, H20 temp, oil temp, oil pressure)? Which would be the 2nd most important to have?
Old Sep 9, 2006 | 01:35 PM
  #158
cooper99's Avatar
cooper99
^^ Bump ^^
Old Sep 9, 2006 | 06:43 PM
  #159
Bahamabart's Avatar
Bahamabart
Instead of the extended bracket that requires a litle fabrication - pick-up the bracket from www.myminiparts.com. Peter took my modified extended bracket and made a nice one out of steel. It is 15 bucks as opposed to 6.95 but needs no work other tha a hole and is painted.
The brackets can be mount as you like and more then one is not a problem.
AF might be nice
Old Sep 9, 2006 | 08:03 PM
  #160
DarkMiniCooperS
I did both standard, tach on the sterring wheel column, and chrono-pack/ Navigation "twin gauges" on the steering wheel setup. Both didn't need any extended bracket.
Old Oct 9, 2006 | 10:21 AM
  #161
bigpmj's Avatar
bigpmj
Argh...I wish I knew I needed the 1/8th connector for the vacuum line...now I gotta call the girlfriend to drive me to the parts store!
Old Oct 13, 2006 | 05:49 PM
  #162
DarkMiniCooperS
You mean the "T" fitting to slplit the vacuum hose from the fuel pressure regulator?
All the parts should be included with the gauge (at least Autometer)
Old Oct 16, 2006 | 07:49 AM
  #163
MiniMacPR's Avatar
MiniMacPR
DIY Gauge w/ Chrono Pack
Well, since nobody has posted a picture of the AM 2 5/8" Boost Gauge on the Chrono Pack per the original How-to, here they are:
I wish AutoMeter had gauges with chromed outer rings .
Anyhow, I have a couple of things to add.
My gauge did not come with a T-fitting, just the nylon tubing, so make sure you check before starting! To connect the "T" fitting to the nylon tubing you need a 5/32" to 1/8" vaccum reducer fitting, which is shown in the original pictures but I don't think it's mentioned in the write-ups. The connection to the fuel pressure regulator would probably be easier with a vaccum elbow fitting; just an afterthought, I didn't do it. I think the connection to the regulator would also be more secure that way. A #8 1 1/4" long phillips Self Tapping screw is a perfect fit for the rear tachometer bracket connection.
I am a bit concerned with the engine heat and the nylon and additional vaccum tubing. No technical info on heat and melting points or anything, just a concern since things tend to get quite hot in there. However, I think someone would have chimed in already if something would have happened, from his signature DarkMiniCooperS has over 100k miles I'm guessing with no issues (right ?).
BTW, I followed the original instructions with the exact gauge and mounting cups and found NO fitment issues. It is quite tight, but I actually found several different mounting positions with this setup. I just chose the position that will be the most viewable from a normal driving position. It blocks a bit of the A/C vent but nothing that causes concern (ask me again in July).
Lastly, the hardest part for me was the bulb replacement on the gauge. Seriously. That thing was on like cement in there. I actually showed a tech at PepBoys while getting the replacement bulb and they questioned whether it was replaceable or not . At the end I ended up crushing the darn thing and cleaning it up for the replacement.
Phew, I'm done with the post. Thanks to DarkMiniCooperS for the original post, and to the others have added opinions . I swear NAM is gonna make me go broke if I keep on finding other stuff to add to my car...It is a SERIOUS addiction.
Old Oct 16, 2006 | 07:51 AM
  #164
Bahamabart's Avatar
Bahamabart
if you picked up the mymini guage bracket, your rings wouldn't be so far back nor would you guages stick out past the speedo/tach.
Old Oct 16, 2006 | 08:05 AM
  #165
MiniMacPR's Avatar
MiniMacPR
Well, I think the angle of the picture plus the chrome is a bit misleading, the AM gauge is actually about 1/16" behind the level of the tach/speedo (basically flush) and not sticking out.
Agreed on the ring. The support on the back is not as intended on the part and the gauge does fit a little looser than I would have liked.
Old Oct 16, 2006 | 09:29 AM
  #166
Bahamabart's Avatar
Bahamabart
If you go thru this thread you will see wh ere I fabricated a custom bracket from an auto meter extended bracket. Peter of www.myminiparts.com liked
what I did and had a steel version made which he sells for 15 bucks. Gives you that extra flexibility.
Old Oct 16, 2006 | 11:14 AM
  #167
jaynicholson's Avatar
jaynicholson
Has anyone gone with a carbon fiber mounting cup? And what about a gauge with chrome trim?
Old Oct 16, 2006 | 12:44 PM
  #168
jaynicholson
OK, I called up Autometer directly, so here I go answering my own questions.
First, the chrome trim. If you send the gauge to their repair center they can add the "anodized" trim piece (which they use on the carbon fiber series gauges). This is pressed on using a specific jig that they use. This is apparently pretty easy for them, but the minimum charge for any repair shop work is $25. So you'd be looking at $25 + shipping each way.
Second, the carbon fiber mounting cup. I explained that I know that the ATM-3204 cup works for this application and the cup would have to have the same dimensions. I was told that cup #2152 is the one to get. I reiterated that this MUST be the same dimensions as the 3204 and I was assured that it is.
Lastly, I'm sure that this was already addressed, but the amber LED conversion is part #3287.
Old Oct 21, 2006 | 07:38 PM
  #169
DarkMiniCooperS
This part # is from AutoMeter?
Let me know by PM please... I'll update my first post, to let other people know!
thanks
Old Oct 21, 2006 | 07:51 PM
  #170
COR BLMY's Avatar
COR BLMY
Just a helpful tip if you want it.
When I did my 3 gauge set up the Aurometer gauges came with both red and green "cap/covers" for the bulbs.
After much experemintation I used a paper punch and cut out the end of the red "thingy".
The color is ORANGE and matches the stock gauge color perfectly
Old Oct 22, 2006 | 01:34 PM
  #171
DarkMiniCooperS
good tip!
you have a picture of your gauge with light on?
Old Oct 22, 2006 | 08:58 PM
  #172
COR BLMY's Avatar
COR BLMY
Have not done that
Thought I had taken all possable
I'll do that now
Old Oct 22, 2006 | 09:36 PM
  #173
COR BLMY's Avatar
COR BLMY
Harder than I thought to take these photos.
More on my gallery, but hope this shows the actual color of the red covers with a hole punched in them.
Old Oct 23, 2006 | 06:50 PM
  #174
DarkMiniCooperS
It does look great!
But why installing the boost gauge upside-down??
I'd have a headache after 2 minutes of driving lol
Old Oct 24, 2006 | 09:13 AM
  #175
COR BLMY's Avatar
COR BLMY
Originally Posted by DarkMiniCooperS
It does look great!
When seated you I actually look "through" the stering wheel just like looking at speedo / tach.
This way I can see the full sweep of the gauge.
It works ... and no headaches for me.
Lets also be honest the boost gauge is really a wow, wow, fun gauge anyway.
I use it more on long trips to watch Vac to get best mileage.
