How To Electrical :: AutoMeter Boost Gauge Install
Old Jun 17, 2008 | 12:31 PM
  #276
jaynicholson's Avatar
jaynicholson
Originally Posted by call it spade
i can't see it cleary enough
Did you take the tach off?
Old Jun 17, 2008 | 06:02 PM
  #277
call it spade's Avatar
call it spade
lol not like that. in the picture i can't see which hole he drilled the cup into. :P
i can see all the holes i just didn't know which one that needs to be used lol
Old Mar 22, 2009 | 07:32 PM
  #278
xizor's Avatar
xizor
My boost gauge is reading low and I looked at the T fitting and the rubber outer cover for the hose is cracked in multiple places. I taped it up to see if it would seal, but no luck. I'm looking for a replacement piece but I haven't found one yet. Anyone have suggestions on where to find it? Didn't see anything on autometer's website.
Old Mar 22, 2009 | 08:44 PM
  #279
call it spade
to find a T fitting? I'm not sure if you have a Home Depot there but they have plastic ones that i used. try that.
Old Mar 22, 2009 | 08:47 PM
  #280
xizor's Avatar
xizor
I'm looking to replace the cracked rubber piece, you can see it in this picture. It's what hold the hose into the T fitting
Old Mar 22, 2009 | 08:49 PM
  #281
call it spade
NAPA auto parts will have that connecting piece Just did mine two days ago.
Old Mar 23, 2009 | 06:00 AM
  #282
DixonL2's Avatar
DixonL2
Looks like you can also use a small piece of the right diameter hose, good luck! Head over the the oldest auto parts store in town, the guy behind the counter should be able to help. Talk to the old guy, not his teenage helper.
Old Mar 23, 2009 | 02:36 PM
  #283
chuckt's Avatar
chuckt
AutoZone has them also.
Old Apr 26, 2009 | 07:42 PM
  #284
Dustin77327's Avatar
Dustin77327
Originally Posted by DarkMiniCooperS
Yes, as Sneves said, the lightning wire can also be tapped into the harness of the tach.
Thanks Sneves... This thread is on its way for a sticky thread, at least I hope so! lol
How about a ground? Where do you ground the light? just put a 2 5/8 JEGS boost/vac gauge and autometer pod in the mini today 56 bucks total from jegs comes with vac hose and t-fitting. O yea my car makes 10 psi at WOT is that about right for a stock mini?
Old Apr 26, 2009 | 07:49 PM
  #285
DarkMiniCooperS's Avatar
DarkMiniCooperS
10 PSI is about right for a stock MCS.
You can ground the gauge with any bolt that touches metal under the dashboard. I used a bolt that screws in a metal part near the pedals.
Old Apr 26, 2009 | 07:54 PM
  #286
Dustin77327
Thanks I'll post pic after work tommorrow!!!
Old Apr 26, 2009 | 09:05 PM
  #287
call it spade
mine only runs 9... :(
EDIT: Fixed the slightest of boost leaks and now running 11-12psi on stock.
Last edited by call it spade; May 27, 2009 at 12:55 PM. Reason: fixed boost leak :)
Old Apr 28, 2009 | 08:21 AM
  #288
Dustin77327
miniboostgauge010.jpg?t=1240931523
I think it came out pretty nice for 50 bucks
Old Apr 28, 2009 | 08:24 AM
  #289
Dustin77327
http://s111.photobucket.com/albums/n...stgauge013.flv
Heres a short video of it
Old Apr 28, 2009 | 11:32 AM
  #290
call it spade
here's my set up.
Old Apr 28, 2009 | 12:02 PM
  #291
Dustin77327
Nice what all do you have? I think I want an oil pressure, voltage meter next. I'll mount those under the auto A/C controls
Old Apr 28, 2009 | 12:05 PM
  #292
call it spade
I have volt, oil pressure, water temp, and boost. It was fun day to install it all!
Old Apr 28, 2009 | 12:19 PM
  #293
Dustin77327
all autometer? I've never seen those mounting pods before their nice!!! How hard are the other gauges compared to the boost? I finished it in about an hour
Old Apr 28, 2009 | 12:59 PM
  #294
call it spade
Yup, all autometer. Those are the Cravenspeed dual pod gauges. They're amazing. I'm going to make some custom fiberglass backs to them though. The gauges are all pretty simple. Both the volts and water temp were easy peasy. I haven't gotten to the oil pressure yet because i'm waiting to change my oil to do it at the same time. But I ordered the tapless oil adapter from craven speed and that's a simple switch out. They're pretty easy!
Old Apr 28, 2009 | 05:51 PM
  #295
Dustin77327
So I have a problem now the check engine light came on. So I took it apart to check the connections and the bottom part of the T-fitting has a brass plug in it, the one that goes to the fuel pressure regulator. I'm guessing I need to pull that out and reset the battery?
Old May 27, 2009 | 08:23 AM
  #296
dustinhxc's Avatar
dustinhxc
thank you so much! i finally bought the autometer gauge and mounting cup and it installed great with this write up! also a special note thanks for the pictures of the normal boost vacuum hose hookup because i dont have all those extra hoses so i would have been way confused with those images. thanks everyone for your help! i now have a boost gauge for around $80 instead of $350
Old May 29, 2009 | 06:07 PM
  #297
Motor On's Avatar
Motor On
Anyone have any issues with the gauge itself leaking?
I've got the Autometer gauge, a high pitched whistle in the cabin, that can only be heard when the engine is running, if everything else is off, and my yo-yo is severely acting up, and I've been getting periodic system too lean codes.
Old May 29, 2009 | 07:09 PM
  #298
call it spade
My roommates Audi TT had the same problem. We went to a Home Depot and picked up some brass piping I think it was and replaced the plastic piping. It was super cheap as well... Good Luck
About the Yo-yo and the lean codes I can't help you there...
Old May 29, 2009 | 07:16 PM
  #299
Motor On's Avatar
Motor On
Well my theory is the gauge has a vacuum leak that is causing imbalances in pressure in the wrong places, that's causing the other issues.
Old May 29, 2009 | 08:10 PM
  #300
call it spade
That's what i thought too. But maybe it could've been the piping. Most likely a faulty gauge...
